Question about Pioneer Car Audio & Video
Hi I have a pioneer carozzeria fhp 999 mdr how do i get the mp3 player to play through the aux input
  • 6 Answers
SOURCE: mp3 to aux input
Try putting the unit in standby via the "SRC" button FIRST..., then press the menu button and cycle through to the "AUX 1" option and activate this....then press menu button again. When the unit is next switched on, you should have an "AUX" option accessible via the "SRC" button which will cycle through all of the availale modes ....standby-tuner-cd-aux etc etc.
Posted on Nov 04, 2007
mixmaster
  • 626 Answers
SOURCE: Cannot Find Aux On Kenwood KDC W3037A
You have to ENABLE to AUX source thru the settings menu.
Users manual is HERE.
Best of Luck.
Please RATE my solution BELOW.
Posted on Nov 24, 2007
tech48
  • 624 Answers
SOURCE: Stereo in my Fiat punto
Yes that should work for you, you just need a cable that will convert the mini-stereo jack of the mp3 player to an RCA jack if the aux input is an RCA input. If it is the same 3.5mm size then you only need a 3.5 mm male to 3.5 mm make cable. Make sure when you first plug it in, the mp3 player volume is turned down low and you can adjust it higher after the is working for you. You don't want to input too big of a signal into the car stereo at first. then you should adjust it so that it is about the same volume as the radio is at. You don't want to blow up the amp ic in the radio or the pre-amp ic for the aux input.
Posted on Jun 17, 2008
SOURCE: aux input not working for mp3 player
Hi to you all. CAN YOU HELP ME? i have peugeot 206 and i have new kenwood CD MP3 and i also have aux input but I cant get any sound to come out at all?
Posted on Jul 12, 2008
SOURCE: Hi, I have a Panasonic
Hi, I have the Panasonic SA-EN9, and if you plug your mp3 player (I have and ipod) into the auxiliary socket you should be able to play it by pressing the AUX button on the remote provided.
Hope It Helps :)
Posted on Aug 25, 2008
How do I get the MP3 player to work in a 2007 Nissan Quest?
you said CAN , i bet you meant CAN'T or CAN NOT. right?
the AUX port is just a line input, analog audio input,
it dont know MP3 .
it only amplies the analog audio found there.
you connect any device, to AUX. push play on the device.
then put car radio in to AUX input mode and play. the audio.
that is all there is to it.
the external device does all the heavy lifting, reading a file, and decoding it (mp3 decode) and then sends raw analog audio out.
the cable is sold and radioshack, or walfart or many other stores,
Target, most MP3 players, come with this cable,
they use mini phone plugs, stereo, type,. (3 contacts)
Jul 05, 2014 | 2007 Nissan Quest 3.5 Minivan
Can I use the Aux port to play USB in Ford audio/CD MP3 player
hi, you may use the aux port by using the right type of usb, hope this helps
Feb 12, 2010 | Car Audio & Video
Cannot get my mp3 player to operate on the aux input consistently
I have a 2002 Pontiac Montana and I use a 2 pronged RCA plug at one end with a yellow plug and a white plug, and the other end is one plug to use for the MP3 player. Plug your RCA plugs into the bottom 2 plugs. My RCA plugs on my cord are yellow and black the yellow one is in the middle
plug and the black in the bottom one and I use the AUX input for my MP3 player. I have a SANSA
and a Ipod and they both work fine. I hope this helps. Just a FYI so you don't think your radio is
going whacko after you do get the MP3 player to work the AUX will always come on first and you will have to push the AM/FM button on the dash or the steering wheel to get the radio or DVD back on.
And the DVD player will have to be switched on for the AUX to play the MP3 player.
Have fun...
Mar 28, 2009 | OEM Systems Car Audio & Video
Problems conecting to pioneer reciever
You will need a 1-to-2 AV Y-adapter. One end will plug into the headphone jack of your mp3 player, and the other end will plug into the red and white audio input of an open slot on your Pioneer receiver. Then change the mode on your Pioneer receiver to correspond to the input jack that you are using. If you plug the Mp3 player into AUX, change the pioneer mode to AUX, etc.
Jun 20, 2008 | GPX MW3837 MP3 Player
Getting it to play my mp3player
I've tried the same thing trying to get it to work without having to buy the aux adapter for it.
You need to buy 2 items to get your pioneer to work in aux.
1. buy the Pioneer auxiliary input adapter CD-RB10
2. buy a wiring harness that has 2 rca inputs on one end and a male plug to plug into your mp3 player on the other end.
You should be able to find these online or even at any electronic stores that have car audio installation as a service.
Jun 19, 2008 | Pioneer DEH-P7600MP CD Player
Help pleasee
I"LL SUGGEST U FIRST TRY TO FIX THE AUX INPUTS. CONFIRM WHETHER "AUX IN " IS "ON" or "OFF" .PRESS "SRC" SWITCH UNTIL "AUX 1" or "AUX 2" APPEARS ON DISPLAY. SELECT IT "ON".NOW HOPE FULLY THE CD PLAYER SHOULD PLAY.
May 03, 2008 | Pioneer CDX-FM687 6-Disc CD Changer
Using Aux Input in a Pioneer AVH-5700DVD
I'm not sure what aux input you're using - but be advised that if you've plugged your mp4 player directly into the RCAs in the back that won't work - those are outputs, not inputs.
You need to use a Pioneer CD-RB10 (or CD-RB20 if you're running a cd changer, XM tuner, or any other IP-bus component) in order to get an auxiliary input.
If you've done that - you need to go to the initial settings menu and set aux input to 'on'. Instructions are in this link, page 89.
Feb 27, 2008 | Pioneer AVH-5700DVD Car DVD Player
Downloading music from internet to an MP3 player
I guess Sanyo means that have an input jack (line in or aux) where you can connect your mp3 player (after you've downloaded music into it), then hear it on your hi-fi.
Just make sure you connect either the line out or the earphone jack from your mp3 player to the aux or line-in on your hi-fi, then set the hi-fi to play aux or line-in.
Oct 29, 2007 | iLO (2 GB) MP3 Player
Car Audio & Video Logo
29 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
