When i try tot print, the display says: printing the document, the green light goes on and off, the only thing i get is a papper with: lUnidrv 0.3.6000.16386 @PJL COMMENT "Username 457645; App Filename: Microso" Nothing more. Any solutions?
    New Friend:
  • 68 Answers
Turn off the printer (unplug if it won't turn off using the power button), restart your computer thern turn on the printer, try printing your document again.
Posted on Mar 28, 2011
HP LaserJet 4L quit working It's connected to my PC and it's on. All 4 lights are on; 2 green and 2 orange. When I try to print, the paper goes through but nothing is printed on the paper.
Empty cartridge maybe?
Otherwise it's simple: selt-test page(by printer button) printed ok - it's outer problem. Self-page is blank - it's inner problem. And so on... use Golden Section method
Jan 10, 2014 | HP LaserJet 4L Printer
I only copy black & white documents.Have changed 2 B & W inks.Never print a color things. Today after change a new B&W ink / the blinking light "color" check appeared.The machine...
That is an indication of regular functionality from device. Red on device is indication of power on cables ready to capture prints. Usually with devices that has several lightening indication displays, a yellow would be ready to produce print request where finally green is indication that print asignment has been attained succesfully. once a new ink was installed, attempt to print documents to ascertain the status to devcies.
Feb 17, 2011 | Canon PIXMA MX310 All-In-One Printer
Printer won't print documents. Green light on
Hmmm, try feeding a sheet of paper into the manual feed slot... you might have inadvertantly sent a Manual feed job, and the printer is waiting for a sheet to be fed by you.
Feb 10, 2010 | Dell 1710n Laser Printer
After every page I print, the green light goes out, and I have to press online to get it to continue printing.
Thats ..paper size mismatch, check the paper size settings of your printer in printer properties is the same as what document or document program is set to under page size of the document you wish to print, if these dont match the printer goes offline so you can put in what it's been told is the right size paper or press online to force it to print regardless...so in your case check paper size in both locations and you should be right, there are other things but 99% of the time..thats ya baby;)
Cheers
Nov 15, 2009 | OKI B4600 Printer
HP LaserJet 4 Printer stopped printing
Try putting a piece of paper in tray 1
Feb 26, 2009 | HP LaserJet 4 plus Printer
TLP2844 won't print
Hi David,
Default the printer so you have a green light.
Print a configuration label so you have the printer's settings.
Check the document you are trying to print.
If your "normal document" is using PCL, it won't print because you aren't speaking the printer's language.
Make sure you are using a Zebra driver and that the label/media settings match your printer. Look at your direct thermal/thermal transfer setting and your media length setting -- especially continuous vs. non-continuous.
Sep 21, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Green ready light on, but will not print
When you refilled the paper, did you load a different size paper? Try this: on your PC, left click on START, then left click on CONTROL PANEL. Next, left click on PRINTERS. Find your BROTHER on the printers page and view the status box. Does it show READY? Are there any DOCUMENTS pending? Left click (you may have to click twice)on the BROTHER icon. The PRINT QUEUE appear, showing any documents waiting to be printed, and their status. If anything is in the queue, cancel all documents so the queue is clear. Next, RIGHT CLICK on the BROTHER icon . On the drop down menu,left click on PRINTING PREFERENCES. Make sure the settings match the paper you have loaded in your machine. If something is not right (Paper size, orientation,etc) the machine will not print. Carefully check all the settings and correct as necessary. To test, first click OK to exit PRINTING PREFERENCES. On the same menu, left click on PROPERTIES. On the GENERAL tab, left click on TEST PAGE button to generate a test print.
Aug 09, 2008 | Brother HL-2040 Laser Printer
The top lights stays blinking and printer will not print
Yes definetly,
First cheak that paper was cuts wrincled from any side from top or bottom, after pulling if yes cheak that the
small part of papper jam in to the papper path or sensor earia
or papper feed out sensor actuater arm jam by pulling the papper by you after cheaking those things you will able to solve the problem you are facing,
vyas
Mar 23, 2008 | HP DeskJet 5550 InkJet Printer
k24674
jasbo
jasbo
