Question about IBM Computers>Laptops Lenovo ThinkPad T60 Ser PC Notebook
My t60 laptop battery is not chagrin & no power up ,i wont repair it my self but i haven't this circuit board inf,pleas sent to me it
    New Friend:
  • 68 Answers
The battery is already Dead and needs to be repack. If this is not detected by the laptop, goto CMOS setting and have the laptop detect it from there because sometimes CMOS setting disables it especially when you remove it.
Posted on Mar 28, 2011
Bios password lenovo T60
there are 2 ways to attempt it. 1/ you need the diagram of your mother board as it involves changing a jumper setting on the board to clear the pass. 2/there is a small round battery inside ( could be under a cover under the laptop ) unplug that battery for a while to clear the cmos. hope this helps
May 01, 2015 | IBM Lenovo ThinkPad T60
Fitnex t60 display says prg bad, what does that mean and how can i repair it
1) You must test first the power supply for +5DC for I.Circuit( Including EPROM, ROM, etc)
2) Test the flexible cable between KeyPanel and display board, and clean.
3) Chechk the connector between Display Board with the lower board(Main Controller Motor)for loose connection, loose wire.
4) Test the transformer controller supplying the 12VCA, to the power supply at the Main Controller Board since this supply the +5vd to the Display Board.
Finally you must have Strong Conclusion if the problem is 1)Display Board faulty, 2) Power supply Faulty, 3) Transformer Controller Faulty 4) Main Controller Board Faulty.
For All test you must use Dvoltmeter.
sincerely.
E.CUADRA
MANAGUA, NICARAGUA.C.A
Nov 21, 2011 | Fitnex T60 Light Commercial Treadmill
Ok ,my l645d 4040 does not show anything on the screen when i power it on.i can hear the fan is on but nothing on the screen.and if i have it plugged in with power supply it starts for about 3 seconds and...
If the laptop is still under warranty, send it to a certified Toshiba repair centre, if not than I can tell you have a cold jointed component on the system board (most likely the GPU), you could try cooling down the laptop by putting it some place cold (cellar, refrigerator, AC outlet, etc...) NOT A FREEZER, for some time and see if it comes back to life, if it does, my diagnosis is correct, you need to have it re-flowed, (resolder the board's components) there are specialists that can do this but it's not cheap!!! you can of course do it yourself (if you have nothing to loose and good skills) by starting with this site: http://www.tomshardware.com/forum/56202-35-what-reflow-laptop-repair (I've done it my self on an old DELL precision, an IBM ThinkPad T60 also, and it worked both times) I am using at this moment the clinically dead T60 ha! ha!, my recipe was stripping the laptop down to (only the board) don't forget to take out the CMOS battery as it might explode in the oven, than I pre-heated my oven to 390F, when it was at the correct temperature I've elevated the board about 1 inch with metal standoffs, placed it in a cookie tray and put it in the oven for 8 minuts, than shut off the oven, opened the door to let cool down slowly to room temperature and reassembled the laptop and VOILA! a perfectly thrown away good working laptop... serve with beer and nachos, excellent!
Jun 27, 2011 | Computers & Internet
Wont power up orange light on
try to remove the cables and battery on your laptop and then press & hold power button for 8 secs for hard reset. Insert the battery and power cable and turn it on. If it still black, then call Dell to repair your laptop. They need to check the circuit board since it does not turn on at all..
Mar 12, 2011 | Dell Inspiron 1501 Notebook
I have a ibm t60 laptop. The power cotd tests good. But the battery wont charge and the AC power light does not come on.
I see this same thing often, when people push in the power plug too hard, jostle the laptop around alot or even tried to force the wrong plug into the port---it sounds like you may have broken the solder on the mother board on the power inlet, There are 4, 6 or 8 solder spots on most power inlets, you may have broken one or more of them loose---take it to the shop if you are not handy with a screw driver and a soldering pen...
Feb 14, 2011 | IBM ThinkPad T60 Notebook
Thinkpad t60 want power up. any ideas, beside the
The power jack inside the computer is U/S This needs to be replaced and is a job for a damn good diy'er, or a professional repairer.
Jan 05, 2010 | IBM ThinkPad T60 Notebook
Motorola S805 headset worked fine with T60 laptop
Solution I found with the same devices is to properly par the devices.
Refer http://direct.motorola.com/ens/s805/QuickstartGuide.pdf
It basically states :
1.Ensure the headphones are turned off (L indicator light not blinking).
2.Press and hold L button. After about 6 seconds, the L indicator light becomes steadily lit.
3.Release the L button. The L indicator light remains steadily lit.
If the L indicator light is flashing or not steadily lit, repeat steps 1 through 3
Now on the T60:
Search for Bluetooth Devices as you would normally.
The T60 lists Bluetooth devices it finds.
Select Motorola S805.
Select OK or Yes to pair your headphones
with your phone.
Enter the passkey: 0000
Select OK.
When your headphones successfully pair
with your phone, the L indicator light
changes from steadily lit to rapidly flashing.
That's it next time you start a audio program on T60 output will be sent to Motorola Headphones
Nov 13, 2009 | Motorola Mobility S805 Wireless Headset
Will not work on battery power, have tried two other working batteries still no luck
A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Nov 10, 2009 | Lenovo Thinkpad T60 Notebook
Volume
are you aware if the AA battery are weak it looses it radio station.if u replace the AA battery already the display board should be replace. in case it need 2 or 3 board go for max cost repair rather than replacing individual parts by your self it will cost u more. at the center they can discount the cost of the repair ask for max cost if needed.
Jul 28, 2008 | Dewalt DC011 AM/FM Radio
Satellite A100-166 PSAA9E does not charge the battery
Your power controll circuit on the main board is bad, you might need to change that or the entire board itself.. If you can get a technician just to repair the power controll circuit you should be fine. most ppl dont do that cause its difficult. Normally your entire main board is replaced. To fix that i will need to see the board but thats difficult since i am sure you dont live anywhere close to trinidad but i am sure someone close to you will be able to repair it, or your can download your service manual for your laptop and attempt to repair it your self.
Dec 31, 2007 | Toshiba Satellite A105 Notebook
IBM Computers>Laptops Lenovo ThinkPad T60 Ser PC Notebook Logo
81 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
