Question about Intel SERVER CHASSIS SC5299BRP Pedestal Chassis with 650-watt 1+1 hot-swap redundant PFC
Having a problem powering a Intel server which has a SC5299BRP chasis with 1+1 power supply. One of the power supply failed and we replaced with a new one. But still one evening the server switched off and could not bring it back online. The front LED with a exclamation mark is blinking green. Please advise how to fix.
map9966
  • 2351 Answers
SOURCE: Intel D865PERLL Motherboard will not power up
Hi nkda2000, this is as close as I could find for power schematics. Intel D865PERL
http://support.intel.com/support/motherboards/desktop/D865PERL/sb/CS-027143.htm
(There is no Intel D865PERLL board). Sure it's a typo. Have done searches for D865PERLL & found it (Not on Intle's web site) but when looking at the specs it's listed as D865PERL. (One L ) not two.
I hope the Technical Product Specification pdf can help you check the power on the motherboard.
Luck!
Mike
Posted on May 08, 2008
  • 11 Answers
SOURCE: Help needed with Intel server KB3HSRP
http://intel-driver.driveray.com/intel-brand/r_16_1.shtml
Posted on Oct 10, 2008
bilua
  • 102 Answers
SOURCE: PC will not turn on blinking green light on power
The green light on power is blinking, it means power supply working in main power and the main supply not constant that time after constant the green light, then turn on the PC.
Thanks
Posted on Aug 15, 2009
  • 39 Answers
SOURCE: MY Intel mother board D845WN can't boot
Try swapping those three connector plugs around from the front panel led lights to the other pins on the 9 pins connector, 5 in a row and 4 pins at the bottom. The bigger plug with 3 holes but only two wire will definitely go on the 5 pins row.
sirjohn
Posted on Nov 01, 2009
darkpain
  • 316 Answers
SOURCE: Internal LED comes on, computer will not turn on
Check your cables if are ok,especially the ones in panel or try to reassembly them like that
http://www.intel.com/support/motherboards/desktop/sb/cs-009016.htm
Posted on Jan 12, 2010
Will not come on it worked fine earlier.
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
May 17, 2011 | Sanyo DP42849 42 in. HDTV
We have a Pehlm-Sloane PS-1500 server in our medical office. The power supply is no longer working. We cannot nail down a replacement power supply. The original one was an EDAC EA-11603. Although they are...
See International Power Supply's catalog. It's exhaustive and well written, even it it does take 30 minutes of your life.... Alternately or simultaneously of course you can get the old supply to an electronics repair shop, having taken pictures of it (and connections in particular) next to a 10 cm. ruler with your cellphone or DSLR or whatever's handy. Not Pelham, eh?
Mar 12, 2011 | Pelham Sloane PS1500 PC Desktop
How do i reset the power supply on my poweredge 2600?
Resetting the power supplies isn't necessary. Once one of the ptwo power supplies fails, the second power supply automatically takes over. Also, there isn't a need to power down the system to change the supplies as long as you change them one at a time.
Oct 12, 2010 | Dell PowerEdge 2600 Server
I have a problem with Intel server board se7501br2: when boot, it msg error: "Error: A voltage limit threshold has been exceedeed". F1->continue, F2->Setup Please help me fix it! TKS all! (sorry my...
The power-supply is producing several different voltages.
However, one of the voltages that it is producing is *NOT* within the "normal" range of voltages, and so you get the error-message.
Replace the power-supply.
Dec 27, 2009 | Intel Server Board SE7501BR2 Motherboard
Intel Desktop Board D945GNTLKR did not boot
Try choosing the 'Exit Without Saving' option in the BIOS menu. If this kicks you to the boot media search, then 99.99% the BIOS is corupt. If not, try to replace the CPU cooler (don't forget to apply the thermal grease).
Mar 15, 2009 | Intel Computers & Internet
L440Gx server board do not boot
1: Check wether the on/off button on your power supply is turned to on.
2: Check your cables. Try switching with those from other pc's.
3: Check wether all the connections from power supply to the mainboard/ram/video/harddisk are OK.
Hope this helps,
Yannick
Feb 18, 2009 | Intel Server Board L440GX (KMS440GXTPAK10)...
Windows fail to boot
How much power is the power supply? Could be the power supply not having enough power for your rig.
Sep 23, 2008 | ASUS P5QC Motherboard - Intel P45, Socket...
RCA hd50lpw42yx2 not working
There are 4 1000 mf. 35 V caps. on the AC IN pwb. (power supply) that are chronic fail items. After back is off, slide the chasis on the left side back toward you. Slide about 1/2 inch and it will lift out of track and then the chasis will be more accessible. The said caps are the tallest on the bd. and 2 are located side by side on the bottom front of the chassis. The other two are side by side about an 1 1/2 above the other 2. Most likely the top of the caps are pooched out. Replace all 4 whether they look bad or not. Problem solved
Jan 23, 2008 | RCA HD50LPW42 50" Rear Projection HDTV
Intel SERVER CHASSIS SC5299BRP Pedestal  Chassis with 650-watt 1+1 hot-swap redundant PFC  Logo
125 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
