Question about Polycom VSX 6000 (220022222001) Video Conference
Microphone not getting connected Changed interface
Microphone not getting connected Changed interface and microphone also. No improvement.
    New Friend:
  • 4 Answers
Try changing the wire. Must be the 30 foot cable not the 10 foot which is specifically the daisy chain ... The former 30 foot is the specific cable from codec to mic. If changing this fails and you tested the mic, then your unit is either suffering corrupted software or the mic hardware is damaged. David
Posted on May 24, 2014
I have a scarlett 2i2 interface and a bluebird microphone, but the interface will not recognize the microphone. im using windows 7
What software are u using for recording (Cubase, pro-tools, reason etc) and does it recognise the line in socket
Jun 30, 2014 | Focusrite SCARLETT-2i2 2 in / 2 out USB...
How do I connect my CAD GXL2200 mic to my apple laptop?
You need a USB interface such as an M-Audio M-Track and a standard XLR male to female audio cable.
You use the cable to connect the microphone to the interface using the XLR cable, then you plug the USB cable on the interface to a USB port on your laptop. Finally, you go to System Preferences - Sound - Input and select the USB interface as the input source.
Depending on the software you you use for recording sound (I use Sound Studio from Felt Tip Software) you may need to go into the Preferences for the program and select the USB interface.
Dec 25, 2013 | CAD Microphones GXL2200 Professional...
Can a Behringer C-1microphone connect directly into a computer and record? What other equipment will I need? Thanks
you could get away with getting a small behringer mixer that has +48V of power for the mic. Put your mic cable into there and then run straight out using 6.5 (guitar) cable to your computer. you may need some connectors to convert your jack.
Jan 27, 2013 | Behringer C-1 Microphone
Hi. I bought a Behringer Dynamic Microphone XM8500 but I don't know how to install it. It's not working but probably because I'm doing something wrong. It's my first microphone. Do I need a mixer? Does the...
the type of mic input built into a pc (with a mini-jack socket) will not accept the output of a pro dynamic mic such as the one you have - it won't work correctly. You require a pre-amp or mixer - or what would be better for you would be an audio interface with a built in pre-amp such as this:
interface example.
Apr 21, 2011 | Behringer XM8500 Professional Microphone
Can I record in stereo via the microphone/line-in jack? On the the Sigmatel interface when Line In is selected, I get no signal on either Audacity or Sound recorder software - but I do get a mono signal...
The input-level from a (monophonic) microphone is MUCH less than the input-level from a device (cassette player?) connected to the (stereophonic) LINE-IN socket.
So, crank-up the slider, to amplify the input.
Make sure that you're connecting into the LINE-IN port, if you want to record in stereo.
Feb 26, 2011 | Dell Inspiron 630M Notebook
Can I connect a CAD GXL2200SP Condenser Mic to a computer?
Technically, you can plug any microphone into a computer via an audio interface or USB(if applicable) With this mic it will require an audio interface just remember that since you are using a condenser you will need an interface that can supply phantom power. Good Luck, Cody J.
Dec 15, 2010 | CAD Microphones GXL2200 Professional...
I'm thinking of buying this microphone for recording vocals to a computer to produce a song, does it connect to a computer through the microphone jack?
No, it does not. A professional mic will not plug directly into a computer. A USB interface, such as the Shure X2u, would be needed.
Nov 21, 2010 | Shure C606 Consumer Microphone
It dont sound like a cd or studio how can i set dis up
There are many factors that can affect how your recorded performance will sound, ranging from the gear (microphone, mixer, interface), the software your using, the room your recording in and the microphone and other recording techniques.
Keep in mind that this is a Consumer Microphone, not a Professional Microphone, so your recording can only sound as good as the mic can record, however there are many ways you can improve the sound you record with the mic.
Start with the recording environment. Hang quilts or other absorbent material on the walls to absorb reflections.
Use EQ and Compression in your software (google this for more info on using these tools)
Most of all, ensure you are using a Pop-Filter to eliminate any plosions (the loud popping noise heard on "B"s and "P"s etc). You can make one out of a coathanger and stocking that is just as effective as most commercial ones if you dont want to fork out the cash.
Use google as a tool to gain as much info as you can on Audio Engineering, and you shoud be able to improve the quality of your recordings quite drematically.
Mar 22, 2010 | Samson C01U Consumer Microphone
Microphone too quiet
That's probably not going to work.
Mic level is extremely low compared with line level.
Your sound card is expecting a line level input.
It's simply not made to plug a microphone into (you must be using an adapter or two just to make the connection)
Look for a USB Audio Interface with XLR or 1/4" microphone inputs - these interfaces are pretty generic these days and easy to use ... just plug into your computer via USB and then plug the mic into the interface ... which has a volume control on it ...
I use a Tapco Link.USB ... and like it
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.whamuniversal.com
Oct 14, 2009 | Sennheiser E845S (3 Pack) Professional...
Polycom VSX 6000 (220022222001) Video Conference Logo
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
David Burbee
David Burbee
TEKUSER
TEKUSER
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
