Question about E-Machines Computers & Internet
So I have a Emachine t2984 model... It was working perfectly till out of nowhere I heard two beeping sounds coming out the computer then CPU shut completely off. So I went to tried to turn it back on but nothing except for the same two beeping sounds. So I figured it must of been an overheating safety thing it does, which it had never done before. So I unplugged everything and opened it up to let it cool off and realize that the fans were extremely dirty! So i decided to clean the inside of the computer and unplugged the fans and clean them with extremely caution. I finally cleaned the fans and also cleaned the big metal
  • dihome_boy Mar 28, 2011
    Thanks a lot but I have done all this and still no signal being sent from the CPU to the monitor :/... I really think is something tO do with the capacitor/processor that has the fan attached to it... It is the only thing that im being iffi
    ... Because it doesn't feel as stirty as it should when I go to place it on the socket 478 and I don't kneoow why is that :(?
  • E-Machines Master
  • 27,725 Answers
You have done the right thing by cleaning the dust from your computers fans you should continue cleaning the dust from your computer as dust will cause static which can cause a computer lots of unforseen problems
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
test or replace all the leads that attach to your hard drive make sure the connections are secure including electrical extensions + IDE,SATA the ones that attach from your
((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps keep up the good work
Posted on Mar 28, 2011
  • 1 more comment
  • Brian Sullivan
    Brian Sullivan Mar 28, 2011
    Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
    i had similiar problems and found that i needed a new PSU and the leads from my motherboard to hard drive were at fault
    The whole computer works as it turns on and everything ram, sound, cd/DVD, floppy works just now it's not sending the signal to the monitor :/... I also checked that the monitor works fine and it does
  • Brian Sullivan
    leads from ((motherboard to hard drive)) make sure they are securely seated or just replace them how old are they if your computer overheated they would have overheated aswell
I have a EMachine T6534 which won't start. I shut
I agree...sounds like a power supply problem. Typically a bad power supply will not damage the motherboard. It should still be functional.
Sep 02, 2009 | Computers & Internet
Cant boot my emachine 2984
Did you check the CMOS battery and the CPU fan. Those are two things that if aren't working the way they should be, then some computers will not boot up. Try this first then post a response if you still can't get it working.
Sep 01, 2009 | E-Machines eMachines Refurbished EMA...
Emachine ihave no sound
Just Install the Driver of your sound card u ned the Cd driver of your motherboard
Mar 24, 2009 | E-Machines eMachines Refurbished EMA...
2 emachines won't boot
Are you attaching them properly
if so then it is something other then power supply
something has caused both power supplies to blow
have you installed anything in the first emachine you talk about
Jan 17, 2009 | E-Machines eMachines Refurbished EMA...
I have an emachine T2984 that won't boot. No noise of any kind. I had another emachine T2625 that was working. I took the power supply out of the T2984 (that wouldn't boot) and put it in the T2625 and it...
Power supply sounds fine. If the pc won't power up it could be your motherboard. If the pc is powering up and you get a 'no signal' on your monitor it could be your gpu.
Emachine 180
no sounds or beeps rules out the hard drive, at this point it's either the power supply, motherboard, or cpu. Have you tried the power supply in a different machine? Also, eyeball the motherboard, specifically the capacitors, look for any that have bulges on the top.
Jul 16, 2008 | E-Machines eMachines Refurbished EMA...
Emachine T2984 won't power up
First, Check your ram. If not seated, it will not power up. Also, do you hear a series of beeps or not? Need a better & more exact description of problem and what occurs
Apr 14, 2008 | E-Machines eMachines Refurbished EMA...
Upgrade to a new motherboard?
I think there may be another issue.. It could be the power supply.. Have you tried a new one?
Have you installed any additional ram lately?
You can use the old XP software with a new motherboard, but it can be a pain in the **** to set-up if it is the OEM version of Windows, or a Recovery Disk that came with your machine..
What you could do, if you bought another motherboard, find someone with a Genuine Windows XP disk, and use your Product Key to install it..
Apr 12, 2008 | E-Machines eMachines Refurbished EMA...
Where can I get a replacement motherboard for emachine T2984?
Here is a site where you can buy one for a relatively good price....hope it works out.
Mar 12, 2008 | E-Machines eMachines Desktop PC
Emachine t5026, 3 beeps
try a cheep video card from your local used computer parts store they're every where, you'll ask for a pci video card.
Mar 28, 2007 | E-Machines Emachine T5026 power supply **...
Computers & Internet Logo
179 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
