I have asrock agp8x p4i65g and don`t know how connect fron power/reset buttons and fron lights. There`re 5 lines power sw, reset sw, H.D.D. led and 2 ampty
  • 656 Answers
Yea there are 5 lines one is power switch other is reset the power led then hdd led then in older motherboard there is provision for speaker The power switch is in the front pannel of the motherboard if you have multitester the power which will indicate 5v the power switch is to be conected to the 5v and the ground normally the front pannels details will be given in the motherboard
Posted on Mar 28, 2011
How do i plug in power button in on mother board? Lost my manual so I can't find the model #. I was just switching my mother board and all other hardware to new case and my power button (or switch or...
> power led,
Runs to the LED (Light Emitting Diode) labelled "power" on the front of your computer-case
> H.D.D led,
Runs to the front-panel LED that lights-up whenever the Hard Disk Drive is being used.
> reset sw,
Runs to the "reset" button on the front panel.
> speaker
Runs to the internal speaker
> s/b sw
Very briefly touch a metal-tip screwdriver between these 2 pins.
If the computer powers-on, you've found the "power" connector.
Nov 06, 2009 | Intel Motherboard
Front panel to motherboard, ASRock P4i65G, connections
the power switch is on the 3 and 4 pins....the 7 and 8 pin are the reset pins. Trying it on wrong pins just won't startup the board but won't short circuit anything.
Jul 28, 2009 | Computers & Internet
Mobo power
There are jumpers on the motherboard,
check all jumpers are set correctly, as from the user manual, this could be a problem.
check all your front lights are wired properly
power button, reset switch, must be correct too.
double/treble check them before building it.
Richard.
Apr 20, 2009 | Asrock 845GV (P4I45GV) Motherboard
Wiring color code sequence for the pins to the front system panel for an asrock p4i65g motherboard. There are 4 double pin connectors. Jim/Sudbury
Can't say what the colours on your case wires are because they do vary but they should be marked up PWR SW (or PWR BTN), HD LED, etc.
Looking at the pin layout there should be a row of four with the pin on the far right missing and underneath a row of five with the last one on the far right being unused.
12 3 4
OOOO
5 6 7 8 9
OOOOO Pins 3 and 4 are PWR. Pins1 and 2 are PWR LED.
5 & 6 are Hard drive and 7&8 are reset
Feb 22, 2009 | Asrock P4i65G Motherboard
Configuration
Hi
The wires that read +5 -d +d and ground those are USB connectors each usb connector will have 4 wires, +5 -d +d and ground so that goes to usb pins.
The sw must be power switch
The HDD led is the load light
Reset is the reset button
Power led is the front power light
SPK is the speaker / beeper.
Can you tell me the brand and model of the motherboard? They are documented in the user manual. but generally in the bottom right corner of the motherboard you have the connectors for the leds and buttons, its all written into the motherboard with small white text. but I can get clear instructions from the user manual for you.
You can look for the motherboard details between the expansion slots and between the cpu and memory.
Thanks,
Ekse
Feb 03, 2009 | Intel SVM266A VIAP4M266A (SYNTAX SVM266A...
Wiring connection schematics
Here is the link for the Users Manual for the ASRock P4165G.
http://download.asrock.com/manual/P4I65G.pdf
This next one is for the quick installation guide.
http://download.asrock.com/manual/qig/P4I65G.pdf
Hope this helps. And Happy New Year to you too!
Dec 31, 2008 | Asrock Computers & Internet
New motherboard
You don't say what case you are using. If it is proprietary and the front panel header is all in one connector, you can carefully back the connector pins out of the block using precision screwdrivers. I keep a bunch of two pin connectors from junked machines so I can create individual connector sets when changing motherboards (eg, PWR SW, PWR LED, HDD LED and RESET). This also requires that you know the pinouts of both the old board and the new one so you can get everything connected properly.
Very doubtful you will ever find an adapter to change from one front panel block to another.
The 9-pin connector probably uses a spacer pin between the legs of the PWR LED, while it seems the 6-pin does not have RESET.
Dec 30, 2008 | Asrock P4i65G Motherboard
Gigabyte GA-8INXP Motherboard Problem- front connector pins
If the wires from the reset switch is white/blue the blue wire is positive, Hdd red/white red is positive power Green/white Green is positive etc. The wires on the speaker connector will be red/black/black/white - red is positive. The colored wire is always positive. On all GA mb's the positive connection is always towards the back of the MB and are marked with a + on the base of the pin as you can see on the photo. Hope this help.
Sep 19, 2008 | Gigabyte GA-8INXP Motherboard
Motherboard is dead!
Here is a new board. http://3btech.net/asp4so47880p.html but you have 90 days to set it up & test it.
To answer you're question. (Yes it will fit). Both boards are Micro ATX.
Here are links for both boards showing their specifications.
Asrock P4i65G
http://www.dealtime.com/xPF-Asrock-Asrock-P4I65G-skt-478-i865G-800FSB-dual-ch-DDR400-8x-AGP-64MB-on-board-VGA-SATA-RAID-LAN-USB2-0
Asrock P4S61
http://www.dealtime.com/xPF-Asrock-ASRock-P4S61-P4-SIS-661FX-DDR400-Motherboard
This is ASRock's web site for the P4i65G
http://www.asrock.com/mb/overview.asp?Model=P4I65G
If I can be of more service, just post back & let me know how thing go.
Mike
Apr 28, 2008 | Asrock P4S61 Motherboard
Computers & Internet Logo
486 people viewed this question
David Payne
David Payne
