Question about Kodak EasyShare M1093 IS Digital Camera
My Kodak m1093 stops charing in 5 minutes on a new battery. The old battery was dropped due to i thinked it goes dead but that was an lens error that i fixed later. when i used a new branded battery, it charges it only for a few minutes but if i remove and reinsert the battery while charing, it continues for more 5 minutes. i have to remove battery 10-15 times to charge it fully. I will never buy from such a idiot company whos camera cannot tell what error it is facing like lens error or battery problem. Previously i had a very good time with this camera with stock battery.
  • 56 Answers
Hello, try putting in more expensive re chargeables. And if that doesnt work, get yourself a discharger. This machine discharges the batteries safely and allows them to fully charge to their full potential. There are more stronger batteries coming out every week, just try a couple and see how you go. Also have you tried using a different charger? Perhaps the charger may not be 100% all of these things make a difference. I hope I have helped you.
Posted on Mar 28, 2011
My Kodak m1093 is will not turn on.
I don't know the answer but I do know there are a multitude of things that can cause it. 1. being the batteries are old and no longer can hold a charge. That can happen just from sitting. 2. The wrong batteries were used in it. Rechargeable triple or double A's aren't the same as standard triple or double A's.
3. The batteries were aloud to run empty and sat empty for a long period of time. (just running them to the point were they die can cause problems) Some batteries act wrong when there low sending out spikes of high amps.
4. A magnet touching the camera or a good jolt of static electricity can ruin it.
I would try a new set of batteries first. If you have some or have a friend who has some just to test it would be handy.
Also you could try plugging it into your PC the power from the PC may close the lens at least but DO NOT FORCE IT CLOSED, that can easily ruin it.
I did have this happen before but in my attempts to fix it I made it irreparable. it's was a bummer. I liked mine too.
Good luck
Apr 29, 2017 | Kodak EasyShare M1093 IS Digital Camera
Hello, My camera M1093 IS suddenly will open when I hit the power button only to close immediately. The screen comes on for a second and then it closes. I ordered a new battery thinking that may be the...
Could be something stopping the lens to go out all the way. It will automatically retract and turn off if anything prevents it from extending. It could be the motor or whatever but I would definitely contact kodak. Also could be something like a short or software malfunction but it sounds like a problem with the lens not being able to extend fully out.
Jul 30, 2010 | Kodak EasyShare M1093 IS Digital Camera
Kodak m893IS is not turning on....the camera was dropped by accident but it wasn't dropped from high it was only like 2 feet...after it was dropped it worked fine for the next 5 minutes but then it turned...
You may have bent the camera's lens housing, which will require professional repair, but the problem you describe is frequently due to corroded battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, clean the contacts at both ends of the batteries, and reinsert them in the camera. This cleaning cures the problem about 90% of the time, and I hope it works for you.
Sep 03, 2009 | Kodak Easyshare M893 Digital Camera
Problem switching on my Kodak m1093 IS
Fixing your problem could be as simple as cleaning the battery contacts in the camera, or the solution could be a lot more complex and expensive. Here's a link to the Kodak Help Center - it provides a simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Aug 03, 2009 | Kodak EasyShare M1093 IS Digital Camera
Kodak M1093
It requires service or repair
Sep 05, 2017 | Kodak EasyShare M1093 IS Digital Camera
Lens won't retract, power on button makes 'on' sound, blinks blue briefly, and then goes off. Picture screen quickly blinks white, than goes dark. Camera was carried around without a case in my pocket...
Your fix could be as simple as cleaning the camera's battery contacts, or it could be something more serious and expensive. First try removing the batteries and cleaning the camera contacts with a small metal brush, steel wool, or fine sandpaper. If that doesn't fix the problem, check the Kodak Help Center by clicking on the link below. It uses a simple Q&A format to diagnose problems and propose solutions.
Jul 12, 2009 | Kodak EasyShare M1093 IS Digital Camera
C913 Kodak won't turn on
check the battery where you insert on camera kodak has an error on mine <+> should be where the <-> is and<-> should be where the<+> is
Nov 26, 2008 | Kodak EasyShare C913 Digital Camera
Kodak EasyShare M1093 IS Digital Camera Logo
27 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
