Question about Toshiba Satellite L355-S7817 Notebook
Need to return to recovery of toshiba l355 and now work vwith xp
Toshiba satellite won't go on
Hello. It sounds like either...
1. Your power adapter is damaged/not working. Look and see if a LED is illuminating on the power adapter. If it is chances are it is working fine and the problem may lie on your laptop. If not replace it. The easiest way to tell if your power adapter is bad is to go out to Wal-Mart or your local technology store and purchase one of their universal power adapters. They are expensive but you can buy it, try it, and return it if it does not solve the problem.
If you are going to buy a new toshiba ac adapter, you may consider the following toshiba l355 charger:
Replacement Toshiba Satellite L355 AC Adapter 90Watt 19V 4.74A
OR
2. The DC pin on your laptop is bent/broken/loose. Look at where your power adapter plugs in on your laptop. Get a paper clip, bend it out to make a long paper clip and slightly push its tip on the pin inside your laptop. If the pin moves chances are either the DC pin needs to be soldered down or needs to be replaced. The part is usually cheap around $10 but the labor can cost more than $50
Dec 01, 2012 | Toshiba Satellite L355-S7811 Notebook
Web cam drivers for a toshiba satellite L355-s7907
Camera Utility for Windows XP / Vista (32/64bit)
OK this is the web address where you can download your driver I dont know your OS SYS vista ,7 ,or ?? but this is for Xp and vista I hope this help you
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2232774&rpn=PSLD8U&modelFilter=L355-S7907&selCategory=2756709&selFamily=1073768663
Oct 25, 2011 | Toshiba Satellite L355-S7907 Notebook
I know my laptop has a recovery partition on it, its an L355-S7907 the partition is not the 0 key, Ive done it before but seem to have forgotten what the partition for this particular one is even though...
The toshiba software included with laptop will give you the protocol for performing a recovery operation.. Look in the Toshiba folder in hard drive . You will have a choice of a repair option or restore to factory defaults which erases everything you may have done and returns unit to condition it was in brand new out of the box.
Sep 10, 2017 | Toshiba Satellite L355-S7907 Notebook
Cant restore operating system on toshiba laptop
1. If restoring using recovery discs; you have to turn on your laptop... then at the TOSHIBA screen press F12. This will bring you into the boot device selection screen select your CD/DVD drive from the list and press Enter.
2. If restoring from the recovery partition... turn on your computer while holding the 0 key down this will bring you into the recovery program
THIS is the documentation direct from Toshiba. hope this helps.
Feb 09, 2010 | Toshiba Satellite L355-S7811 Notebook
How do i put my toshiba tecra laptop back to factory settings with no system cd
what model tecra? some have a recovery partition, either hold 0 during startup or call toshiba for the recoveries. they run about 25 bucks
Nov 01, 2009 | Toshiba Satellite L355-S7811 Notebook
I have a Toshiba Satellite L355-S7811 laptop that will not boot. It keeps going to a blue screen that says fatal error and before I can read it,it restarts. I dont have a recovery cd so I dowloaded 2 from...
See let me talk with you from experience...
The only thing that can be done is system restore to factory default and remember to backup your documents.
This is the only way to resolve the problem you are going through.
Cheers.
Oct 11, 2009 | Toshiba Satellite L355-S7811 Notebook
L355-S7812 missing wireless adapter driver
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1998632&rpn=PSLD0U&modelFilter=L355-S7812&selCategory=3&selFamily=1073768663&selModel=1998632|PSLD0U here is your link i assume you can download you will need two files
security utility wifi and bluetooth lan utility wifi they are to be downloaded.open file and run the software
it will reload your wifi. kawuna
Dec 01, 2008 | Toshiba Satellite A205-S4617 Notebook
XP DRIVERS for Toshiba L355-S7812
here are the XP drivers I have found for that model system:
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modItemList.jsp?BV_SessionID=%40%40%40%401773750978.1210856642%40%40%40%40&BV_EngineID=ccceadeedkhgjelcgfkceghdgngdgmn.0&ModelDLOS=Windows+XP%7C132594&ModelDLCat=null&BV_SessionID=%40%40%40%401773750978.1210856642%40%40%40%40&BV_EngineID=ccceadeedkhgjelcgfkceghdgngdgmn.0&ListType=Model&ct=DL&moid=1998632&rpn=PSLD0U&OrderBy=D&PublicStartIndex=25&PrivateStartIndex=0&PublicCutOff=&PrivateCutOff=&AddOldPublicItems=false&AddOldPrivateItems=undefined&all_docs=false&x=39&y=12
If you cannot find a specific driver, then post the driver you need and I'll see if I can find it.
May 15, 2008 | Computers & Internet
Toshiba Satellite L355-S7817 Notebook Logo
43 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
