Question about Bose Companion 2 Computer Speakers
NO SOUND FROM MY BOSE LEFT SPEAKER - Bose Companion 2 Computer Speakers
  • 27,725 Answers
Try swapping the speakers around if the problem still persists either the speaker is faulty
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
be sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Posted on Mar 28, 2011
My 07 avalanche has bose s s intermittent sound on left channel
Sound troubleshooting - Bose
worldwide.bose.com/.../en...tv...sound/page.html?...
Bose CorporationSound troubleshooting. No sound from speaker. Make sure the sound system is turned on and the power indicator is on (solid green). Increase the volume.
Aug 08, 2015 | Cars & Trucks
I have a Toshiba flatscren, just baught a Bose cinemate GS series 2 sound sytem, and only one speaker works, Returned it, got a new one and it does the same thing, It must be a settings issue on my TV ?? ...
The left audio channel pre-amplifier in your TV is not working. Fixing that is a job for a technician with an oscilloscope, or else you would have to replace the main board in the TV.
If you connect another device (CD or MP3 player to your Bose sound system, I expect you will hear both speakers playing the sound from the other device.
Oct 19, 2017 | Bose Cinemate Digital Home Theater System...
The left speaker of my Bose On-Ear headphones suddenly stopped working although putting pressure on it makes sound come out for a very short time.
This may sound strange, but try slipping a piece of cotton on the area where the bare conductor runs through the plastic covering of the speaker (as suggested here). 39c682c9-7c92-4e14-963e-7b6eb35c074d.jpg
Apr 04, 2011 | Bose Audio Players & Recorders
@I got a bose acoustmass 7 it has three inputs left right center,and three outputs left right center dont have paper work I need like a diagram or instructions on hooking it up please help.
you need to run the left speaker output from the amp to the left speaker input on the Bose, the right speaker output on the amp to the right speaker input on the Bose, the center channel output on the amp(assuming it has one), to the center channel input on the Bose...then the right output on the Bose , to the right Speaker..the Left output on the Bose to the left speaker...and finally the center channel output on the Bose to the center speaker
Jan 07, 2011 | Bose Acoustimass 5 III System
Getting the sound on the right speaker only
Its likely a broken wire. You can take them apart if you are careful and re solder the wire if you have the tools and are ok with doing that. its a little tricky. if you need more help email me. n_raven99(at)hotmail.com
Mar 20, 2010 | Bose TriPort Consumer Headphones
No surround sound
It sounds like the speaker wires are mixed up or maybe a setting on the reciever is wrong. Verify your speakers are properly connected. you test speakers using a 9 volt battery or smaller.
Jun 19, 2009 | Bose Lifestyle 12 System
I have Harmon Kardon AVR 25 ii receivers and I have attached it to Bose 701 front speakers and three other Bose surround speakers and an subwoofer. All the speakers work except for right speaker, I need...
To locate the problem...a) Cable
Test if right cable is ok, by interchanging the rt/left cables.
b) Test Bose right speaker
Connect the Bose right speaker to HK's left channel. Works? Then Bose right speaker is ok.
c) Test HK's right output by connecting the left Bose speaker to HK's right output.
Does not work?
Jun 16, 2009 | Audio Players & Recorders
Bose Lifestyle 20 system. sound from only two speaker
A lifestyle 20 system is stereo only. Two channels. Left and right.
Jun 04, 2009 | Bose Lifestyle 20 System
Brookstone Wireless Outdoor Speaker with Bose 123 System Problem
AUX usually refers to an INPUT, such as a CD player, etc. No signal comes out of a standard AUX jack, unless it specifically says "Aux speaker output". Instead, look for another speaker output jack, such as remote speaker, B speakers, etc. You may only have one set of speaker output jacks, in which case you would need to connect your wireless speaker to the speaker output jacks along with your main speakers, or buy a little speaker selector switch box to switch between main and wireless speakers. There's usually no harm in connecting more than one speaker set to the same outputs, though it is technically not recommended. In the real world, just don't crank it too loud and you'll be fine. The wireless speaker MIGHT run off of a standard line output also, if the wireless speaker has its own power amplifier.
Dec 15, 2008 | RCA WSP150 Main / Stereo Speaker
Bose Wave Radio/CD - Sound from only one speaker
Sounds like the audio transformer, but it's difficult to tell because Bose will not release their schematics or parts lists, effectively giving them a monopoly on repair of these sets. On their web site, www.bose.com, they offer to repair most Wave sets for $100 or give $200 credit towards the purchase of a new Wave. Before you spend the big bucks though, you might want to check out the new HD radios. Better sound and MUCH lower prices than the Bose.
Dec 06, 2007 | Bose 683-0332FB CD Shelf System
Bose Companion 2 Computer Speakers Logo
686 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
