Question about Dell 3100cn Laser Printer
I'm getting the following error: Dell 3100cn Laser Printer error 004 332 problems
    Problem Solver:
  • 11 Answers
Try restarting your printer, if this does not help make sure that the toner cartridges are set in properly and locked in place.
Posted on Mar 28, 2011
Testimonial: "Thank You. I t was very helpful"
I took out my cyan cartridge then put it back in. No idea why it worked but that ...just came back with same message.. oh well
Posted on Nov 15, 2011
  • Kay Kuck Nov 15, 2011
    Messed with cyan toner cartridge and again ready to print, but only in black and white.
3 Suggested Answers
SOURCE: Error Code 004-332
Error code: 004-332
This type of error code implies that you need to restart the printer again. However, do check to see if toner cartridges are seated in the proper position. Also ensure that they have been locked in. This is an error commonly associated with the Dell 3100cn laser printer.
Posted on May 13, 2008
WonderTech
  • 268 Answers
SOURCE: 3100cn Laser Printer: dell 3100cn service manual...
This link will take you to a site where you can download the manual for your machine. You will the link on the right side of the page.
http://safemanuals.com/user-guide-instructions-owner-manual/DELL/3100CN-_E
Hope this helps.
Posted on Aug 04, 2010
My printer wont work. its a dell laser printer
did you think of installing the drivers. the printer should have come with a cd with the drivers on but if you dont have that here is the link to drivers online. Just follow the step by step instructions and your printer should be up in no time.
http://download.cnet.com/Printers-Dell-Laser-Printer-3100cn-Driver/3000-2116_4-109366.html
Jul 02, 2011 | Dell 3100cn Laser Printer
Installed new yelloe cartridge but printer keeps stating to reseat cartridge
009-340 Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ...imaging drum cartridge. Turn the printer off using the power switch on the left side. Wait 10 seconds, turn the printer back on, and check if the error message...sensor solenoid nip. Turn the printer off using the power switch on the left... (English) 016-720 PCL Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ... Press Select ( ) to clear the error on the printer. Reset the printer NVRAM: Press Menu. Press the...and then press Select ( ). When Restart Printer appears, turn the printer off and then back on... (English)
KB Article How Do I Configure and Troubleshoot My Dell Color Laser Network Printer? - KB Article - 296059 ...Troubleshooting Guide for My Dell 3000cn-series / 3100cn Laser Printer ...available online for your Dell 3000cn/3100cn laser printer. The troubleshooting...printing, refer to the Dell Laser Printer 3000cn/3100cn Troubleshooting Guide... (English)
Dec 13, 2010 | Dell 3100cn Laser Printer
004321 restart printer error
Nov 30, 2010 | Dell 3100cn Laser Printer
Dell 3130cn gone down with repeating 016-370 Error...
This type of error code implies that you need to restart the printer again. However, do check to see if toner cartridges are seated in the proper position. Also ensure that they have been locked in. This is an error commonly associated with the Dell 3100cn laser printer. Please let me know the results.
Jun 28, 2010 | Dell 3100cn Laser Printer
Hope this helps.
May 17, 2010 | Dell 3100cn Laser Printer
My dell laser printer 1320c has printer error code 091-935 come up what does this mean?
this error means
Replace DrumCart
091-935
Drum Full of
Waste Toner
The drum cartridge needs to be replaced. fro more information about how to remove it you can got to following link
http://support.dell.com/support/edocs/systems/3100cn/en/UG/section22.html#172399
Sep 09, 2009 | Dell 1320c Laser Printer
004-332 error plus carousel is out of whack
contacted dell tech support. noticed that the rotator frame was slightly bent. tech told me that the printer had to be replaced since they do not offer parts for this.
May 27, 2009 | Dell 3100cn Laser Printer
Manual for RAM upgrade
Memory Upgrade for Dell Color Laser Printer 3100cn Printers, the Dell Color Laser Printer 3100cn Printers takes the PC133 SDRAM SODIMMs Memory Type, and comes installed with 64 MB (non-removable) of Memory. You can upgrade your Dell Color Laser Printer 3100cn Printers to up to a maximum of 576 MB Memory, the system has 1 socket to install Memory, already with 64 MB (non-removable) standard Memory installed.
http://www.memorystock.com/memory/DellColorLaserPrinter3100cn.html
You should be able to get crucial or the likes to send you the correct memory - as for where it goes that will be in the manual
May 25, 2009 | Dell 3100cn Laser Printer
My Dell 3100cn will not print unless I press Init NVRAM and restart printer every time I want to print. This is annoying. Can you help? Thanks! Greg
this implies that you need to restart the printer again. However, do check to see if toner cartridges are seated in the proper position. Also ensure that they have been locked in. This is an error commonly associated with the Dell 3100cn laser printer.
rate my answer
Aug 22, 2008 | Dell 3100cn Laser Printer
Dell 3100cn Duplex won't feed
I'd suggest it is a sensor issue. Since the error comes up, the printer stops responding - even if everything is okay.
Jul 28, 2007 | Dell 3100cn Laser Printer
Dell 3100cn Laser Printer Logo
643 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
