I have cleaned the heads on my vs player but it keeps telling me that my heads are dirty. I have cleaned it with a tape and I have also cleaned it manually. Why does it keep telling me that they are dirty?
  • 56 Answers
Hello, after a while the heads get worn. Open up the unit, with power turned off, and check the heads to see if they have marks on them. And then,CAREFULLY, take a piece of writing paper and soak it(but not too much) with methylated spirits,and then CAREFULLY again rub it gently around the head, not too hard or you will break the heads that spin around( they are the little black things in the gap of the head) you should see a lot of black stuff on the paper. Keep doing it until you dont see that stuff. If after this you still see the message, you will need new heads. I hope that has helped you.
Posted on Mar 28, 2011
DVD/VHS recorder/player stopped working,screen says NO READ. Where do I get it fixed in Palm Coast,Fl? Model DMR-EZ48V
First, try another disk/tape whichever you are getting the message from. It is usually caused by a dirty disk/tape head or a dirty disk or tape. Second, try using a head cleaner. Available almost anywhere including Walmart! The DVD and the VHS heads should be cleaned after every 10 hours of use.
Sep 28, 2017 | Palm Televison & Video
Cassette eats tape??
Heads are dirty, need to clean & demagnetize the players Heads.
Cassette Tape Player Audio Head Capstan Cleaner Demagnetizer Kit
Apr 15, 2015 | Video Cameras
Went i put a tapes my vhs it just eating the tape up and it cuts off
You need to purchase a VHS head cleaner or clean the heads and pinch rollers by hand. remove cover and lid to drive system. you will see all the tape guides, rollers and heads. use Q-tips and denatured alcohol and clean every thing the tape touches. swap q-tips as they get dirty.
May 07, 2014 | Magnavox Dvd Vhs Vcr Player Recorder
When I record a movie on the vcr it plays back snowy.
Ur VCR signal recorded free air throught an DTV converter box?Yes,this cause is normal,because VCR player have no digital tuner on the VCR player by itself,on it circuitries design.If recorded throught pay cable signal.Yes,than ur VCR video head player is dirty needed to be clean.Tries websites like Amazon.com,Ebay.com to buy a VCR video head cleaner vdeo tape.Just play it as normal as a video tape,when the video head clean,VCR will display clean head eject tape now.
Aug 03, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
It keeps flashing c:31:22 whats wrong
This Sony code in your camera is telling you the video heads are dirty, buy or put a cleaning tape in the camera and press play for around 30 seconds, if problem is not resolved use tape cleaner for 30 more sec, that is all it is I assure you.
bye
David
Jun 12, 2010 | Sony Handycam CCD-TRV208E Camcorder
Vcr gets sound but no video. dvd works fine
it sounds like the video head is dirty and needs cleaning, buy a vcr cleaning tape and follow directions on how to clean the heads... Radio Shack should have the cleaning tape....hope this helps.
Dec 29, 2009 | Philips Magnavox DVD/VCR Dual Player
Jvc miniDV 28x Optical Zoom
clean all brown oxide off capstan roller with 70% alcohol and Q-tip. Its the skinny silver axle that the rubber roller comes into contact with when the tape loads. This is what pulls the tape through the transport. also clean heads with head cleaner tape. If your head is dirty, the tape will wrap itself around the drum and cause a transport error.
Jul 14, 2008 | JVC GR-D290 Mini DV Digital Camcorder
VCR acting strange with audio and playing
It sounds like the audio control head is at fault.
If all prerecorded tapes (movies) play with audio level jumping up and down, is is likely that the audio head is dirty. The audio head in the VCR looks very similar to a head of an old audio cassette player.
First, try to clean the audio head by running a VHS head cleanning tape. The cleanning tape will usually clean the path of all tape mechanisms..
Good Luck
Feb 25, 2008 | Panasonic PV-V4523S VHS VCR
DVD RECORDER + VCR
this shows that your tape needs to be cleaned we have vhs cleaner a liwuid type and dry type just play this and it will clean your tape head. the tape is stock up inside due to dirty tape head. does this answers your problem?
Dec 03, 2007 | Televison & Video
Bad playback quality
Some possible cause of lines, noise or pixelation during playback are: 1. Dirty heads on the recording machine. If the heads were dirty at the time of recording, the dirty heads didn't record a strong enough signal on the tape. The damage is done for this tape and recovery is unlikely. Best advice here is to use only premium grade new tapes and keep your camcorder clean by occasionally running a cleaning tape. 2. Physical tape damage. Any distortion of the tape will result in mistracking and subsequent loss of data. 3. Built up oxide deposits or other debris in the guidepost corners can also result in tape edge damage. Keep your machine clean! 4. Improper tape storage - Even short term exposure to high temperatures over 130 deg f. can permanently damage the tape. The black cassette housing readily absorbs the sun's infrared rays and internal cassette temperatures can soar even if left in direct sunlight on just a warm day. It doesn't take much heat to slightly distort the plastic shell or ruin the tape contained within. * Try other tapes to ensure the problem lies within the tape and not the camcorder. * If the problem becomes apparent on all tapes, try a head cleaner. After cleaning the heads, the tapes may not play cleaner if the recording was done while the heads were dirty.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
