Question about Hitachi Deskstar 7K500 500 GB Hard Drive
When we r formating that HDD its coming This Disk May Be Damaged
  • Hitachi Master
  • 27,725 Answers
Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
hope this helps
Posted on Mar 28, 2011
My hp mini 2140 laptop says non disk or disk error hoe do I fix it
You must try to format it with a disk installer (windows cd).. During the process of formatting it will show the HDD is exit or not. If it not exist means the HDD is physically damaged. Or you will be ask for the partition to install windows on it
Jan 19, 2017 | HP Computers & Internet
I need format my hd
You can't format the HDD, or you don't have a operating system. You need a windows disk, recovery disk, or contact the MFG with your serial and see if they will send you a system disk or recovery and the windows serial.
Second, you don't format from NTFS to NTFS to clean a HDD, you use software like active killdisk, or one from the MFG of the HDD, WD has a tool cd, so do most.
Apr 09, 2013 | Gateway T-6836 Notebook
Sir/madam My toshiba HDD2189 si damage. I cannot check the HDD. I was see error message in computer. When I format now, computer error message was said "your HDD is damage". so, I not format yet...
The disk is damaged at a hardware level - something inside it is broken. This cannot be repaired, the disk is dead and the data on it is lost.
Feb 08, 2011 | Computers & Internet
Error occured while formating my 40g seagate hard disk..
your hard disk might have got damaged.
try installing on other hard disk and see the difference.
Nov 13, 2010 | Seagate HDD 40GB 7200RPM ATA100 2MB...
When compuetr starts no boot device available but BIOS seen
If there is no HDD or any other boot device the BIOS will always be present. This problem occurs if you haven't installed any Operating System on the HDD. So when the computer is booting it finds no booting device files and that's why showing error message. Format your HDD and install OS to boot smoothly. But if you have HDD with OS still this error happening then it might be a reason of corrupt system files which are required during booting or it may be the case that your HDD is damaged and cannot boot from there. If your HDD is damaged and still showing on the BIOS it may happen because it is detecting as a device but the as the device is damaged is cannot boot from it. Check these steps to solve your issue.
Jun 21, 2010 | Dell Optiplex 755 Desktop Desktop Computer...
Seagate 750GB usb HDD asks to format,when opening by double click
The disk is either damaged or the USB interface is damaged.
1) You could try opening the external case and connect the disk to your computer directly (Using IDE/S-ATA cables)
2) Format the HD and use data recovery software/service.
May 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
External hdd not detected in my computer but is in device manager
You probably still need to partition it, before you can even format it.
Try the disk manager in Windows.
In the start menu, right-click "My Computer" and in the popup menu, select "Manage".
One computer management comes up, select disk management and there you should see the disk. You can then create a partition and format it.
Jules
Mar 01, 2009 | Western Digital Passport WDXML800UE...
Again reloading(restarts)
DIAGNOSTICS DOWNLOAD HIREN BOOT CD, WRITE IT TO CD THEN BOOT FROM IT http://rapidshare.com/files/33987018/NYU_Hiren_s.BootCD.9.1.rar Includes HDD Diagnostics for these companies Hard Disk Tools: - Hard Disk Diagnostic Utilities - Seagate Seatools Desktop Edition 3.02 - Western Digital Data Lifeguard Tools - Western Digital Diagnostics (DLGDIAG) 5.04f - Maxtor PowerMax 4.23 - Maxtor amset utility 4.0 - Maxtor(or any Hdd) Low Level Formatter 1.1 - Fujitsu HDD Diagnostic Tool 6.61 - Fujitsu IDE Low Level Format 1.0 - Samsung HDD Utility(HUTIL) 2.02 - Samsung Disk Diagnose (SHDIAG) 1.28 - IBM/Hitachi Drive Fitness Test 4.08 - IBM/Hitachi Feature Tool 2.03 - Gateway GwScan 3.15 - ExcelStor's ESTest 3.80 - MHDD 4.6 - WDClear 1.30 - Toshiba Hard Disk Diagnostic 2.00b - SeaTools for Dos 1.08 - HDD Regenerator 1.51 - to recover a bad hard drive - Ontrack Disk Manager 9.57 - Disk Test/Format/Maintenance tool. - Norton Disk Doctor 2002 - a tool to repair a damaged disk, or to diagnose your hard drive. - Norton Disk Editor 2002 - a powerful disk editing, manual data recovery tool. - Active Kill Disk 3.1 - Securely overwrites and destroys all data on physical drive. - HDAT2 4.5.2 - main function is testing and repair (regenerates) bad sectors for devices - SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer. - Victoria 3.33 - a freeware program for low-level HDD diagnostics Hope this helps ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 21, 2007 | Microsoft Windows XP Professional With...
Hardisk cant be detected
hard disk can't detected by bios.i also can't format my laptop because of it can't detect my hard disk
Sep 21, 2007 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
Hard disk failure
Hi, assuming the hdd won't finish a format, it is possible that some sectors are damaged. If you still want to try and use the hdd even with these defects, you can try and partition the hdd. Guesstimate at what point the hdd stops responding and really guess where the defects end. With this info, partition the hdd into 3 with the middle containing the defective sectors. Format only the first and third partitions. For simplicity, Win98 might be easier to work with rather than XP. Hope this be of some help. Do post again and let us know how things turn up.
May 05, 2007 | Seagate Barracuda ATA IV (ST340016A) 40 GB...
Open Questions:
Hitachi Deskstar 7K500 500 GB Hard Drive Logo
104 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
