My dvd drive is working but cant display any condent in cd or dvd
  • Computers & ... Master
  • 27,725 Answers
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Mar 28, 2011
Can lite-on-ltn4865 48x play dvd movies
If your Drive is a CD-Rome drive, surely it cant, for the drive cant read dvd disc. Replace the drive of yours with DVD-Rom or DVD-RW in order to play dvd disc, DVD-RW simply has the added capablity to burn on DVD discs
Jan 12, 2011 | Lite On (LTN486S) Internal 48x CD-ROM...
Just looking for a driver fro crwd 2400p cdplayer. The OS the driver is needed for is Windows XP. This peripheral is a PCMCIA cdrw dvd player and was bought from PSISM.com (they keep saying this item is...
Follow the steps given below
Connect the External CDRW to the PC and you should be able to find the green light glowing and CDRW should make some noise like spinning.
Press the Eject button the CDRW and It should open. Put in the Software disk that you have received from your PC manufacturer and it should display the contents on the PC Screen
If not, Click on START button - Click on My Computer - You should find the CDRW displayed in Drives Location.
Double click on it and it should display the CD Contents.
This indicated the CDRW is working.
Nov 09, 2010 | EXP Computer EXP CRWD 2400P (CRWD-2400P)...
Unable to open cd/dvd drive
hi
if you mean you cant open drive door
there is an emergency hole that you cat put a pin in to open i
if you mean it cant read the cd/dvd try to test with a original cd (silver) if it works, that means your drive need service
if you cant see you cdrom drive icon in my computer
push your drive into (it may be disconnected)
by
Jul 02, 2010 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Laptop Optiarc DVD RW AD 7530 B is not reading CD or DVD media. 1.DVD icon displayed in My Computer. 2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off...
2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off within few seconds.
3.DVD drive in My Computer when clicked shows empty folder
4.Uninstalled DVD drivers in Device Manager and let windows find it on reboot
5.Issue still persists.
6.Right now external DVD RW works perfect.
Please help
Oct 29, 2009 | Sony NEC Optiarc AD-7530B 8x DVD?±RW DL...
My aspire DVD drive will not work
I see ..if it reads the cd and dvd-s it is probably good and all you have to do is to reinstall the program that u use to burn disks ..but about the second issue with the sound ..try to reinstall the sound driver ..maybe its corrupt ..also look at the settings in the sound driver to see if it isn't maybe locked on left from balance ..but if you cant figure just reinstall the sound driver too ...
By the way if you was using vista program to burn dvd an cd ...just reinstall the whole machine ..it might just fix all the problems..I suspect that its bug-ed
Aug 02, 2009 | Acer Aspire 5100 Notebook
I am using DELL Vostro 1510 Laptop.recently a dvd got stucked up inside the Drive .The thing is that the drive is not having manual Eject Button. At this time the system got hanged up,Even i tried clciking...
Mechanical you need to take the drive out and disassemble the casing. I seen one that the CD actully broke into millions of pieces. I was not there to experience the happening but was there to help save the drive.
Jul 27, 2009 | Dell Vostro 1510 Motherboard System Board...
Acer aspire 6920 18.4 inch screen! I cant get blue ray dvds
According to the ACER Aspire 6920 specs, it does not have a Blue-ray player only DVD CD R/W drive. Therefore it cannot play blue-ray movie disks.
The specs of the DVD drive are as follows :-
Optical Storage
  • Type DVD±RW (±R DL) / DVD-RAM - Integrated
  • CD / DVD read speed 24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
  • CD / DVD write speed 16x (CD) / 8x (DVD±R) / 4x (DVD±R DL)
  • CD / DVD rewrite speed 16x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Jul 24, 2009 | Acer Aspire 6920-6422 Notebook
My dvd drive cant read some cds
either the cds are too scratched or have finger prints or marks on them and need a clean or you need to get a laser lense cleaner to try and clean the lense on your cd / dvd drive and if that does not work then I would test the discs that do not work in that dvd drive in another computer and if that works then may need to replace the drive
Jul 01, 2009 | Teac (DW-224EA-AM6) CD-RW/DVD-ROM (Combo)...
Cd/dvd dosen work pleace geimy a solution
i cant get you. cd/dvd is not working or cd/dvd rom drive is not working ? To work cd/dvd rom drive properly, Make sure the Jumper settings of the drive is set to slave or else remove all the jumpers from the cd/dvd rom drive, it automatically sets to slave. Check the power cable and the FRC(flat ribbon cable) of the cd/dvd rom drive. Hopefully it should work. Thank you.
Sep 11, 2008 | Computers & Internet
Cant play DVD on CD-RW/DVD-ROM Combo Drive
Assuming you have tried different makes of cd or dvd disks, it's a classic drive failure problem where the laser can no longer burn or read dvd's, but may still be able to read cd's only. You will have to replace the drive, they are quite inexpensive, and very easy to fit.
Aug 10, 2007 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
