Question about HP OfficeJet 7140xi All-In-One InkJet Printer
Bad Printhead Message said bad magenta print head. We replaced it but it said the same thing. I pulled it back out and reinserted but still says the same thing. I pulled it and the yellow out, reinserted and now it says the yellow print head is bad and to replace it. What is going on? Help
  • rmvannord Aug 06, 2008
    Ok, we powered off the printer and held the 6 & # keys while powering back on. It no longers says bad magenta and yellow print heads but it still is not printing magenta and it is a new head. We cleaned and aligned the print heads. What do you suggest we do now.
    Ok, We powered off the printer, waited 20 seconds and then powered it back on while holding the 6 & # keys. It is no longer saying bad magenta and yellow printheads. We aligned and cleaned the printheads but the magenta is still not printing and it is a new head. What do you suggest doing now?
  • 3,037 Answers
Have you tried cleaning the contacts on the printer cartridges and printhead
Also try unplugging it, uninstalling the printer and reinstall it and see if it works. If it doesn't, let me know and we can try other options
my best to you
Posted on Aug 06, 2008
  • HP Master
  • 13,433 Answers
Reset the unit.
Note:
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Posted on Aug 05, 2008
  • Ekse Aug 06, 2008
    do you have another magenta cartridge to try?
LCD said "Head Ele. Bad". After reconnecting the printhead, the massage was gone, but now the printer isn't printing anymore, just empty labels with some black points sometimes. Do we need to change the...
The message shows the printer was powered on with printhead disconnected. The print head is bad and needs to be replaced. Make sure power is off during the installation or it could damage the new printhead.
Oct 22, 2013 | Zebra S4M Thermal Label Printer
My HP officejet Pro L7580 doesnot print in black but I can print other colors. What could be the problem. Please help
It's probably a problem with the black/yellow head.
lift the topup to access the heads. if the heads don't move over to the change station area (all the way left as I recall for that unit) press and hold the * until they do.
lift the big blue flap, then the blue handle on the black/yellow head and pull straight up to remove it.
Take a q-tip dampened with bottled water (dampened, not dripping) and clean the CONTACTS area (not the HEAD, just the little round/square copper pads) on the printhead, and disconnect the power from the printer, and clean the printhead contacts in the printer as well.
Without reinserting the head, close up the head access blue flap, and close the printer lid
press and hold the # and the 6 on the keypad. While holding these, reconnect the printer power
wait for a RESET message of some form to appear on the screen, or for the printer to shut back down.
If the printer demands you replace the damaged/missing head, put the printhead back in at that point, but not unless the printer is asking for it!
Once you have released the buttons, turn the printer back on if it shut itself back off.
put the printhead back in when the printer asks for it, if it hasn't already.
The printer will now go through several minutes or whirring and clicking and so forth. Let it.
In the end, it should produce a calibration page.
If the black prints ok, you're done.
If not, you'll heed to replace the black/yellow (K/Y) head.
You can usually get them where you get your ink.
Mar 15, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
Bad print head replace magenta (square) what does his mean. Does this stop all communication with the printer
It means that you need to replace the Magenta printhead which goes for about $35. To see what I mean, go to: www.superwarehouse.com/HP_14_Magenta_Printhead/C4922A/p/55741
Each #14 printhead is made to last about 3-4 years or 30,000 prints. But since this is a 5+ year old printer, you will most likely start to need the other three printhead too, and at $35 each ($140 total), you might as well by a new printer. The current model that replaced this one is the HP OfficeJet 6500, MSRP of $150 and $200 for wireless version. Both can be found on sale for $50 off MSRP.
Feb 09, 2010 | HP OfficeJet 7110 All-In-One Thermal...
My HP Officejet Pro L7780 All-In-One InkJet Printer was jammed with paper. I believe I got it all out and now the display reads" Printhead problem- the following printhead has a problem: magenta/cyan...
There are two possibilities here Joanne, first, it could be a false error message or else second, the Cyan/Magenta print head has gone bad.Try the following:
1. Take the Cyan/Magenta printhead out. Remember, the printhead...not the cartridges.
Clean the copper contacts with a Q Tip, moistened with plain water. Wait till it dries, put the printhead back in.
2. If this does not resolve the issue, unplug the power cord from the back and press and hold the power cord for 30 sec. This will drain all the static charges. Plug it back after a couple of minutes and see if the error message re appears.
Jul 02, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Lcd message "wrong cartridge". I rebooted, replaced an ink cartridge, reseated the print head. What's left?
The wrong cartridge error happens when the printhead goes bad. The only thing to do is replace the printhead.It is QY6-0064-000 for around $40.00
Jun 30, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
HP D145 need new print head (magenta)
You can purchase a magenta printhead from HP's site here. Before you do that make sure it is the printhead - this model uses separate ink and printheads. Are you receiving an error message that the printhead is defective?
regards,
Bob Headrick, MS MVP Printing/Imaging
Nov 05, 2008 | HP Office Equipment & Supplies
HP D135 - replaced printhead - still doesn't print in that color
try this link : I followed the directions and fixed the problem. the instructions that came with the new printhead weren't really complete.
Here's essentially all I did for my fix - Opened the printer top, turned the printer off. Removed the "bad" printhead, cleaned the metal contacts on the printhead and printer with windex. Closed the printer. Turned it on. waited for it to reset. Opened the printer. Turned the printer off again. Installed the printhead. Closed the lid. Plugged the printer in again. When it was ready I accessed the HP toolbox and alligned the printheads and cleaned the printheads. It worked. Here's a link with photos.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa02107&lc=en&cc=ca&dlc=&product=64986
Oct 18, 2008 | HP OfficeJet D135 All-In-One InkJet...
HP Officejet d145 print head problem
Did you replace the PRINTHEAD, or did you replace the INK CARTRIDGE? They are not the same on the D145.
Good chance that you may have replaced the ink cartridge, not the magenta PRINTHEAD which sits under the ink cartridge.
PS - in my experience, non-HP ink cartridges clog up HP printers with separate printhead mechanisms... any possibility here?
Jul 26, 2008 | HP OfficeJet d145 InkJet Printer
Printhead Problems
Since buying the L7780 printer for our business office two years ago, the printer has been a work horse for us. The problems I've seen online about scanning, paper jams and ink cartridge issues have been none existent. Then it was time to change the print head. The L7780 printed several pages before the print head error message appeared and the printer ceased printing. We tried all the solutions offered online including another print head and cartridges but to no avail. We were ready to buy a new printer. Then a member our team whom we dubbed “Service Tech 130” came up with the solution. Service Tech 130 simply pried the chips off both print heads with a screw driver and super glued the old chip onto the new print head. Now the printer has been working as if nothing was every wrong.
For this to work for those of you having the same problem, you would have to be in possession of the old print head that worked prior to the error. Attached is an image showing the location of the chip. Hope this works for you as it did for us.9101d4c.gif
Apr 02, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
HP OfficeJet 7140xi All-In-One InkJet Printer Logo
279 people viewed this question
Seeker5211
Seeker5211
