Question about Jwin MP3 Player
My iriver stops then comes on with warped music, then stops again. Now although I know it's charged it will not turn on... Just out of warranty too.
  • Rielle Burst Mar 28, 2011
    In order for me to make an attempt to solve this problem, I need to know what type of model the electronic device is or its model number. This is not the solution to your problem, but clarification is needed in order to get a better explanation of your problem.
  • Simone Stranack Mar 28, 2011
    It is iriver E150.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 164 Answers
Good morning, afternoon, evening or night; whatever time you are viewing this. What you are trying to say in your request is that your MP3 player stops playing, then comes on for a short period of time with defective music, then cuts off again. There could be a number of causes here. We can eliminate the "battery needs charging" cause because you said that the battery is already charged. But the battery itself may be defective. If that's the case, you will need to install a new battery into your device. Reply back and I will try my best to locate where you find a battery for this product. Another cause to take into consideration is the music file that you are playing. The music files that the iriver 150 supports are: MP3, WMA, OGG, FLAC & ASF. The music file you that was currently playing may not be supported by this device or is corrupted. If so, you need to delete this file immediately. To delete a file, press and hold the > (directional right) button to display the Options menu. Select Delete File to delete the selected file. You can also go to your file manager and manually delete files. On the main menu screen, press the directional up or down buttons and selcet the File Manager, then press the OK button. Next, press the directional up or down buttons again to select either Internal or External Memory, whichever type of memory your file is under. If you do not know what Internal or External Memory is, Internal memory is the memory in your hard drive. External Memory is portable memory for example a Micro SD card, that can be taken out. In the file folder list, press the directional buttons to select your folder or subfolder if you have created one. Once you've done that, press and hold the > (directional right) button to confirm the deletion process. If you are still having problems, try changing the settings for the backlight or auto power. To do this, go to your main menu and select the Settings que. The select either the Display or Timer options. If you selected the Display option, select Backlight and change the time to your desired setting. If you selected the Timer option, select Auto Power and change this setting to off. If that doesn't solve your issue, reply back and and I'll see what else to do. I hope these options get your music device back up and running. If you have any questions, comments or concerns; reply back to this website. Thank you for taking the time and oppurtunity to read this solution and choose FixYa as you one-stop solution spot to answer all your problems. Thank you and have a good day, afternoon, evening or night; whatever time you are reading this.
Posted on Mar 29, 2011
Iriver mp3 player aa battery
Are you all sure the battery is fully charged? a lot of time I forget to shut my player off and run the battery dry. Should this not be the case then try the reset. If rest is not working try plugging into you pc if the unit shows it should be charging. You can reformat your unit Problem is you have to re-add your music. To reformat go to my computer right click your device and select format. Now unhook from pc and turn on unit. Should this fail them you may need to check for an update to the firmware. Otherwise if not under warranty still ,time for a new unit.
Apr 26, 2014 | iRiver H10 MP3 Player
I have just recently purchased a 2nd hand iriver but dont hav a manual for it & wanted to know how do i put files on my iriver, i have tried both music & video & although it says on the...
You can download the E10 manual from the manufacturer's web site at
http://www.iriverinc.com/lounge/loungeView.asp?selectPart=03&findWord=&sno=821&page=1&cateCode=03
Dec 15, 2010 | iRiver E10 Digital Media Player
Iriver h300 drive problem
whenever my iriver h300 is turned on, i get this message 'check hdd connection' while the device is booting. although i had over 2000 songs and 400 folders, the device now shows 0000 (zeros) for both songs and folders. i guess they cant be accessed anymore. how do i get around this problem
Jun 19, 2008 | iRiver H320 MP3 Player
Iriver s10 problem
there is a 'reset hole' next to the power on switch - you need a pin to push into the reset hole
I do not use the software that comes with the S10 - it always wants to go on to the internet and re download itself. If I want to copy music over I use windows explorer and copy MP3s into the music folder
Here is what I do when I need to reset - format S10 machine from windows
1. plug the S10 into the computer via the USB key
2. You should see the S10 in Windows Explorer as a portable flash disk
3 Right Click and select format - Warning! all data will be lost if you have not backed up!
4 In the File System drop down list select FAT (the default is FAT32)
5 Click start to format the device.
6 Once the S10 has been formatted unplug it from the computer
7 Turn the S10 on and scroll down to SETTINGS
8 Right click and scroll down to Advanced
9 Right click and scroll down to Format Device
10 Right click and then click OK to confirm
On the same menu as Format Device is Reset All Settings - I recommend you do this as well.
11 Plug the S10 back into the computer
12 When you look at the S10 in Windows Explorer you will see it has created some extra folders
13 drag and drop MP3 music files into the Music folder and away you go!
14 you can create additional folders in the Music folder if you want to organize your music
Jun 07, 2008 | iRiver S10 2 GB MP3 Player
MMy iRiver iHP-140 doesn't turn
If it is the power switch and it is out of warranty you are out of luck. This happened to mine and iriver will not fix anything not in warranty. Bill in AZ
May 02, 2008 | iRiver iHP-140 MP3 Player
Battery Life
it is normal
to charge it of the mp4 and charge it
Mar 11, 2008 | iRiver E10 Digital Media Player
Loss of songs
try updating the firmware on the device, also update your iriver program. other wise reinstall iriver plus and update to lastest version.
Feb 17, 2008 | iRiver E10 Digital Media Player
Iriver T30MX
If running Windows XP, install Media Player 10 and it will recognize it.
Jeb
Jan 18, 2008 | iRiver T30 MP3 Player
Iriver Clix problem
yes i river has got customer support in online but i don t know how efficient it is if you had brought it from india , you better contact the vndor and ask for its warranty support man or else give a try connect the i river to another computer with windows xp (i prefer) and then install the software bundled up with your device and try to format the device via the software and then disconnect the device and power it on it will work i think
Aug 06, 2007 | iRiver Clix Digital Media Player
Iriver H10 20GB
They don't make a battery for the player. My experience with iriver is that they only replace your player with another refurbished one if it's under warranty. Contact iriver.com and go to support, they will help you to a certain point. Sounds like some music files are corrupted, did you download them from Limewire? Lots of nasty stuff out there. Remember your player is a Hard Drive just like your PC and can be damaged by improper disconnect from your PC. Regards, John H.
Feb 07, 2007 | iRiver H10 MP3 Player
Jwin MP3 Player Logo
41 people viewed this question
Top Jwin Audio Players & Recorders Experts
 Grubhead
Grubhead
Oloyede Monsuru
Are you a Jwin Audio Player and Recorder Expert? Answer questions, earn points and help others
