Question about Samsung NV10 Digital Camera
Problem with camera
Hello there i have samsung nv10 and all worked fine but now the zoom wont come out it beeps 4 times then shuts off
  • Joanne Zahler Sep 11, 2008
    I've got the same problem. It beeps and then shuts off without the lens coming out. Did you find a solution??
    Email:pixie1115@gmail.com
    Joanne
The lens is sticking, I had same problem, thought it was the battery. It kept doing 4 beeps and turning off, but the lens would be out.
Lightly lube the lens area with WD 40 worked, be real careful and don't use alot of it. My camera works fine now. I actually read the solution someone on this site, can't find it now, but wanted to post that it worked for me. I love the camera and was bummed it wasn't working. Works great now!
Posted on Nov 19, 2009
Samsung nv10 digital camera, the lense is stuck in zoom position. if i turn on my camer i cant get it to close and then it shuts off
Hi! As a first course of action please remove the battery and press hold the power button for 10secs. while the battery is removed. Install the batter, turn it on and see how it goes.
Oct 07, 2010 | Samsung NV10 Digital Camera
Zoomes lense wont come back in and the camera beeps 3 times and shuts off when you try to turn it on.
I would check the batteries and also try to reset the camera.
If that doesn't work, the camera needs to be sent back to Samsung.com for repairs.
http://www.samsung.com/us/support/online/supportOnlineServiceRequest.do
Aug 17, 2010 | Samsung SL620 Digital Camera
Digital camera starts then shuts down
yeah its broken sorry mate
suggest a new camera
Dec 15, 2008 | Cameras
Lens is stuck open - will not close. still takes pictures
you must have dropped your camera where it caused damage in internal part. when cameras are dropped wires and screws inside loosen which will cause trouble. Have it checked by a pro. you might destroy it more if you try to fix it yourself. Thanks.
Nov 24, 2008 | Samsung NV10 Digital Camera
Samsung NV10 heeelp!Pleeease
Not sure about the battery... that could be it and I haven't tried switching it out for a new one yet, but in the meantime I am getting around this problem my grabbing the lens with my fingers and "helping" come all the way out... just give it a little pull, a little encouragement and it will come all the way out... but the trick is that you have to do it right after you try to turn it on and before you get the beeps...
So if your lens is stuck out right now and the camera is powered off, then turn the camera on and then pull the lens out before you get the beeps... once you give it a little tug, the mechanics should take over and it will extend all the way... the LCD will come on and you'll be good to go...
Like I said, I'm having this problem too and my girlfriend suggested we change the battery... I guess that's possible, that the battery is not holding enough of a charge to push the lens all the way out... I'll investigate how much a new battery costs and then determine if I think its worth a try...
Jul 10, 2008 | Samsung NV10 Digital Camera
The lens is jammed.
This is a result of damage to the gear in the motor asssembly.
The gear teeth have been broken off & as a result the gears that drive the opening& closing of the barrel dont mesh together resulting in the jam and your 4 beeps!!
Jan 24, 2008 | Samsung NV10 Digital Camera
Samsung NV10 - 4 bleeps on switching on then turns off
my camera started doing the same exact thing, did you ever get an answer?
Jan 20, 2008 | Samsung NV10 Digital Camera
Samsung NV10 Digital Camera Logo
286 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
