Question about AudioBahn Car Audio & Video
I have 2 audiobahn 12 inch aw1200eu 700 watts each and i need to know the omes
  • 752 Answers
If each speaker only has ONE negative and positive terminal, then its about 95% likely that they are 4 ohms.
If each has TWO sets, then you will have to m,easure it with a DMM.
Posted on Aug 04, 2008
I NEED SPEACKER BOX SIZE FOR TWO 12" AUDIOBAHN , 1000 WATTS EACH ( DIMENSIONS)
A box using 3/4" MDF will need dimensions of about 14"x15"x32".
Sep 30, 2015 | AudioBahn Car Audio & Video
I have a 12 inch auduobahn 400 watt that is a special edition d jones. what is the best and most efficient way to install it with a jensen 400 watt 2 or4 channel mosfit power amp.
Is it a 2 or 4 channel amp???? Does it have a lpf (low pass filter)??? If its a four channel it prolly wont sound too great. If its a 2 channel you need to bridge sub to amp. Usually its the 2 outside terminals on the amp. Might have a diagram on the bottom of amp
Feb 27, 2012 | AudioBahn Car Audio & Video
I have a 12 inch audiobahn 550 rms 4 ohm coil ported box and a dual box with 12 inch subs they say 550 max wattas a piece thats it waht amp do i need to get atleast 80% of my power in bass
Get a 1200 watt 4 channel amp that's 2 ohm stable. Bridge 2 channels into the single 550W rms audiobahn. Use the other channels for each side of the dual box. Turn the LPF or Low Pass Filter on and vibrate down the road.
Sep 25, 2010 | Car Audio & Video
What is the rms and voicecoil configureation on these the older aw1200
here is all the specs for your sub
12" subwoofer with two 4-ohm voice coils
» carbon composite cone with foam surround
» heavy-duty cast-aluminum basket
» power range: 50-700 RMS watts (350 watts per voice coil)
» peak power: 1400 watts
» frequency response: 20-500 Hz
» sensitivity: 94.65 dB
» mounting depth: 5-5/8"
» sealed box volume: 0.50-1.50 cu. ft.
» ported box volume: 1.30-3.30 cu. ft.
Aug 04, 2009 | AudioBahn AW1200 Car Subwoofer
I HAVE A A2300HCT AUDIOBAHN I WANT TO CONECTED TO 6 12 INCH CROSSFIRE ALL 6 GIVE ME 1 OHM DO YOU THINK I CUOLD LOWER THE AMP TO 1 OHM IF NOT WHATS MY BEST CHOICE
Hello VICENTEMULGA,
According to Audiobahn's specifications, the amp is stable at 1ohm, either with the channels driven separately or in bridged mode. With the channels driven separately, the rated output is 1,200 watts at 1 ohm. In bridged mode, the rated output is 2,400 watts.
You'll need an absolute minimum of 2gauge power and ground, and preferably 1/0gauge and a really good alternator to provide enough current for the beast.
Hope this helps.
May 05, 2009 | AudioBahn A2300HCT Car Audio Amplifier
Wiring subs
audiobahn.com can help you with the free diagrams under tect support
May 03, 2008 | AudioBahn A4075HCQ Car Audio Amplifier
Audiobahn 12' subs and audiobahn amp
First thing is first. What subs do you have? Audiobahn makes several kinds of 12" subs. What model sub do you have?
Without knowing this, it would be hard to recomend an amp without knowing how much power your sub can handle. Audiobahn makes from very power amps that can put out up to 5000W RMS, but if your sub can not handle that power, then you will blow your sub.
Dec 20, 2007 | Car Audio & Video
Baffled
AudioBahn A2401Q Car Audio Amplifier: 100 watts x 2 @ 4 ohms stereo 140 watts x 2 @ 2 ohms stereo 280 watts x 1 @ 4 ohms mono ZT3000 "Beta tester of "0"s and "1's"
Aug 25, 2007 | AudioBahn A2401Q Car Audio Amplifier
Car Audio & Video Logo
75 people viewed this question
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
matthew walsh
Level 1 Expert
Iron
Iron
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
