Question about Canon Office Equipment & Supplies
I have a macbook and am trying to scan my document but I kept getting a message "an error occur while communicating with the scanner'
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 332 Answers
I have many years of experinece with Canon scanners and I think I can help you out.
Your problem is a common one with all canon scanners and its an easy fix. After using the scanner for a period of time the images tend to fill up the memory on the computer. All you need to do is shut down your computer, then turn off your scanner. Turn your scanner back on and then turn your computer back on. That will correct your problem. With canon scanners and if you use it a lot I suggest you do this procedure at least once a day I suggest at the beginning of the day so your scanner will run smoothly for you for you the rest of the day.
If you have any other questions let me know and I hope this helps you out.
Posted on Apr 01, 2011
I try to scan a document and i get the message that "X" folder does not exist, would you like to create one. although this folder does exist is select "ok" another window opens saying...
Uninstall the Printer Software from Add or remove Programmes in the Control Panel.
Get the Drivers and Softwares Installed again.
There is an Issue with the Installation of the Scanner Drivers and Software.
Good Luck!!!!
Sep 24, 2011 | Office Equipment & Supplies
I am unable to scan with epson stylus SX105. It says, "cannot communicate with the scanner. Make sure the scanner is on, correctky setup and connected with no errors in the scanner. If using an...
Did you ever get a resolution to your problem? I have exactly the same problem with same error message - and very loud clicking noises coming from the scanner. Powering it down - allowing it to "cool" for 5 minutes will get probably 1 or 2 documents through the scanner before the error message reappears. But this is only a workaround rather than a solution.
Jan 22, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Error messages appear when scanning from glass to macbook.
  • Unplug the Scanner cable from the computer.
  • Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the Scanner.
  • then you can connect the Scanner and and try to Scan.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Scanjet 3570c not scanning
Scanning Without HP Hardware
1. Click Start
2. Control Panel
3. Click Scanners and Cameras
4. Click on the Icon and follow the Scanner and Camera Wizard instructions.
5. Select the HP scanning device from the TWAIN source list
6. Click File and then Scan New .
Feb 08, 2009 | HP ScanJet 3570C Flatbed Scanner
Scanning error - cannot scan error code 2,155,0 ???
i found this while i had the same error msg... apparently its actully the USB cable where its does not suffice
here is the link : http://www.fixyourownprinter.com/forums/printer/49111
Thanks
Sanjieev
Jan 13, 2009 | Office Equipment & Supplies
Using hp scanjet 3970 Just loaded hp scanning software and the large install of the 3970 drivers. When I enter the program the scanner opens and scans te image on the tray. (I am trying to scan a...
Have you checked the cord from the scanner lid to the scanner base. if that doesn't work I would try uninstalling the scanner and then reinstalling it. It sounds like a problem with the twain driver for the scanner.
Dec 20, 2008 | Computers & Internet
Connection issue between XP Pro and HP C6180 all-in-one
Hi Lynn,
Unfortunately, HP.com doesn't have a very satisfying online solution to your problem. Still, there are a few things you can try.
The first is a general diagnostic check of your scanner. HP provides a doc that takes you through some steps, many of which you probably already tried, to see if it's a simple fix:
An error occurred while communicating with scanning device
The next document is a set of diagnostic steps to address errors trying to scan to a PDF:
An error occurred while trying to scan to a PDF
I don't know if the current situation was created by a fault in the device or some recent change in your configuration settings. I do know you can use the HP Director software installed on your computer to set the scan destination settings:
Settting "Scan To" Destination using HP Director
Those were the most relevant solutions I could find for you. I hope some of this information is helpful. Good luck.
-Trip
Oct 07, 2008 | HP Photosmart C6180 All-In-One InkJet...
I can't scan
This document applies to the PSC 2210, PSC 2210v, and PSC 2210x. When you see the scanner failure message, turn off the PSC 2210. Wait a few seconds and then turn on the PSC 2210. If you see the message again, please contact HP Support. http://h10025.www1.hp.com/ewfrf/wc/contacthp?lc=en&cc=us&docname=c00055511&dlc=en&product=79499&rule=45570&lang=en
Dec 04, 2007 | HP PSC 2210 All-In-One InkJet Printer
63 people viewed this question
old marine
old marine
