Question about Amana Heating & Cooling
My amana window unit blew a fuse in my fuse box I replace it now thw window unit won't come on
    Brigadier General:
  • 4,736 Answers
Candy, if the fuse blew in the first place, it was either overloaded or the AC unit has an electrical short in it. However, it may not come on now, without turning the Master Switch on the AC unit OFF and unplugging it from the outlet. Wait 10 minutes before plugging it back in. Then turn the unit ON. If it functions properly then the problem is solved. If not, the circuit board in the unit has been fried and will have to be replaced. Also, be sure that only the AC is plugged in to this receptacle. More than one will overload the fuse/circuit.
Hope this information helped you. Please rate my reply.
Posted on Mar 28, 2011
Why would the Amana AXP22 be kicking fuse?
You have a serious short circuit, I suggest you call for a service technician
May 31, 2018 | Amana Microwave Ovens
Chevy Avalache 2007 blew a fuse while getting a jump, car won't start, rear windows and power locks don't work
You blew more than 1 .
The HUGE MAXI FUSE is probably burned... IF I remember correctly, it is a 80 or 100 Amp
Apr 06, 2013 | 2007 Chevrolet Avalanche LTZ
My husband reversed jumper cables so now my 2002 rav4 starts but won't move out of park and has no radio,back lights power windows etc
Have blown fuses or fusible links or melted
bars under fuse & distribution box-- depending
on what the car has
Mar 13, 2013 | 2002 Toyota RAV4
My central air unit has stopped working. The outdoor fuses were blown and we replaced them but it still wont turn on
If the outdoor fuses blew, it is usually for a reason.. There may be an electrical failure in the unit itself which caused this. Most AC units have fuses in the indoor unit as well, but I would suggest getting a Tech to trace the reason the fuses blew in the first instance. Replacing blown fuses sometimes works but a lot of thime, more damge is caused to the unit. You usually know this when the unit goes "bang" and the fuses blow again when turned on...
Jun 16, 2011 | Amana Heating & Cooling
2004 VW GOlf 4door windows wont open,doors wont lock,trunk wont lock, what can cause this to happen all at once?
All these components operate via the central locking control unit. Check fuses No.4, 37, 6, 3, 14. If these fuses are ok, the control unit may be faulty and need to be replaced. The control unit is located behind the right dash panel.[on right hand drive vehicle , may be else where on left hand drive vehicle.
Jun 05, 2010 | 2004 Volkswagen Golf
Heat worked fine all winter. Turned on A/C and blew a fuse. Replaced 3amp fuse and worked for a few minutes and blew another fuse. Checked all connections, filter, obstructions, need help...
If your blowing fuses then you have something grounded or shorted. By grounded I mean a wire has come loose and is touching the cabinet or a part that allows it to go to ground or your motor, capcitor or compressor is shorted.
Apr 25, 2009 | Heating & Cooling
Do the power windows have a fuse? Where on the fuse box is it
your power windows use reays and cicuit breakers... they will rest themselves after a few seconds, somtimes enabling the window to at least be closed. First I check voltage to switches and motors, tapping lightly on thw motor and making it work is a sure bet you have a bad motor (window motor)
Mar 28, 2009 | 1988 Chevrolet Suburban
Heating & Cooling Logo
61 people viewed this question
Top Amana Heating & Cooling Experts
Bill Long
Pete Norton
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
