Question about Frigidaire CWS3600AS Top Load Washer
Frigidaire top loader
My washer which is only a couple years old,just began to stop mid cycle..it won't advance to the next cycle so it wont drain or spin...HELP!!!!
  • andreatsmith Nov 04, 2008
    My machine would also stop mid-cycle and it would only restart after I open the machine lid and then close it again, then it would continue. Now suddenly it filled up for a large load yesterday and didn't do anything. I switched it to the delicate cycle onto rinse and it rinse in the delicate section but id I went back onto dark or white loads it would not rinse or spin or agitate.
  • 943 Answers
Hi thanks for your question. it would appear to me that the problem is with your lid switch would check that first try it and let me know thanks THE APPLIANCE DOC.
Posted on Sep 13, 2008
I have a maytag centennial washer MVWC400XWO it is 3 years old. The washer has stopped after the initial wash cycle leaving the cloths wet in a tub full of water. The washer will not go to the spin/drain...
For saftey the lid lock and lid down switch must be activated before the machine can advance to the next cycle. This has been the sequence for all top loaders..
Check the switch for the lid it is likely defective.
Make sure that the power is removed.
Simple repair by a qualified technician.
Hope this helps?
Jun 14, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
I have a Frgidaire Gallery series front loader washing machine. It just started pausing itself mid cycle. I have to keep checking on it and repress the start button. It doesn't seem to be spinning...
I have the same problem ,, and i called frigidair and they didnt seem to care my unit is only a year old ,, im so furious right now ,, now i was looking on the recall list and the water pumps are on the recall list on selected models i know with mine it will stop then pause and not drain the water out ,, maybe some can help us out :)
Sep 06, 2011 | Frigidaire ATF6000ES Front Load Washer
My GE top load washer is about 5 months old. It fills up and runs through the agitation cycle but then stops at the end spin cycle. The clothes just sit in the water. I checked the hose for kinks and...
I have had this problem with two of my previous washers a top loader and front loader.Each time it was a faulty pump that drains the water from the tub after the wash cycle is complete. If the water does not drain from the tub the machine will not go to the spin cycle. Both of my washers were 5 or 6 years old when this occurred. If the washer is only 5 months old it should be under the manufactures warranty. Good Luck.
Nov 12, 2010 | General Electric WBB2090G Top Load Washer
GE Top Loader 10 years old. won't drain
Timer is faulty and should be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | GE WBSR3140DW Top Load Washer
Frigidair Top loader washer wont drain, but pump is running...
firs get a shop vac and drain the water from the drain hose if you don't have one get a radiator hose clamp from auto zone then remove two bottom screws from washer bottom and pull down on panel you will see a hose coming down from the tub if you didn't have a vac clamp the hose here with the clamp about mid way the pull the hose from the drain pump and check it for jamming there is no filter
Feb 12, 2009 | Frigidaire FEX831CS Top Load Stacked...
Frigidare front loader washer error message 20
If you open the top of the washer , there is a "tech" sheet in there to tell you how to reset the error codes.
My washer started this. Then stopped spinning. Now it will not even wash a load. It stops mid-cycle. The ER 20 means that something is not draining right. We checked all of the tubes leading to the pump. Nothing was clogged. The technition seems to think it is a motor controller error.
Oct 27, 2008 | Frigidaire Affinity ATF7000E Front Load...
Stops mid cycle
CHECK DRAIN PUMP AND DRAIN HOSE FOR RESTRICTION
Jun 01, 2008 | Fisher and Paykel GWL11 Top Load Washer
Frigidaire Affinity ATF6000ES frozen
IF there is an E attached to the 45, it is your control board and the control board would need to be replaced. This is per the "Washer Tech Data Sheet"Hope that helps...
Mar 19, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire CWS3600AS Top Load Washer Logo
173 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
