Question about Whirlpool Washing Machines
The water is not shutting off and moving to the next cycle.
  • Whirlpool Master
  • 17,130 Answers
Possible that the water level controller switch is defective. this is normally a pressure sensor and *** the water flows up the diaphragm within contracts to switch the contact and so trigger the circuit to stop the flow and move to the next cycle.
please check this out.
Posted on Mar 28, 2011
I just replaced the drain pump and don't think that's the problem. it pumps just fine, it just doesn't stop pumping and move on to the next cycle, which would be rinse or spin.
some machines use a rinse spin cycle in conjunction so that the fresh water is introduced and spun out through the clothes to remove the suds completely in which case the pump will be working all the time to pump out the dirty water.. If the machine will not move on to the next cycle check out the timer cycle switch
Aug 16, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Jun 10, 2009 | Whirlpool Washing Machines
Washer fills with water, spins but does not aggetate
LG washing machine, the water continue, not stop
Mar 15, 2009 | Washing Machines
Admiral Washing machine will not advance to the next cycle.
whirpool machine .. it was overload and now it's not draining the water. stops when in the drain cycle./
Jan 01, 2009 | Admiral AW22 Top Load Washer
Washer fills but won t advance to the next setting for all cycle
Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
Nov 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
No water supply
There are a few checks. Try the #1 first and then proceed to the next one til you get water. Here are a few checks:
  1. Turn off the supply and disconnect the supply line to the dishwasher, turn the water on to flush the line and to check for flow
  2. If you have water to to the supply line, your problem is the water solenoid. Replace the water solenoid.
  3. Turn off the supply, and disconnect the supply line at the shut off, turn the water on to check for flow.
  4. Shut the water off to the house, disassemblehe shut off, clean debris out of shut off. It may need to be flushed. I recommend using a hose to direct the flow into a 5 gallon bucket while someone cycles the water supply.
  5. Replacement of shut off is next.
Please rate this solution.
Aug 03, 2008 | Kenmore 15129 Built-in Dishwasher
Kenmore washing machine
you need to replace the timer it is faulty let me know how you make out
Oct 30, 2006 | Kenmore 15944 Top Load Washer
Washine Machine
-Sounds like the timer is out. Check it out and replace it
Good luck
Mai
May 16, 2017 | Kenmore 22642 Top Load Washer
Washing Machines Logo
75 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
