Belt has broken down and is not able to rotate the drum of machine. New belt of that size is not available in the market nor at any samsung centre in India.
  • 2,510 Answers
Get a belt a little larger and make up, or have somebody make up an adjustable idler wheel on an arm that you can use as a tensioner for the belt. If there is a belt just a little smaller, you could try work out a method of moving the motor closer to the drum to compensate for the shorter belt.
For the time being, forget the dryer and enjoy the cricket - do you think India will win? Our boys arrived home over the weekend, they were not very popular.
Posted on Mar 28, 2011
How to change a belt on a whirlpool ultamite care plus washing machine
Rear access panel off belt right in front of you. turn drum and pull old belt towards you fit new one by putting over motor spindle first, then feeding onto drum spider as you rotate it. Tension by moving motor on it's bolts (out for tighter, in for slacker) About 1/2" movement in centre of slackest part of belt.
May 19, 2012 | Whirlpool Washing Machines
Bosch Classixx 1400 Express - Drum not rotating.
Sounds like teh belt has either broken and come of of drum, or is simply lose. take the back off mchine; if broken buy a new one; if lose loosen motor bolts, press teh motor down until belt is taught and retighten. Check first to see if their is soap on the belt/pully/drum/motor carrying the belt as this could be causing it to slip
Dec 04, 2011 | Washing Machines
Washer makes a buzzing noise when it tries to spin
Hello. Loud noises coming from a Washing Machines are most often caused by looseobjects inside the unit or by a broken dryer belt. The Washing Machines beltallows the dryer's motor to run smoothly. Continuous wear and dry conditionsmay cause the belt to dry out, eventually Washing Machines cracking and thensnapping. This will cause a loud noise within the unit. Repair and fix thedryer belt of a Washing Machines to get rid of loud noises. Instructions And Things You'll Needed to solve the problem.
Screwdriver ,Replacement Washing Machines belt 1 Stop the Washing Machines and look inside the dryer's drum for any looseobjects such as coins, pens or anything else that may have been in a pocket ofclothing. Remove the object and restart the dyer to determine if the noise hasstopped.
2 Unplug the Washing Machines from the wall outlet to disconnect all power tothe unit. 3 Remove the lint trap from the lint compartment on the top of the dryer. 4 Remove the screws that hold the top panel in place. Pull the panel off toaccess the
dryer belt.
5 Tilt the dryer forward and lift the dryer drum to remove the belt. Check theWashing Machines belt. A belt that is worn, cracked, split or broken will causeloud noises. 6 Slide the old belt off of the drum and pull it out to remove it. Take noteon how it is positioned over the drum.
7 Install the new belt. Lean the front panel away from the Washing Machines andslip the new belt over the drum. Locate the position of the old belt and slipthe new belt following the old belt's position ensuring the grooved side of thebelt faces down. Push the idler pulley towards the motor to allow you to slipand loop the belt around the motor pulley.
8 Place the top panel on the Washing Machines and screw it in place.
9 Open the Washing Machines door and use your hand to rotate the drumcounterclockwise a few turns to ensure the belt is secured.
10 Plug the Washing Machines into the wall unit and begin use . Thanks.
Sep 13, 2011 | GE Energy Star WCVH6260F Front Load Washer
How do i fit a new belt
Replacing the belt on your machine is pretty easy. You will first need to take the top off. Depending on the model of your machine, there are either 2 screws at the rear of the machine that hold the lid on, or there is a screw at either side of the lid, about 3 inches back from the front, hidden under a couple of oval plastic covers about the size of your little finger nail (Note, these are torque "star" screws). Remove the screws and give the lid a sharp tap backwards with the heel of your hand to unclip it from its fixings. The lid will now lift off. Now go to the back of the machine and remove the lower oval cover (about dinner plate sized) that is held on by about 6 screws. This reveals the empty pump and the end of the motor drive shaft.
From the top of the machine, dangle the belt down and lasso the drive shaft of the motor, move the belt to the centre of the slotted shaft (you should see where the original belt was, because that section of the pulley will be shiny.
Now take the belt in one hand and holding the contact side of the belt (grooved side) against the large pulley wheel that drives the drum, slowly spin the drum pulley by hand, holding the belt in place where you first made contact with the drum with one hand, while guiding the belt on to the drum at the bottom of the pulley as you slowly spin it. The belt will stretch and after one full turn it will be in place. Now just check that the belt is in the correct position on the drum and motor pulley by spinning it a few rotations by hand.
OK, Job done. Now for the bad news. Drive belts just DO NOT "come off" or break on good machines. They come off because there is a fault. The really bad news here is that the usual reason is that the main bearings on the drum have failed causing the drum to "flop about" and causing the belt to dislodge. You should really check the bearings of your drum before you go buying a new belt, because if they have failed then the cost of repair will potentially write the machine off. Below are my standard instructions about checking bearings. Please let me know how you get on.
Sep 09, 2011 | Zanussi FLA1001W Front Load Washer
How to replace a drive belt?
OK, Job done. Now for the bad news. Drive belts just DO NOT "come off" or break on good machines. They come off because there is a fault. The really bad news here is that the usual reason is that the main bearings on the drum have failed causing the drum to "flop about" and causing the belt to dislodge. You should really check the bearings of your drum before you go buying a new belt, because if they have failed then the cost of repair will potentially write the machine off. Below are my standard comments about checking bearings. Please let me know how you get on.
To test your bearings, open the door of the machine and by putting a little lifting pressure on the top of the inner drum, attempt to rock the stainless steel inner drum up and down.
The outer drum is mounted on springs and shock absorbers, so it will rock about (and it should do this) but the inner drum should not move up and down in relation to the outer drum. There should be ABSOLUTELY NO PLAY between the 2 drums, even the tiniest amount will mean the bearings have failed.
If the bearings are bad enough then other symptoms will typically include:
A clonking noise as you lift and release the inner drum (this is the inner drum rattling on its bearings and/or hitting the outer drum)
You will have become aware of the spin cycle becoming far noisier recently and possibly even a grinding crunching noise when the machine spins.
The drum may feel like something is crunching or stopping you turning it when you spin it by hand with the door open.
A leak from under the machine, which you will probably be able to trace to the back of the machine, coming from the centre of the drum. This is a result of the failing bearing allowing water to escape through the seal at the rear.
This is NOT a job for the uninitiated DIY enthusiast as it will mean stripping the machine and removing the drum from the chassis, splitting it, removing pressed in bearings and then sourcing and re-fitting new bearings.
To be frank, the cost of a bearing set (if they are replaceable, and most are) will be about £20 ($30) or so. But it's a long and horrible job if you haven't done it before. I know professionals who claim they can do a bearing change in under an hour, I've done a few and it takes me about 2 hours by the time I've ripped the machine apart and reassembled it after the bearing swap. A local repairer will probably attend and swap out your defective drum for a refurbished one and then take yours away so he can refurbish it and put it back in his stock. Sadly, this will take the price up to the point where you need to question if the expense is worth it or do you get a new machine instead.
Aug 25, 2011 | Hotpoint Washing Machines
Hi i have a speedqueen awm373w-3062 have noise on
Hello.
Loud noises coming from a Washing Machines are most often caused by loose objects inside the unit or by a broken dryer belt. The Washing Machines belt allows the dryer's motor to run smoothly. Continuous wear and dry conditions may cause the belt to dry out, eventually Washing Machines cracking and then snapping. This will cause a loud noise within the unit. Repair and fix the dryer belt of a Washing Machines to get rid of loud noises.
1 Stop the Washing Machines and look inside the dryer's drum for any loose objects such as coins, pens or anything else that may have been in a pocket of clothing. Remove the object and restart the dyer to determine if the noise has stopped.
2 Unplug the Washing Machines from the wall outlet to disconnect all power to the unit.
4 Remove the screws that hold the top panel in place. Pull the panel off to access the
dryer belt.
5 Tilt the dryer forward and lift the dryer drum to remove the belt. Check the Washing Machines belt. A belt that is worn, cracked, split or broken will cause loud noises.
6 Slide the old belt off of the drum and pull it out to remove it. Take note on how it is positioned over the drum.
7 Install the new belt. Lean the front panel away from the Washing Machines and slip the new belt over the drum. Locate the position of the old belt and slip the new belt following the old belt's position ensuring the grooved side of the belt faces down. Push the idler pulley towards the motor to allow you to slip and loop the belt around the motor pulley.
9 Open the Washing Machines door and use your hand to rotate the drum counterclockwise a few turns to ensure the belt is secured.
Aug 02, 2011 | Washing Machines
I have a new Samsung electric dryer (DV218AEB/XAA)
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-160-1067142-/Samsung-Dryer-not-heating-DV218AEB
Click the link for no drum turning. There is a belt in the machine that wraps all the way around it, the belt has come off or broken.
Oct 08, 2017 | Samsung DV218AEW Electric Dryer
Does a front felt bearing belt that sits at the front of a hotpoint machine drive the drum or would it be another belt?
No the drive belt sits around centre of the drum, you would need to remove the top of the machine to see the drive belt.The felt belt acts as a bearing and helps drum rotate quieter
Feb 19, 2010 | Dryers
My mini washer samsung does not tumble
pl. remove rear cover and see if belt is broken ? if belt is ok also check freeness of drum by rotating with hand.
Nov 07, 2009 | Samsung WF337AA Front Load Washer
I have a kenmore 27 inch electric dryer that when you push the start button it sounds like it starts but the drum doesn't turn. What could this be?
A clear indication that your dryer belt is broken is when the dryer drive motor runs but the drum does not rotate. A new belt is relatively inexpensive from several online or a local parts vendor, but installing it can be a bit frustrating since the dryer drum usually needs to be remove to install a replacement belt. Access to the interior of the dryer is usually necessary. For Maytag (and some Kenmore) models, the front of the dryer can be easily removed (two screws below front contour) by pulling out on the bottom of the panel and rotating up to release the top clips. Once off, place to the side, then remove four machine screws from the front drum/lint filter assembly, then remove by pullling out. Once off, place aside. Remove drum by lifting up and pulling out on drum (since the belt is broken it will not provide any resistance). Once removed, inspect the motor pulley arrangement noting the belt routing path around the motor pulley, belt tensioner, and the drum. Inspect the drum for belt wear marks, noting approximate location on drum where belt rides. Install replacement belt by routing through pulley arrangement (ridged side of belt rides againt motor pulley), then "hang" the belt on the interior backside to enable reaching the belt after reinstalling the drum. After placing the drum edge on the rear rollers, lift the front of the drum up into position, working the belt around the drum into the drum groove. Once the belt is in the groove, the drum should stay in position without lifting from the front. Check for proper pulley routing, taking care to avoid routing the belt OVER the tensioner belt keeper, i.e., route the the belt under the belt keeper to avoid belt riding on the keeper and failing prematurely. Install the front/lint filter assembly. As you manually rotate the drum, reach along the top and side of the drum and gently pull the belt out of the groove and into its normal ride position. Install the front panel, plug the unit in, start and check for proper rotation of the drum.
Oct 04, 2009 | Kenmore Dryers
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
