Question about Ricoh Office Equipment & Supplies
Aficio SP 4100N SC 541 Error
Our Ricoh Aficio SP 4100N printer is having SC 541 error. Can you please help?
4 Suggested Answers
  • 37 Answers
SOURCE: Service Call SC 553 on Ricoh Aficio SP C811DN Printer.
No.
Type
Details (Symptom, Possible Cause, Troubleshooting Procedures)
553
A
Heating roller overheat (software error)
The detected heating roller temperature stays at 230°C or more for 1 second.
• Defective PSU
• Defective lOB
• Defective EGB
Related SC code: SC 543
1. Replace the PSU.
2. Replace the lOB.
3. Replace the EGB.
This is the simptoms of the service manual , you should check that your power output is stable and double check if there is not anything like paper stuck some were in the fuzing unit wich could also cause the fuzer to over heat
Posted on Nov 16, 2007
  • 7 Answers
SOURCE: how i reset error sc 546 on ricoh aficio 4100n
Turn the machine off, hold down online & escape, turn machine on and wait for "1.Service Menu"
Select service menu, find sp 5-810, select #/enter, when it says "execute select #/enter, then escape. Turn machine off then on.
Posted on Oct 24, 2009
SOURCE: I Cannot solve SC541 Error in RICOH Aficio 270
It's not the PCU (photoCONDUCTOR unit), It's either a thermistor or blown out heater lamp in the fuser. Call a tech. The code can only be reset in service mode
Posted on Aug 12, 2010
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
Service call sc541
change the fusing thermister
thanks
Nov 26, 2015 | Ricoh Aficio SP 3510SF
Fix sc 545 RICOH Aficio SP 4100N PCL
Do a fuser reset.
SP5810 in service mode. Reboot machine.
If that did not work, replace fuser.
May 29, 2015 | Ricoh Aficio SP 4100N Laser Printer
Error sc 541
This is a fuser error. I found the following solution here on Fixya and it seems to have helped.
"Hold down both of the arrow keys for 10 seconds, then press enter. Select 2 for engine, ok, select 7 for data log, ok, scroll to 7807 and execute. exit all of the way out until you get back to engine, then select 3 for end. Recycle power."
Sep 02, 2012 | Ricoh Aficio SP C311N Color Laser Printer
Ricoh Aficio SP 4100N SC 590 power off on
YOU DONT FOLLOW INSTRUCTIONS VERY WELL,,DO YOU???!!! CALL SERVICE PROVIDER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Aug 13, 2012 | Ricoh Aficio SP 4100N Laser Printer
Sc 541 power off on
sc 541 is a fuser error. you have to reset the code. here are the steps to follow.
press clear mode button once, clear mode button is the yellow one
press 107
press and hold clear/stop red button until you see the screen changes to copy sp mode written.
press copy sp on the screen and off and on the machine
it should reset the code.
Oct 26, 2010 | Ricoh Aficio 1035 Copier
What SC 541 is ?
sc 541 is a fuser error code. try these steps
press clear mode once
press 107
press clear/stop and hold it untill your screen changes to copy sp mode.
press copy sp on screen
off and on the machine. it shud reset its code. i am a Ricoh tech. email me if you are having difficulty. ronils_singh@yahoo.com.au
Oct 01, 2010 | Ricoh Aficio 450 Copier
How i reset error sc 546 on ricoh aficio 4100n
Oct 24, 2009 | Ricoh Aficio SP 4110N Laser Printer -...
Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Jan 17, 2009 | Ricoh Office Equipment & Supplies
Error Code SC 541
Its a fuser code. Hold down both of the arrow keys for 10 seconds, then press enter. Select 2 for engine, ok, select 7 for data log, ok, scroll to 7807 and execute. exit all of the way out until you get back to engine, then select 3 for end. Recycle power.
Apr 01, 2008 | Ricoh Aficio AP600N Laser Printer
1,070 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
