Question about Lands Phones
I need to deregister VTech Phone model CS6329-2 without the base
  • 1 more comment
  • vgarcia_2006 Mar 28, 2011
    Solution 1 did not work.
    What status should the handset be? do I have to press and release buttons or I have to hold them for some time?
    Victor
  • vgarcia_2006 Mar 29, 2011
    You are not going to charge me for these kind of answers, are you?
    Victor
  • Duane Hutchins Dec 14, 2011
    I had the same issue with my handset. Here is the solution:
    Using the handset you're giving you trouble, Press Menu Select and the press the following without pause - *7890#
    You should now see Test Base at the top of the screen press the Vol up button until Test Handset is present.
    Press Menu/Select and you should see SW Version displayed. Press Vol up button until you see regstr clear, then press Menu Select and then Menu Select again.
    At the handset remove the battery for 15 secs and then place the battery back into the handset. You should see 1. Place handset ... 2. press # on the handset screen. DO NOT FOLLOW THE ON SCREEN DIRECTIONS.
    Next place the Handset on the base station and press the find handset button for 4 secs until the In Use light shows up. Remove the handset and press the # button. The handset is now registered to the new base!
  • Lands Phones Master
  • 12,061 Answers
Hi, well sorry to tell you but I think this isn't possible, you see the codes are passed between the devices, and in the HS it is stored in Non-volatile ROM, the ONLY way the Code can be erased or changed, is by initiating a handshaking sequence with the "Base" only then will the HS be "Allowed" to change the "Codes", so without a connection, it simply isn't possible, it's just that simple.
Even a reset will NOT erase the NVROM, even replacing the NVROM with a blanked or correct code, still probably wouldn't work... as, it also MUST have the data sent from the Base.
Posted on Mar 30, 2011
    Top Expert:
  • 79,865 Answers
You can't do this without the base, you can buy used handsets and then register them to a working base, but not the other way around. I got this from the VTech syupport site.
Posted on Mar 28, 2011
  • 2 more comments
  • yadayada
    yadayada Mar 29, 2011
    You have the correct answer, you can register the hand set to any base station, that is all that you can do. It takes a different base frequency to assign a new registration frequency to the hand set. I fell this answers what you asked more than satisfactorily. Thanks
  • yadayada
    yadayada Mar 30, 2011
    My answer came directly from the Vtech factory data base at the Vtech support site, yet you still think I am wrong about the information??? well ok then!
  • yadayada
    Yes you will still be charged, you where given the correct information the first time around.
  • csims2 Aug 05, 2013
    this worked for me thanks for the info
  • 2,069 Answers
On handset, press talk/FLASH, then press OFF /clear.
How do I deregister an orphaned Vtech sb67108 handset to use on another bases without the original base
Here are the steps: Press menu, then press *883247# and then press the up arrow. Select deregister and then unplug and take the battery out for 10 seconds. Plug the phone back in and it's ready to be registered to another device.
Oct 06, 2014 | VTech Communications 4-Line Cordless...
How do you deregister vtech ds6401 handset without the base?
Enter the following on the handsets you want to deregister: *331734#, followed by the left soft-key (the key labelled "-" at the top left of the keypad).
Jul 13, 2012 | Lands Phones
I need to deregister a DS6101 without the base. I needed to replace the base and once we installed the new base, the extra handset that we had registered with our old base shows the following message...
Called the manufactuer.... To do this enter on the handset you want to deregister:
*331734# and press (Menu Key# 1 - top uppermost left button that is unmarked).
This will put the handset back into the register mode.
Hope this helps,
James Pavicic Jr
Feb 16, 2011 | Vtech DS6101 19 GHz Cordless Phone
Vtech 6.0 deregister
Getting startedReplace a handsetIf you want to replace a handset or reassign the designated handset numberof a registered handset, you must deregister all the handsets and thenindividually register each handset.To make deregistration easier, read all of the instructions on this page beforeyou begin. To deregister all handsets:Press and hold FIND HANDSET on the telephone base for about 101.seconds (until the IN USE light on the telephone base turns on and starts toflash), then release FIND HANDSET.Press and release FIND HANDSET again. You must press FIND HANDSET2.while the IN USE light is still flashing. The IN USE light flashes forapproximately seven seconds.All system handsets show CONNECTING... The deregistration process3.takes about 10 seconds to complete. All handsets show NOT REGISTEREDwhen the deregistration completes.If deregistration fails, you might need to reset the telephone and try again.To reset:1.Pick up the registered handset and then press talk/flash.Press OFF/CLEAR and place the handset back in the telephone base.2.-OR-1.Unplug the power from the telephone base, then plug it back in.You cannot deregister a handset if any system handset is in use.
May 29, 2010 | Vtech Cordless 6041 Phone
Deregister a ds6322-4 without the base
for the Vtech cordless phones model DS6322-4 models
In the handset press
*331734# and the menu button, yur handset will be deregistered.
Enjoy unlocking :-)
May 06, 2010 | Vtech Lands Phones
I need the base id for a vtech house phone model number 6772
It sounds like you are trying to register the handset(s) to the base. Once the handset is charged, if you see 'Searching for Base' on the display,(The bold is for your question specifically but I thought you may like all of the information for getting a phone hooked up) ON the Base unit press MENU, scroll down to Display Base ID, press OK, and the Base ID code will display. If NEW appears in your handset display, press the soft key under it and enter the base ID code you found in the base display. If 'New' does not appear on your handset, press MENU and then scroll down to REGISTER. Press OK and then enter the base ID code. If the handset is already registered, please deregister all then register again. To deregister a handset which is registered to the base model 20-2431, Using the soft keys on the base, press the 'MENU', then press the down arrow once until 'SETUP BASE' is highlighted. Press 'OK'. Press the down arrow 6 times, until 'DEREGISTER ALL' is highlighted. Press 'SET' . If your handset is registered to the base model 20-2481, Using the soft keys on the base, press the 'MENU', then press the down arrow twice until 'SETUP BASE' is highlighted. Press 'OK'. Press the down arrow 7 times, until 'DEREGISTER ALL' is highlighted. Press 'SET'.
Benjamin
Jul 11, 2009 | Lands Phones
How to I reset the base for a Vtech VT-2431
This worked for me after lots of digging....If you have already tryed reregistering your handsets and can only get two-or three to work try this and deregister them and re-register. If your base model number is vt2431: Take the handset out of the base, press **335782 on the dial pad of the base. (do not have the line active or anything , just put the (2) stars and 335782 in (no spaces) on the base unit. This will de-register all of the handsets at one time. Then just re-register the handsets...
May 29, 2009 | Vtech VT-2431 Cordless Phone
I have a Vtech 2431 base station with 4 phones, one at the base station and 3 remotes, I need to replace one of the phones but I do not know how to reset the base station to remove all the phones...
This worked for me after lots of digging....If you have already tryed reregistering your handsets and can only get two-or three to work try this and deregister them and re-register. If your base model number is vt2431: Take the handset out of the base, press **335782 on the dial pad of the base. (do not have the line active or anything , just put the (2) stars and 335782 in (no spaces) on the base unit. This will de-register all of the handsets at one time. Then all you have to do is re-register handsets...
Mar 03, 2009 | Vtech Lands Phones
Lands Phones Logo
587 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
