Question about APC (BE500U-WEB) (BE500UWEB) UPS System
BE500R-PH when i switch power on, the buzzer contineously alarm..the a.c voltage dropped at 45 volts a.c when i check the battery,full of charge 12volts d.c what is the common prblem in this unit? please..thanks..rolly..philippines.
    New Friend:
  • 68 Answers
Your battery is half dead already(dead cells). It need battery replacement.
Posted on Mar 28, 2011
  • juirrelle Sep 19, 2011
    hindi sa battery yun, ganyan din publema q. pero may nakuha akong buo na parehong unit, subukan q itrace tapos post q sayu publemang sira.
Replaced Fuel filter and fuel pump on my 2002 Ford Explorer Sport Trac. I have no fuel pressure. The voltage to the pump initially is there when I try to start but drops to 6 volts. What is the issue?
Make sure battery has a full charge and battery connections all good. Use a digital multi meter across battery posts, have helper turn key to crank, how far does the voltage drop? Generally it shouldn't drop below 10 volts, that spec is subjective, but, if the reading drops way down there, I'd check the battery and connections.
You could check voltage at inertia switch. That might give you an idea if the problem is before the inertia switch or after?
Nov 04, 2016 | 2002 Ford Explorer Sport Trac
I hear a continous clicking on my BE500R-PH ups when i turn it on. What seems to be the problem?..Allan...Philippines
Hi I also having the same problem here even replacing new batteries still doesn't give a fix, Im thinking it might be the relay?
Nov 13, 2013 | APC (BE500U-WEB) (BE500UWEB) UPS System
My Dyson DC16 usually shuts down after about 5 to 10 seconds. However, occasionally it will run for 45 seconds to 1 minute before shutting down. It is left on charge permanently. I have checked the...
Your battery is losing voltage too quick. It has probably developed a 'memory'. Dyson claims that their handheld has the best suction out of all the handhelds out there. In order to maintain that claim the circuit board will shut off power to the motor when the voltage drops below adequate charge for full suction.
We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to get a new battery.
Shorting the battery like an Aircraft battery then re-charging won't fix it.
Mar 23, 2011 | Dyson DC16 Root 6 Bagless Handheld...
My nokia 3110 dead not power
FIRST CHANGE UR BATTERY WITH FULL VOLTAGE
VOLTAGE 3.60 - 4.20V.
CHK BATTERY CONNECTOR
IF IT DESOLD
SO SOLD{RESOLD}IT
CHK SHORTING ON BATTERY CONNECTOR ON BUZZER RANGE IN MULTIMETER
CHECK CHARGING IN UR CELL
CHK ON OFF SWITCH VOLTSGE 2.80V
CHK ON SOFTWARE OR FLASH UR PHONE
SAME IT DEAD
SOIT HARDWARE FAULT
CHK ALL POWER SUPPLY
IDRISH 911
Oct 30, 2010 | Nokia 3110 Cellular Phone
My aims 2000 pure sine wave inverter is pluged to 2 240amp/h 6 volt batteries. When | plug in a 1800 watt hairdrier i get an alarm as if the batt. were to low. they are new and at full charge. is the load...
Your inverter has a peak of 3000 watts rating and should power that hair dryer. Make sure your batteries are in good shape. The inverter can only put out what it takes in. 1800 watt demand on the inverter requires 1800 watts from the batteries.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 14, 2009 | Inverter Aims Pure Sine Wave Power...
Low power to ignation switch
Check battery voltage with a volt meter. Voltage at ignition switch should match that of battery less 1% due to built in loss at connections and wire resistance. If not, check connections on the way to the switch, beginning at the battery to see where power drops off. Check all grounds as well.
Jun 02, 2009 | 1999 Jeep Cherokee
Upon power up, 3 red LEDs flashing rapidly continously, no power.
The control systems on power mobility equipment have a "prevent" circuit that immobilizes the equipment while it is plugged into a charger, so folks won't take off with it plugged into the wall outlet. When you turn it on when plugged into a charger, the display will flash constantly, or sweep constantly, depending on the manufacturer. This is normal. Your off-board charger should have a red light to indicate power to the charger, and another light for the charge status. Yellowish means it is charging, when it turns green, you are fully charged. If the status light is green all the time, that is an indication that the charger is not functioning properly, or that the batteries are below a chargeable state. Check charger output, which should be 26-28 volts dc, and each battery should show at least a 12 volt reading, but around 13.5 volts with a full charge. If one or both of the batteries drops below 12 volts after a short period of time, it's time for a fresh pair. Fully charge new ones before using the chair.
May 31, 2009 | Pride New Jazzy 600 Power Wheelchair by...
APC (BE500U-WEB) (BE500UWEB) UPS System Logo
316 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
