1997 toyota 2.7 petrol hilux.Radio absolutely fine.3 stack CD changer not working,comes up with ERR1 message,does this mean a new cd player or can it be fixed
  • 56 Answers
Hello, it sounds like the laser is faulty in the cd. These can be fixed and shouldnt cost too much. After a while, and sometimes straight away, the lasers go as they are the weakest part of the system. Your technician should have no trouble in getting the parts and repairing it as good as new. Good luck.
Posted on Mar 28, 2011
2002 isuzu rodeo 6 cd player has err1 code on it when i put the discs in it. What does that mean?
Go to Best Buy and purchase a CD disc cleaner to clean the photo I inside of the changer
Jan 29, 2015 | 2002 Isuzu Rodeo
Bmw x5 cd changer no disc
absolutely no idea ,do you have anything else plugged in that could cause the sound cut off although you say the radio works?or has a plug come loose in the back of the radio ,you could try one of them radio fitting centres as you never know some young lad comes out presses a button and it all works as you had the mute on or something but the radio works ,is it a built in cd player or a remote unit ? in my time a 8 track was the in thing these modern things are welll beyond your ancient dinasaur here .
Jan 30, 2014 | Cars & Trucks
Cd player error
so is this a stock RAD/cd?
stock JBL 6 disk player in dash>? or? what? name and model #
mp3 and wma format. but not DVD
or
JBL premium 4-disc in-dash CD changer
io the single disc player, 3 kinds sold. new.
and now comes the big question.
TELLS where you got the disk, or name it, or tell how it was made if home made. we dont know that.
is said CD a CDDA? or not. (always try CDDA first)
is CD a real music disc. from a real store, CDDA, is that.
or CDR, or DVDr, or CDRW, or other record-able media
is music MP3? files.
see, the old units dont play modern media.
try 2 real discs, not scratched.
do they play?
one other way, is to name the radio, brand, like JBL then get the
p/n off it. (hard) then look up the product data sheet on it,
bingo, what it can and can not do is there.
but this does it all, mostly
does what yours will not do.
http://www.flyaudio.net/product_id.asp?id=113
Jan 02, 2014 | 2007 Toyota Camry
6 stack CD Player in Auto
The CD player died. Probably the magazine (the thing that holds the cd's) isn't functioning properly, crooked inside the radio. Needs the radio repaired or replaced.
Apr 21, 2013 | 2005 Chevrolet Chevrolet Malibu MAXX LS
Err 1 message on cd player 2003 toyota corolla
I thnk it's Lens is not working or damaged..
Mar 05, 2012 | 2003 Toyota Corolla
How do you work the cd changer
Very easy, open the trunk, slide the door on the CD changer open and press the little black button that dispenses the cd stack. That's it, press the little white release lever on the CD stack to let the CD's come out and make sure to put the new CD's in the same way they came out (FACE UP OR DOWN).
Oct 16, 2009 | 1995 Toyota Camry
The CD player and the CD changer don't work in my 2001 A6. I get the message CD ERR 1. Can you tell me what the error message means? I bought the car used, and never got any manuals. I also have a...
Is there a CD inside the CD player? You could try pulling the fuse for the radio (look at the fuse box panel for the exact fuse) and leave it out for 10 secs, then turn the car to the on position and leave for 20-30 secs.. turn the car off and put the fuse back in and then turn the car on and if you;re lucky, the radio will reset... This works for Volkswagens and since Audi is the same company, it should work
Aug 16, 2009 | 2001 Audi A6
1993 Toyota Vienta Ultima, ''Fujitsu Ten'' INF4 fault
i had the same proble. i happened to remove the changer from the boot for a few days and have a look inside but did not see anything wrong and when i put it back in it worked.
i expect it is as simple as disconnecting the changer from the head unit, turn the head unit on and off and then reconnect the changer resets the connection between the two.
Jul 31, 2009 | Car Audio & Video
6 disk CD changer is broken!
Hello, I just removed the 6-disc player from my 2001 Trooper. To remove it: 1) Remove the two screws above the radio area in the black faceplate 2) Remove the one screw located between the ash tray and the lighter. 3) Remove the four screws (two on each side) from the front center console cover and pull it back (you will need to shift into 2 or L) 4) Pop the black face plate off (there are some metal brackets holding it on that need some light force to pull out. Nothing should break) 5) There are two screws for the CD player and two screws for the radio. Unscrewing them will allow you to pull out the radio and disconnect the smaller CD wiring harness, then you can pull out the CD player.
When I unscrewed the CD player unit, I found that there are six plastic halos that hold each disc and move them up and down as selected. These had broken in some places and the discs had dropped to the bottom and stacked, so nothing could move...hence the clicking sound. Because there was a severe jam, nothing else could be loaded either...hence the error message. I'm attempting to superglue the pieces back together to see if I can reset it. Otherwise, I'd recommend you replace the unit (most likely what I'll do).
Hope this helps!
Ryan
Nov 08, 2008 | 2000 Isuzu Trooper
 Grubhead
Grubhead
