Question about Tecumseh Enduro Horizontal Engine 5 HP 2532in x 2 2532in Tapered Sha
Hey i have and enduro 5 hp and it is a B**** to start but once it is running it good till you idel it down then it just dies
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly,
Download this manual:
http://www.cpdonline.com/692509.pdf
First things first turn off the fuel selector if there is one.
See figure 10 on page 14. I think your going to have to remove the float bowl and the idle screw and use some carb cleaner in the idle screw hole. BEFORE you remove the idle screw turn it "clockwise: gently counting the number of turns until it just stops turning. (write it down as IDLE) DO NOT force it closed. Then remove the idle screw for cleaning. Also remove the main adjustment screw but loosening the nut ONLY that retains the float / fuel bowl. (do NOT turn the main fuel jet until after removal. Again count the number of turns it took for the jet to just stop turning. (Write that down as MAIN) Spray carb cleaner into the idle screw hole and into the threaded area where you removed the bowl nut / main fuel jet. What ever you do if your carb has any Welch plugs in it DO NOT remove them even if the manual tells you to do so.
One thing to check is that your carb mounting bolts are tight and that gaskets are in tact. The symptom your describing can be caused by a bad intake gasket also. It is ok to loosen the carb and slide it away from the head gently and inspect the gasket. DO NOT disconnect any linkages, just inspect the gasket.
After cleaning things up (jets) remove the fuel supply hose form the fuel inlet fitting and leave the float itself in the down position. Spray carb cleaner from the float needle are UP to the fuel inlet manifold. You are attempting to free any debris from the float needle seating area and flush it out through the fuel inlet. Usually you DO NOT have to remove the float and float needle to do this but there are exceptions when there is a large piece of debris in the float needle area. Usually if there is debris here the carb overflows. I do not think you have an overflow problem at this time.
Reconnect the main fuel line. Briefly turn ON the fuel selector and as fuel flows check that as you raise the float to level the fuel shuts off. Turn OFF the fuel selector. If you are not getting good fuel flow here inspect the fuel tank outlet port and fuel filter.
Reinstall the main fuel jet into the bowl nut until it is closed then turn it counter clockwise the number of turns you wrote down for MAIN. Reinstall the float / fuel bowl and main fuel jet but make sure the inner gasket that goes between the bowl and the bowl mounting nut is installed (2 ea usually one inside and one outside the bowl. Install the idle jet screw until it just closes and then turn it counter clockwise the number of turns you wrote down for IDLE.
If you have difficulty with mixture jet adjustments the pre-sets are on page 20 of the manual.
If you find that your going to have to completely tear down the carb and overhaul it the steps are in the same section just past the pre-sets.
Turn ON the fuel selector and attempt a start.
This usually fixes most Tecumseh carbs.
Let me know the outcome please. And if you need parts I can help you locate an on-line source but most lawn more repair shops will have overhaul kits for your engine. I will need your engine number to get you the right parts manual.
Thanks for choosing FixYa,
Kelly
Posted on Mar 28, 2011
Starts right up but once it warms up it dies have messed with the air gas screws that's fine don't know what the problem is
My car runs good when it's cold but stalls once it warms up ...
www.badasscars.com/index.cfm/page/ptype...id.../prd289.htm
My car runs good when it's cold but stalls once it warms up? ... In this situation, you can usually re-start the engine once it has hada chance to cool back ... it'll fill-up and exits fuel right up and out the vent tube which dumps it down the middle of ...
Car starts and after warmed up.. it dies!! HELP! - Honda-Tech
honda-tech.com/...del.../car-starts-after-warmed-up-dies-help-2797652/
Jun 28, 2010 - Car starts and after warmed up.. it dies! ... but if i let it sits for awhile till the engine is cool down it starts right up but after its warmed up.. it dies.
Troubleshooting an Engine that Stalls at Idle When Warm ...
www.gearheaddiva.com/.../troubleshooting-an-engine-that-stalls-at-idle-...
Dec 21, 2015 | Cars & Trucks
Problem with my fzr after first ride in the morning iit wants to die wen taking off an most of the time it will then start it an it wont rev if let throttle go it will die
I'll tell you why. It is cold natured. I have a 89' Virago, and it doesn't like going anywhere till' it is warmed up. I usually just set the choke up a bit for about 5 minutes, and then hop on and go.
Apr 15, 2013 | 1988 Yamaha FZR 250
1990 toyota pickup v6 starts-up step on gas pedel motor then dies
does thr engine rev upwhen started than idels back down.try idel control switch and map sensor
Oct 27, 2012 | Cars & Trucks
1996 GMC jimmy rough idel and dieing when driving.
i have seen many strange things happen with the distrib cabs on these
Aug 22, 2012 | 1996 GMC Jimmy
Just turns off on it's own, Wait 60 sec. restart press pedel it dies.
This engine is electronically controlled so the first thing that must be done here is to have the systems control computer tested for fault codes and then do the proper diagnostics based on those codes.
Jun 07, 2012 | 1995 Plymouth Voyager
I have the 6.5 hp self propelled model, It starts fine and runs strong for aprox 5 min then dies, seems to die when it gets hot possibly, the die time is always the same aprox 5 min. Once it dies it will...
I don;t know what engine is on your mower but if it has the self contained electronic ignition coil I have seen happen on several engines. It would run good for several min. then the spark just stops . And it will not spark again until it sets and cools . Just make sure it is the ignition that is not working.
Sep 15, 2010 | Toro Lawn Mower With Toro Power Tools
Truck runs great going down the road, when I stop and start to take off it bogs down like it is getting no fuel and then dies. I wait for about 5 mins and it starts up and runs great for a few days. any...
either ur engine isnt getting enough fuel while ideling or its getting to much and flooding....what kind of system is it?? injection or carborator?
Jun 20, 2009 | 1998 GMC Sonoma
I have a 1968 mustang with 1966 289 c. code .engine starts good .idels ,good till it reaches running temp. then it sounds like the rockers start to chatter .and mis fires till it dies.it has 40psi on oil...
Yes.sounds like the oil pump is laying down when oil gets hot,,,,,,but,,,,i would try changing oil filter..I have seen Oil filters will **** together after a few min. of run time.....I would never use a WIX oil filter,,have had 3 friends loose engines because of the same thing..........hope this helps......
Mar 01, 2009 | 1966 Ford Mustang
Tecumseh Enduro Horizontal Engine  5 HP 2532in x 2 2532in Tapered Sha Logo
387 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
Jim Parker
Jim Parker
lnbn1975
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
