Question about D-Link DP 301U (DP-301U) Print Server
D-Link DP-301U Problem
Good Day
I have a problem with this print server, If i add this print server on the network with a static address to the printer the USB port on the print server does not pickup the printer but only if i reset the print server to it's default settings and address it picks up the printer and only on the default address.
Please can someone give me some advice how to solve this problem.
  • 1 more comment
  • ITnet Aug 04, 2008
    Well what if done is i gave it a static address, i updated it's firmware i ticked the PJL Printer block.
  • ITnet Aug 05, 2008
    Wel the network is on a 192.168.2 range and this is the only network printer an dthe ip i gave him is 192.168.2.250.
    No this is a normal network print server.
    The PJL Printer block is on the Configuration page of the Print servers web page.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Whats the settings your are giving it and what is the default settings it is using?
The print server is not compatible with your printer. check Dlink's website for the print server compatibility...
http://support.dlink.com/faq/view.asp?prod_id=2135&question=DP-300U%20/%20DP-301P+%20/%20DP-301U%20/%20DP-311U%20/%20DP-G310%20/%20DP-G321
Posted on May 27, 2009
I cannot get my ip address after i press the reset button at the print server DP-301U. How can i get?
Posted on Oct 30, 2008
  • 2,794 Answers
It should be fine as long as it is in the range that the router can recognize and that it doesn't conflict with another IP address used on another device. Usually on the networks I design I keep the printers on higher IP address so that they can be managed on a certain range.
Is this the wireless print server?
What specifically do you mean by PJL printer block?
Posted on Aug 04, 2008
1.my dp-301u print server is in net A and it works well; 2.i just have an other net B ,it joins net A by a route ; 3.users in net B can connect to other server in net A but they can't connect the print...
Port 80 may be open behind the router to network B, but the ports used for printing may not. See if the router is blocking any ports and disable this feature for printing ports or all ports if possible.
Alternatively, try setting up a virtual server on the bridging router that points to the static ip address of your printer on network A.
Hope this helps. -Daniel
Jan 26, 2011 | D-Link DP 301U (DP-301U) Print Server
I have installed the DP-301U print server on my home network to print to an HP Laserjet 4050. When setting up the print server per instruction, I set my computer IP address to a static IP address. The...
Your print server has to have its own IP address. If you have your computer as 198.168.1.1 then your print server would be 198.168.1.2.
You cant have the same IP address on any 2 items on your network.
Oct 20, 2009 | D-Link DP 301U (DP-301U) Print Server
D-link 301u using windows vista
Primary solution is to enable all print services in Vista and XP. This is done through the control panel under Programs and Features or Add / Remove Programs. Enabled ALL print services, which is needed for LPR support.
Jul 29, 2009 | D-Link DP 301U (DP-301U) Print Server
HP LJ P1008 can be used as network printer ?
I have one of theses D-Link PD-301U. It does NOT support a printer like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1008 is NOT in the list):
LaserJet
  • 1200
  • 1500 (USB 2.0)
  • 2200
  • 2200D
  • http://support.dlink.com/faq/view.asp?prod_id=2135&question=DP-300U%20/%20DP-301P+%20/%20DP-301U%20/%20DP-311U%20/%20DP-G310%20/%20DP-G321
    Feb 10, 2009 | D-Link DP 301U (DP-301U) Print Server
    Browser Setup Access address for DLink DP-301U Print Server
    It's in the quick installation guide, which is freely downloadable from their web site. Top of page #3...
    "The factory default IP address of the DP-301U is 192.168.0.10."
    Dec 18, 2008 | D-Link DP 301U (DP-301U) Print Server
    Setting up IP address on server
    Download and install <a href="http://www.wireshark.org/download.html">Wireshark</a>.
    After installing, click the first button on the toolbar to list available capture devices. Select the interface you use to connect to your network (wired or wireless card) by clicking the "Start" button next to it.
    Power off and back on the print server. Watch the log on Wireshark, and look for the D-Link identifier under the "Source" tab. In the same row, it will tell you the IP address the print server has assigned to it. You can then change your computer's IP to be in the same subnet (match the xxx's in the address xxx.xxx.xxx.yyy), allowing you to connect to it.
    Oct 30, 2008 | D-Link DP 301U (DP-301U) Print Server
    DP 301U and Lexmark 2550 (all-in-one)
    1. Set up your print server with an IP address.
    2. Ping your printer IP address.
    3. If successful, Add printer wizard. Create a new port, Make it TCP/IP port. Put the IP address in the IP address field. Click next and Use Generic 9XXX Raw.
    4. Install the driver provided by the manufacturer for your printer and assign it to the Network port.
    5. Print.
    Hope this helps.
    Jun 03, 2008 | D-Link DP 301U (DP-301U) Print Server
    D-LINK DP301U
    TCP/IP printing for windows xp:
    you must know the IP address of the print server and the port name.and the pc's ip address must be in the same subnet as the print sever's ip address.
    Step 1 Go to Start > Settings > Printers and double-click the Add Printer icon to open the Add Printer Wizard.
    Step 2 Select Local Printer and click Next.
    Step 3 Select Create a New Port and choose Standard TCP/IP Port from the drop-down menu and click Next.
    Step 4 This will bring up the Add Standard TCP/IP Printer Port Wizard. Click Next.
    Step 5 Enter the IP address of the print server and the port name and click Next.
    Step 6 The next window will prompt you for the Device Type. Select the Standard radio button and use Generic Network Card from the drop-down window.
    Step 7 Click Finish to close the port configuration wizard.
    Step 8 This will bring you back to the Add Printer Wizard. Step through the remaining windows of the Add Printer Wizard, accepting the default values to complete configuration.
    May 29, 2008 | D-Link DP 301U (DP-301U) Print Server
    Unknown address
    Install Network Manager in your and install . When you install this software then you go to networkingmap there you will get ipaddress of your print server
    Apr 18, 2008 | D-Link DP 301U (DP-301U) Print Server
    Documents not printing
    Hi How to check the print server is in the wireless network or not!! Check under the Router Setup page Router's ip address... Check if you are able to ping the Print Server Ip address....Since it the router will assign a ip address from DHCP range.. If you are able to ping the router's ip address and the print server ip address then the print server is in the Wireless LAN... Try the following steps. 1. Go to run and type "cmd" press enter 2. type ipconfig. 3. Check the range of ip address...if its 192.168.0.XX 4. Try pinging that ip address.. 5. If able to ping the router and print server.. Then the wireless network is fine... Somehow some of the printer's don't work with some of the print servers.. Check if D-link does support the printer or not!!!! for this particular model of the router...
    May 30, 2007 | D-Link DP 301U (DP-301U) Print Server
    D-Link DP 301U (DP-301U) Print Server Logo
    1,384 people viewed this question
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
