Question about Samsung LCD-TV LE40S81B 40 in. HD-Ready LCD TV
SAMSUNG LE40S86BDX WONT SWITCH ON JUST CLICKING AND RED STANDBY LIGHT FLASHING
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Samsung Expert
  • 177 Answers
Clicking and not switched on because capacitors on pcb power have damage.
open and change the capacitors can solved your problem.
if any problem after replacing capaditors, let me know . thanks
Posted on Mar 28, 2011
  • 10 more comments
  • pjvv1 May 20, 2011
    I've got the same problem. How do I find out the bad capacitors? Is there any video tutorial to learn how to change those capacitors?
    Thanks!!
  • Basuki Jrobenk
    Basuki Jrobenk May 21, 2011
    hello,
    It's simple... bad capacitors can be seen from the physical form capacitors, usually bubble and almost exploded. read my tips :http://www.fixya.com/support/r8811424-no...
  • pjvv1 May 24, 2011
    Thanks. I've changed the wrong capacitors (there were four as many people have reported on the Internet) but the problem persists.
    The wrong capacitors were in the upper right corner of the pcb. I put 4 new capacitors 1000 uF 16v instead of the old 1000 uF 10v.
    I just changed the wrong capacitors, should I change all of them? Others seem to be right...
    Any ideas?
    Thanks in advance!!
  • Basuki Jrobenk
    Basuki Jrobenk May 25, 2011
    You have do the right change, 1000 uF/ 10V to 1000uF/16V its OK. Voltage behind capacitor value indicate a minimum value of the work ability of the capacitor. More higher value of the capacitor, more evenly and much current stored in the capacitor. Do the replacement with the same value (in Farad), and the value of working voltage is higher than the old capacitors.
  • pjvv1 May 27, 2011
    Thanks Mas Baz,
    I think I did right. I changed the wrong 4 capacitors (1000uF 10v) for a new ones (but 1000uF 16v). Despite that, my TV is not fix yet. Any idea about how to try now? Maybe you already answered my question in your last post but my ba English and muy complete ignorance in electronics did the rest...
  • Basuki Jrobenk
    Basuki Jrobenk May 27, 2011
    hello, I thing you should try it now. But, before you plug it to power source, make sure all soldering area clean. Make sure all capacitors replaced properly (+ or -). I think that s all.
    Try it.
    I tried it but without success. I checked the capacitors were well soldered and the area clean but the problem persists. The same one. I think everything is OK. The soldering seems to be good. Any idea? Should I try to change again the capacitors for a new ones?
  • Basuki Jrobenk
    Basuki Jrobenk May 28, 2011
    Have try to unpluge the T-Con (board on LCD panel) cable connection from PCB ?. If that methode still not working, you should replace PCB Power supply with new one, because that board is complicated.
  • barry simpson Jun 08, 2011
    hi all. i have got a full set of working parts for this tv as i managed to break my screen whilst my tv is only 6 months old. i will sell anyone who wants the parts to sort ther tv out for 70 pounds. what you need is the psu and the board with the eprom which the bad capacitors will have corrupted also the boards that i have for sale will have new and better caps installed before i send the boards out so this wont happen again and also i will sell these boards through ebay so you will have buyer protection and you know it is legit . if you want these then go to ebay and check item number 170649736766 or type in LE40S86BDX on the ebay search and see my listing. mine is the tv with the blue broken screen thanks
  • barry simpson Jun 10, 2011
    hi. did you read my post. if you have had bad capacitors on this then it will have corrupted the eprom on the main board. i have the main board on ebay for just 45 pounds which will solve your problem. its listed under: Samsung lcd LE40S86BD main board bn63-02494a le40s86.
I made it work. I "reset" the TV by pressing the on/off button for half a minute. I tried several times and it works.
I read that in the samsung website.
Posted on May 31, 2011
  • mindo_ab Aug 03, 2011
    Hello, i have the same problem (sound clicking, no power on), after i replaced two 2200uF capacitors, the TV turns on perfectly. After 10 minutes turned on only give me sound, no image. After power off and power on again, i get image and sound for about 5/10 minutes, and then only sound. Thanks on advance
    Mindo
    Portugal
Won't turn. on red standby light changes to on but then goes right back red
TV won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have the Samsung FP-T5084 50" Plasma tv. I went to turn it on the other day, and it wouldn't turn on. No clicking. No red power indicator light. Nothing. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
More results from www.cnet.com
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old. ... I have an old type sony tv with the big back and the red power light keeps flashing and ...
How do you fix a television that won't turn on? - Ask.com
www.ask.com > Technology > Television & Video
Jan 03, 2016 | Televison & Video
My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
Samsung TV Keeps Shutting Down - Forums - CNET
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Dec 25, 2015 | Televison & Video
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
T.v on standby, red light flashing 3 times, wont switch on
Shutdown with a 3x blink pattern occurs if the 12v from the power supply (GF1 or GF2 depending on model) is lost at CN6153/pin 6 to the AU Board Q1224 to Sub Micro IC1205. The suspects, in order of likelihood, are (1) Power supply and (2) the AU board.
Aug 11, 2009 | Sony BRAVIA KDL-40V3000 Television
Red light flashing on samsung le40a stuck in standby mode
hi nick think it may be blown capacitors on your power input board?
Aug 03, 2009 | Televison & Video
Set wont turn on red light just keeps blinking
this is a malfunction of the power supply block (inside your TV-device),or over load of it.please contact the nearest repair shop.
Aug 08, 2008 | Sony Televison & Video
Panasonic th-42pa20 plasma 42 inch tv
Try to replace the Main Power Supply board first.
Dec 29, 2007 | Panasonic TH-42PA20U/P 42 in. Plasma EDTV
Samsung LCD-TV LE40S81B 40 in. HD-Ready LCD TV Logo
1,508 people viewed this question
Jerry Greenberg
Jerry Greenberg
