Question about Garden
The nail gun has worked well in the past but I have not used it for over 12 mths. Batteries charged up well, new gas cylinder. the gun fills and on odd occasion fires but this is not continuous.
  • 710 Answers
You didn't say what kind of gun you own. I will give a couple of general suggestions I hope will help.
When you cleaned the gun, did you clean the filter? It can be washed with soap and water.
Occosaionally the spark plug wire can come loose.
Also, their is a date on the fuel cylinder that tells you if it is "past its prime." You said it was new, so assumed you bought one at the store. Still could be old.
Also, There are temperature and altitude restrictions on the fuel cells. Is it still cold where you're at. The fuel cells should be warmed in a pocket or something if its cold.
Write b ack if these things don't work.
Hope this helps, if it does, please give me a vote. Thanks,
Handie Andie
Posted on Mar 28, 2011
Paslode 350i first fix nail gun. Charge both batteries (1 is brand new). Put battery into gun and fire. Im lucky to get one nail from it before gun shows up red.
Sounds like either the battery is bad, or since one is new its possible the contacts in the gun are not making proper contact. Are you sure your charger is working as well ? If you have a volt meter check that the battery does have a charge on it.
Oct 10, 2016 | Air Tools & Compressors
Tip
Paslode Cordless Nailer Problems
<p><b><i>Paslode cordless nailers</i></b> are a very common tool used by many professionals and do it yourselfers. These <b>nail guns are a great tool</b> when they work correctly, but can drive you nuts when they do not work as they should. When answering problems that people have on <a href="http://www.fixya.com/"><b>www.Fixya.com</b></a> I come across many questions about these nail guns and why they do not work.<br /> <p><br /> <p>If you are having problems with your <b>Paslode nail gun</b> the first thing you need to do is get the <b>Paslode manual</b> out of the box and checkout how to <b>clean the nail gun</b>. One of the most common causes for these <b>nail guns to have problems</b> is because of a<b> lack of maintenance</b>. If you do not have the <b>manual for your Paslode nailer</b> you can download one here. <a href="http://www.paslode.com/owners-manuals.html">www.paslode.com/owners-manuals.html</a><br /> <p>They have all of the current models and also <b>discontinued model Paslode manuals</b> there.<br /> <p><br /> <p>The manual will also contain <b>troubleshooting information</b> also. The <b>troubleshooting guide</b> can often help you to find the problem with your tool. Do not do the common man thing and be too proud to <b>get out the directions and READ them.</b> There are many tips and helps contained in them that will save you a ton of aggravation later.<br /> <p><br /> <p>Now, there are a few things that I have found out through my experiences with this nail gun that are not in the manual. <br /> <p><br /> <p>First, When the manual tells you that the tool needs to be <b>cleaned and lubed regularly</b> it means that you NEED to do that. Most problems are because of a<b> lack of cleaning and lubing the tool</b>.<br /> <p><br /> <p>Besides that, <b>gas cylinders</b> are a problem sometimes even if they are new. If you just replaced the gas cylinder and the <b>nail gun will not work</b>, try another one. Also, sometimes the end that goes on the gas cylinders will not snap on correctly or completely. You sometimes can still get the cylinder into the gun but it will not work because the top is not attached completely or correctly.<br /> <p><br /> <p>Check that the <b>nails do not get jammed in the magazine</b> and then not push up to the front of the gun. No nails, no work. Paper from the nails can sometimes cause them to bind up and not slide front. Make sure to always use nails that are only for the<b> Paslode nail gun</b>.<br /> <p><br /> <p>The firing pin can also be a problem. The <b>firing pin will bend</b> sometimes, but usually because of lack of the right nails or maintenance. Another problem that can happen is that the<b> o-rings around the firing pin</b> will break or crack. When this happens the gun may not fire or the pin will not return after it shoots a nail. If you are having these problems then check the o-rings both top and mid-pin to make sure they are in good shape. If they are chipped or cracked in anyway the gun will not work correctly.<br /> <p><br /> <p>The <b>battery contacts</b> on these nailers are also a problem. They can get dirt and dust in them or become bent. If they fail to make good contact they can cause the gun to have all types of problems. If you are having unexplained problems then<b> check the contacts of both the battery</b> and the gun. You can clean them with a soft cloth or sometimes with a pencil eraser.<br /> <p><br /> <p>The last but least likely problem is the<b> internal wiring in the nail gun</b>. Because of the violent nature of the gun firing the wiring takes a beating inside the nail gun.<b> Every time the gun fires</b> the vibration can cause the wires to move just a bit and eventually a wire can work loose. If all other things check out then look for wires that do not go anywhere. If there is a wire floating around that has no home then you have found your problem. After adjusting the end of the wire so it is tighter, reconnect the wire and you will be working again.<br /> <p><br /> <p>As you can see there are many things that can go wrong with these nail guns. Because of this there also are many things that you can find online that will help you. <b>E-how.com</b> has some tips that will help. <b>You-tube</b> also has some videos that will show you how to clean and troubleshoot these nail guns. Doing a simple online search will give you many places that can help you and also give you sites from which to buy parts if needed.<br /> <p><br /> <p>If you need parts for your nail gun, here is a good place to get those parts.<br /> <p><br /> <p><a href="http://itwconstructionparts.com/xcart/">http://itwconstructionparts.com/xcart/</a><br /> <p><br /> <p>
on Mar 06, 2011 | Tools & Hardware - Others
Have a nu power gas nail gun fully charged battery full gas cylinder but will not fire nail
Did you take the nails out a check the safety , where the nail comes out ? Sounds like a stick or stuck safety switch . Good Luck !!!!!!!!
Nov 15, 2014 | Air Tools & Compressors
Nail gun shoots 1st nail fine then second is a blank. The gun is clean, there is no jam, they are the right nails. PSI is at 100. Person using gun has used this gun and others for a very long time. ...
Miss fire usually occurs when piston/driver is bent, piston oring worn, lower bumper cracked or missing pieces or upper bumper is cracked. Easy to check. Remove head and pull piston. If bent try to adjust, but be careful, blade breaks easily. Piston should fit snugly in cylinder, if loose, replace piston oring. If oring/plastic ring ok examine lower bumper for cracks and replace as needed. If lower bumper ok, pull out headvalve and examine upper bumper for cracks. If upper bumper ok, pull cylinder and look for loose check band around cylinder. Check band is black rubber and should be placed around cylinder fitting snuggly covering series of holes. Replace parts as needed and lube with silicone paste sold at Lowes in the plumbing department (or white grease). Good luck
Jan 11, 2011 | Porter Cable FactoryReconditioned DA250BR...
On the trigger of my Bostich Spiral load nail gun AND my Bostick trim nail gun air is leaking profusely from the trigger. Nail guns were not in use for about a year. When I first used them this weekend,...
A nail gun works on compressed air.
When you hook the air hose to the gun it fills a cylinder with air pressure.
When you pull the trigger. the cylinder pressure is released onto a firing pin that shoots the nail.
The air pressure line is also connected to the trigger and therefore the trigger has to be sealed.
When ever using a nail gun, you add a bit of gun oil in the back of the gun (not 3-in-1motor oil, it has to be non-detergent gun oil)
If you haven't used the gun in a while, it is best to oil up the gun and let the oil run down into the gun.
If you use anything but gun oil, the seals will give out.
Your trigger seal has given out. It is probably an 'O' ring. You can access it by taking it apart. Look for the O ring.
Bostich makes re-build kits for the different guns that you can buy on-line.
Back when I was in construction, there were several nail gun shops that sold and serviced nail guns, and sold nails to the contractors. I don't know if that business model is still active or if you have to send the guns to Bostich service center.
Oct 18, 2010 | Garden
FC350 nailer problems
Assuming that there are no air leaks you could try a simple trick to solve your problem with not feeding nail. As you suspect, the driver is not returning to top position thus not allowing nail to move into position. All that you need is some teflon tape and some silicone paste both available at Lowes in the plumbing department. Remove the head of the gun being carefull not to tear gasket and pull out the driver and cylinder. There is a check valve that looks like black rubberband on outer part of cylinder covering small holes . Make sure band is in place and fits snuggly. This band is what caused piston to return. Check that the bumper at the bottom of the cylinder is whole and not cracked. Replace as needed. Clean orings to cylinder spacer, lube and reinstall. Remove the oring on the driver and wind teflon tape into oring grove and replace the oring. Apply only enough tape to make the driver fit snugly in the cylinder. Lube cylinder and oring with silicone paste. Reassemble driver and head. This should get pressure to driver up to normal. If it works your done. Later you could order an oring kit to reseal your gun (cost about $12) Good luck
Jul 25, 2010 | Porter Cable Cable No. FC350A Clipped Head...
Nail fails to fire
The older design was trouble free. Now this new redesign fr350a has been having trouble with stuck headvalve (If you have the valve with quadring instead of oring). Seems like the orings/headvalve fit too tight in head.
The problem that you are describing indicates that the driver is not returning to full top position and not allowing nails to feed forward because driver is blocking path. I would try lubing gun with silicone paste lube (available at Lowes in the plumbing department, used to lube faucet washers). Remove head and pop out headvalve. Lube all oring contact surfaces. You should be able to press in headvalve with your thumbs and valve should return when you release. Next check that the driver is not bent. Driver should move freely but not drop down cylinder under its own weight. Should not be hard to push driver down cylinder. Finally make sure (check seal) is in place located on outer part of cylinder lower half. (remove cylinder from gun, check seal looks like rubber band and fits in a groove, some guns have an oring instead, the check seal is what causes the piston to return to top, is piston oring is too tight or driver is bent or air pressure is too low, the piston will not make it to top )
When new, all parts fit very tight within this gun. The oil that is recommended for this gun is too thin. It works better with silicone paste. Good luck and post again if you have other questions.
Jun 18, 2010 | Porter Cable Cable No. FR350A Rnd Head...
Nail gun
have you activated the fuel cell by pressing the black nozzle down onto the cylinder?
Jul 27, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Nail Guns Types
The real different between nail gun's models are the sort of power supply they use. A nail gun can be powered by compressed air, electricity or batteries, or electromagnetism. Some small guns are powered by butane, a fuel that causes a small explosive charge to drive the nail into the wood. The most common type of nail gun is the pneumatic nailer, which works with compressed air.
Aug 27, 2008 | Stanley Pneu Roof Stapler
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
