Question about Vizio L32 32 in. LCD HDTV
How can a tv that got plunged into a 220 europen plug instead of a 120 us plug get repaired
    Brigadier General:
  • 8,909 Answers
It will only be a standard power supply fault to repair. Any good engineer, with a circuit, should be able to repair it.
Posted on Mar 28, 2011
How can I tell if maker is wired for 220 or 120
If its been changed to 220V plugging it into 120V won't damage anything, it just won't work. Replace the plug with a 120V plug end and plug it in. If it works its120 if it doesn't, its either a 220V setup, or you have a blown fuse in the unit/power supply or some other defect.
Nov 04, 2014 | Bunn CWTF Coffee Makers & Espresso...
I plugged my desk top to 220 volts line instead of 110 volts
Most likely the damage is too great to be repaired and if it can be repaired the cost of repairing may not be worth it.
If it was me I would put my money towards a new computer.
Jan 04, 2013 | Dryers
It came with a american plug and when we put a converter to australian plug on it it only shows 220w instead of 240 which is what we have in australia. Don't want to plug it in and it blow up on me.
I think you mean 220 volts, versus 220 watts. The difference between 220 & 240 volt equipment is usually just a matter of nomenclature -- no significant difference in terms of operating the equipment.
The vacuum is 110 / 120 volt since it has an "American" plug on it. If the plug is swapped for an "Australian" plug (or adapted) and plugged into the wall, the vacuum will be connected to 220 volts -- this would destroy the motor.
You would need a transformer to step down the Australian voltage to 110 / 120 volts. If you plug it in without a transformer, it will surely burn up the motor.
More info, let me know.
Charlie
Mar 30, 2011 | Vacuums
Is a Hampton Bay HBD240A window A/C 120v or 240v?
I have never seen a 240-volt window A/C unit for the U.S. market. So, my guess is it's 120 volt.
The best way to verify this is to read the name-plate on the unit.
Another way is to look at the plug on the unit's cord. There are at least three types of plugs :: 120 volt, 15 amp; 120 volt 20 amp; and 220 volt. 120 volt 15-amp will fit a standard household wall outlet. The 120 volt 20 amp plug is similar to a 120 volt 15 amp, but will not plug inot a standard household outlet. The 220 volt plug is altoghether different.
Charlie
Jan 08, 2011 | Heating & Cooling
When I turn the tv on it turns on than it goes into hibranate mood. and it doesn't go on.
first try plunging the TV into another wall outlet if still nothing then the power supply board needs servicing. This repair shouldn't cost more than $220 if the power board is bad but prices differ from State to State....
Let me know if you have any other questions:-)
http://tvtechwork.webs.com/
Oct 18, 2010 | JVC LT42P789 42 in. LCD TV
What type of outlet do I use ?
It depends....
Some units are 120 volt and others are 220v
Units up to about 18,000 btu are usually 120 and over that they are often 220...
The pug for the 120 will look like a normal light cord plug and the 220 plug will have the two blades going sideways instead of up and down...
Also for the larger units you will need a dedicated circuit for them as they take too much power to run on a circuit with anything else...
heatman101
Apr 28, 2010 | Heating & Cooling
I plugged my air conditioner into a 220 outlet and it doesn't turn on now, what could the problem be?
is there any Power at the outlet. dose it have 120 on each side of Plug 120=120= 240 or 220. maybe a blown breaker?
Jul 04, 2009 | Haier hwr10xc6 Air Conditioner
120 volt to 220 volt plug
it is sorry that the clock has been damged by high voltage so , it can not be repaired but you can replace the entire set
thank you
May 15, 2009 | Sony ICF-C318 AM/FM Clock Radio ( White )
Voltage
no!   It will be ruined if you try that.
Oct 16, 2007 | Kirby G6 Bagged Upright Vacuum
Vizio L32 32 in. LCD HDTV Logo
18 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
