Question about BLACKOUT LABS Ringtone Designer Free
Sorry...this song cannot be made into a ringtone and it does this to EVERY SONG
Nokia 300 seting song as ringtone
go to your file explorer find the song you want to set as ringtone then go to options >> use tone>> set as ringtone..
Oct 03, 2012 | Nokia 300 Touch and Type
Tip
How to create a ringtone for iphone
You'll need - Audio song, a song editor, iTunesFollowing are the steps needed to follow:
  1. Select any song
  2. open that song in the song editor and extract the part you want to create as ringtone
  3. Save the clip, export it as format - M4A (i.e. m4a format) - say myringtone.m4a
  4. goto the clip in your file system, change the extension to m4r, i.e. myringtone.m4r
  5. double click the file, it should automatically get added to ringtones under your iTunes installation.
  6. Enjoy!!
Restrictions: clip can be up to 40secs in length.
on Jun 18, 2010 | Apple iPhone Smartphone
How do I use one of my songs as my ringtone ? Please help !
  1. Open iTunes.
  2. Find the song that you want to make into a ringtone.
  3. Listen to the song and find the part of it you want to use. The chorus may be a good place to start.
  4. Write down the start and stop times of the clip.
  5. Right-click the song and select "Get Info."
  6. Click the "Options" tab.
  7. Type in the start time of your ringtone in the text box next to "Start Time" in the minutes:seconds (i.e., 2:01) format.
  8. Type in the end time of your ringtone in the text box next to "Stop Time." Make sure the ringtone is no more than 40 seconds long.
  9. Click "OK."
  10. Right-click your song again and select "Convert Selection to AAC." Wait for iTunes to convert your song. It will create a duplicate version.
  11. Right-click the ringtone and select "Delete."
Jan 15, 2011 | Apple iPhone 3G
Can i make a ringtone from a song on the phone
yes you can just go to gallery and choose a song that you wanted to be as a ringtone there then click options then there would be a option there to " set this as a ringtone "...click ok then the ringtone should be the song that you choose
Apr 05, 2010 | Cell Phones
I cannot set songs for ringtones
no, you can't set song's as ringtones, if they were recorded..
Feb 09, 2010 | LG Neon GT365 Cell Phone
Hoo i put a downloaded song as my ringtone.
don't know about your phone because you don't give me the name of your mobile phone but in lot of mobiles ringtone option is in the settings & then audio settings or simply click on the song options there is one option use as a ringtone... prefer your way to set downloaded as a ringtone
thankyou
rate it
Jan 08, 2010 | Cell Phones
Ring tones
To change ringtones, go to Settings, phone profiles, highlight the profile you are using, choose options, then edit, the screen will show the settings for incoming calls, here you can scroll down and change the call ringtones, highlight voice call ringtones, press options,choose change, this takaes you to My files folders, go to the folder you keep your tunes in and highlight the song you wish to use. press options, then select. Press options again and then save.To change text tones, you do the same, but once in the screen to show settings for incoming calls, you must scroll right to show the new message screen, then you can choose the song you wanat in the same way as for calls. remember to save tho.
Jan 09, 2009 | Samsung SGH-F400 Cellular Phone
G1 Tone Problems
Like most (if not all) phones. when setting a ringtone you can only select the song you want ! the only way to have a certain part of a song as your ringtone would be to use Audio editing software on a PC and then crop the song how you want. enabling you to have a ringtone of a certain part of the song.
hope this helps
Greenie UK
Oct 26, 2008 | HTC G1
Memory crd
ring settings select memory card data an select the song
dont forget to rate me
Aug 16, 2008 | Palm Treo 650 Handheld
Not able to set my fav song as ring tone
If you convert the song to mp3 format, you can set it as a ringtone.
Mar 29, 2008 | Pantech Duo Smartphone
BLACKOUT LABS Ringtone Designer Free Logo
235 people viewed this question
Top BLACKOUT LABS Apps Experts
Bill Boyd
ray gallant
Are you a BLACKOUT LABS App Expert? Answer questions, earn points and help others
