Question about HP ProLiant ML350 G4p Server
Hi there, i have an hp proliant ml350 wich has been working fine for many years, i have recently moved offices and it simply wont switch on, no power no nothing, any ideas? all is plugged in the same as usual and all power leeds are fine. kind regards, Jake
ted1430
  • 339 Answers
SOURCE: After initial power on of HP ProLiant ML350, it will not stay on.
Is it on a dedicated circuit? Have you checked the voltage? As a control, I would suggest you move it back to its most recent location temporarily or at the very least to a location with a different power circuit to try to isolate if you have a power issue or a server failure.
Do you have two power supplies? If so, be sure they are plugged into independent circuits if at all possible.
Posted on Jul 12, 2009
ted1430
  • 339 Answers
SOURCE: hp proliant ml350 g5 vga drivers for windows 2000 professional
Download the latest Proliant Support Pack from HP's web site. This will update the drivers for everything on the server at once.
Just go to hp.com and click the link for "Support & Drivers" at the top, then click the radio button to download drivers and enter ML350 into the text box. Select the G5 from the list and then select your OS. The PSP will be near the bottom of the page. The display driver will be close to the top if you just want to update it.
JaxPlanet
  • 922 Answers
SOURCE: HP Proliant asking for a power-on password
If it is a hardware password, such as the motherboard, the there are two possibilities that I know.
1. Shutdown and unplug the power. Remove the battery on the motherboard wait 30-seconds and replace it.
2. There should be a CMOS reset jumper on the board. Typically, you move it over one pin, power on the board then power down and put it back to reset. Best bet is go to www.hp.com and check Support & Drivers for documentation on your ML350.
If this helps please vote for my solution.
Posted on Sep 22, 2009
  • 2386 Answers
SOURCE: i want to freely download
you can download fron the HP official web site
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3279709&lang=en&cc=us&taskId=135&prodTypeId=15351&prodSeriesId=459045
good luck, and do rate the solution if helped
Posted on Nov 30, 2010
Mustgo
  • 2359 Answers
SOURCE: My HP ProLiant ML350 G5
There was a critical HP ProLiant ML350 G5 ROM BIO upgrade dated on 17 Aug 2010.
Please bookmark the bio update link HERE for reference.
Check your monitor Hz and display resolution setting.
Did you change any video driver or resolution before reboot?
If all else fail then swap in a simple S-VGA card and let Windows 2003 to sort out the 640X480 display mode.
Posted on Jan 05, 2011
Server won't boot after bios update
http://forums.whirlpool.net.au/archive/1758237
Oct 21, 2013 | HP ProLiant ML350 G4p Server
Tip
Windows Server 2008 Network Driver for Proliant ML350 G3
Anyone who has tried loading Windows Server 2008 on their Proliant ML350 G3 has found that HP does not offer the network driver for this system.
BUT, the Windows Server 2003 driver for the NC series Broadcom 1gb will work! Rather than choosing the 'install' option, choose to 'extract' it, then via the device manager, manually install the driver from that location.
Happy Computing!
on Feb 04, 2009 | HP Compaq ProLiant ML350 G3 Server
I need Network card (LAN) driver for HP Proliant ML350 5G server.
Go the website of HP, chose for the support and drivers - lookout for drivers and software - enter your product name i.e HP Proliant ML350 5G Server and click on search.
You will get the list, select your product. Select the operating system you are using on your server - then choose the driver type - click suitable, from the list of drivers and download it.
Apr 23, 2013 | HP ProLiant ML350 G5 Server
Smart array 5300 PCI-X 64Bit/66MHz in ML350 G5 server.
it will be a controller card problem / SA5300 is 100% compitable
Jan 17, 2013 | HP Compaq ProLiant ML350 G5 Server
Problem with harddrive
It could be because the disk is not a part of any array. Log into the server and go to the array controller utility from HP and check for any unassigned disks. It will be displayed there rather than the diskmanagement window.
Feb 01, 2010 | HP Compaq ProLiant ML350 G3 Server
Hp proliant ml350 g5 vga drivers for windows 2000 professional
Apr 08, 2009 | HP ProLiant ML350 G5 Server
HP Proliant ML350 G5 wont boot ,just spining.
The G5 Series is fairly new, if you're within warranty, call 1800-okCompaq.
Could be a bad cable, a bad monitor, or bad computer hardware. Any display at all or any beep codes?
On the back, the ml350 G5 will likely have an additional Network interface jack-- this may be labeled ILO. The ILO network connect allows you to use another PC on the same network to access this system (like a remote control via VNC or RDP) even if it won't power up--literally. Inside the ILO page, (you'll need the IP address of the ILO, the default account is administrator, and the default password is listed ona paper tag attached in the rear or on a sticker. If you can get into ILO via web browser: https://ipddress of ilo, you can check the Integrated log, which can shed some light on any failures.
Mar 19, 2009 | HP Compaq ProLiant ML350 G5 Server
Jan 25, 2009 | HP ProLiant ML350 (370507R001) Server
I canĀ“t use a serial ata disk in a proliant 350
I know ATA disks are cheaper , but they don't last as long or are less reliable.
I do not recommend mixing SCSI and ATA .
Use one or the other , not both.
Do not try , unless your server is non critical.
If it is non critical , why bother with server , a PC will do as well.
Thanks
David
May 14, 2008 | HP Compaq ProLiant DL380 G4 Server
HP ProLiant ML350 G4p Server Logo
37 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
