Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
My tv screen is smaller than usual, opened the tv and saw that the transistor burned. I cant find anyone with a transistor or a replacement, the transistor nr is IRFS G 14 B
    Brigadier General:
  • 8,909 Answers
Any Sony Service Centre will be able to source the part for you. Try CPC.co.uk or SEME.co.uk
Make sure you have the correct type number as the one quoted does not exist.
Posted on Mar 28, 2011
C6090 transistor burn in just seconds
This link will give u a general idea why your transistor burn down.
It could be the hor coil or the driver or lack of hor drive pulse or bad dc hv level or a 100 more reasons !
Usually tv technitions get lucky by replacing a 3-5 $ transistor ,
solving the problem and charging u 100-150 $ , u did the samew took a chance now i am sure u will consider buying a new lcd tv .
good luck
Feb 23, 2015 | Televison & Video
Where can I get the scematic for the Veco 21 STC voltage control circuit board?
try mailing the manufacturer
hot transistors are usually shorted out, or driving a short!!
a multimeter across the 3 transistor legs (TO-3 transistors have 2 legs & the case which is the 3rd leg) will reveal if they're dead (remove the transistors first as the circuit may give a false reading) - if you get a zero ohms reading between any of the legs it's dead - don't forget to check the smaller driver transistors too,, as a dead main transistor will kill its smaller driver transistor
speakers are marked,, usually 4 ohms or 8, though sometimes 16 ohms - use a multimeter to ensure you have something very close to these values according to the label on the speaker box & measure from the wires at the point where they connect to the amp
power the unit without any speakers or speaker wires connected,, if the transistors still get hot, you're very likely looking at bad transistors
Feb 21, 2015 | Audio Players & Recorders
Samsung CRT flyback problem
When fly-back transformer gets damaged, there is a chance to a leak to its horizontal output transistor too. Replace this too. If you wish to get some details, check the site linked here.Pull up older posts.
Dec 07, 2013 | Televison & Video
Sir i have a problem w/ my tv. w/ i turn it on it appears a light circle center on my tv screen. before that sir. it has a horizontal tv screen only i replace 100uf 50volts capacitor then. replace it new....
You probably used the wrong capacitor or it requires to change more than one. Check and make sure that there are no more burned capacitor or transistors that may cause such as failure. Good Luck!
Oct 15, 2013 | Aiwa F2000 20" TV
Half my screen stays green
the problem is in the color circuit.but this lcd has itcolor circuit on a module,so the whole module has to be replaced.the problem is a shorted kine driver transistor on the module or the reistor on the colector of the transistor is open.it can also be a defective color driver which is a ic..replace transistor.resistor or ic if posible.. if cant,,, then do the above, replace the module.good luck.
Sep 25, 2011 | Sanyo DP19647 19 in. LCD TV
The image of my TV is getting smaller and not clear
Vert. output transistor went in the television. Your remote dosen't have anything to do with that. have a service person look at the television
Jul 14, 2010 | Samsung TV Remote Control
T.v. not coming on ,turned off by itself with an arc noise
The part is known as a flyback transformer.. it will have to be replaced.. also the horizontal ouput transistor will possible most likely be bad..
Dec 16, 2007 | RCA D52W19 52" Rear Projection Television
JVCAV-N2043TV,Horiontal Output Transistor burns out everytime if fix a new one
Hi There,
The Hor Output transistor is connected to the Line Output Transformer. This transfromer provides a lot of voltages around your TV set but includes the very high voltage to the Picture tube...
These transformers are specially tuned to resonate at a certain frequency,
The Hor output transistor needs to match this frequency....so if the wiring inside the transformer is shorted by "just a bit" the picture will be visible but the transistor is struggling to match the transformer impedance,from the mismatched tuning...so the transistor draws more current from the power supply.. runs hot then burns out...
Usually manufacturers provide a Trip circuit that detects that an overload on the power supply is occuring and cuts the power to the Line output stage ...this is usually detected by a clicking sound within the power supply its called hiccuping.
If some one has altered the correct setting on the power trip circuit then the next thing that happens is the Transistor goes Blooooey like in your case.....
So to save you a lot of money replacing the output transistor
please replace the output transfromer as well next time...
But please... please... re-check the power supply trip circuit to save you a lot more expense in the future....
Best Regards From YUBEUT
Oct 10, 2007 | JVC AV-27230 27" TV
TV SCREEN PICTURE SMALLER
Yes you have a problem I'm afraid in the pincussion or horizontal width circuit. These circuits usually have alot of high voltage in them and is not a safe place to be experiementing around with. Most of the time, with a problem like this, there are bad capacitors or a correction transistor has failed. If the set is over a few years buy a new one. Good Luck
Jun 04, 2007 | Bush 5693D 24" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
85 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
