Question about Fisher and Paykel Washing Machines
My machine has stoped mid cycle, have emptied out alll the washing but it still won't continue. It is making a sound like it it trying to get started but nothing happens. It is a Fisher Paykel Pride 5.5 top loader
    Brigadier General:
  • 3,513 Answers
Hi
If your washing machine stopped mid cycle or the cycle doesn't advance, it's probably the timer or a cold-water supply problem.
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water.
Also there is an important thing to check is that this unit has a very small fuse, its round and black or red soldered to the main control board, its possible the fuse is blown. Check it and if needed replace it.
Also check the bellow link to have a general idea related to your issue:-
http://www.washerhelp.co.uk/diy-repair-help_8.html
Please get back to us if you have further query else please accept the suggestion.
Posted on Mar 28, 2011
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
Washer stops mid cycle
ur drain is stoped up. the drain emptys into the sink plumbing...
Oct 17, 2013 | Admiral Washing Machines
Washer stops between wash and rinse, and stays full of water. ld code
see this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 21, 2013 | Kenmore Washing Machines
Skipping wash cycle
follow this steps and fix it. God bless you
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
Jul 13, 2013 | Admiral 3.4 cu. ft. Top Load Washer in...
GE WBSE3120 Washer stops mid cycle
if it makes a grinding sound when in spin this is the tub seals or bearing and basically you'll have to replace the washer.very common with this ge washer,not one of ge's best product,also why it stops mid cycle could be anything,this washer has a computer board biult on top of the motor that also failed,if your having all these issues i think that washer sold for like 500 dollars,it would cost more just to repair it,i wouldn't put 5 cents into it,do yourself a favor and get a new washer.
Dec 04, 2017 | GE Washing Machines
I cannot get my washer to drain. Its stops and starts beeping
Sometimes the pump gets a bit clogged. Tip the machine back so you can see underneath (best if it is empty!) and spin the fan attached to the pump a few times in each direction with your finger. Then see how it goes. I saw this solution on a forum a year or so ago and it worked well for me.
Jun 25, 2010 | Fisher and Paykel GWL11 Top Load Washer
Stuck Mid-Cycle, Wet Clothes!!
unplug the machine for 15 minutes then try again
Jun 09, 2009 | Whirlpool GHW9150 Duet Washer
Whirpoo washing machine stoped
make sure there is power (tripped breaker from jammed pump) check the lid switch & or timer
Mar 10, 2008 | Washing Machines
Timer clicks arround and arround
My Belling integrated washing machine will not stop at the end of the cycle. My partner had accidently moved the dial during mid-cycle. We have tried to reset the machine by turning it off and then moving the dial around to the stop section of the dial. However when we turn it back on it waits for a while and then continues to click around with starting any cycle. Can anyone help? Thanks.
Jul 02, 2007 | Belling SGE12X Front Load Washer / Dryer
Washing Machines Logo
48 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
