Question about Brother DCP-350C InkJet Printer
My brother printer dcpj125 error paper jam every time i print..
SOURCE: paper jam, and I don't
I had the same problem.  I had removed all the visible paper and when it came back on made some awful noises and flashed "paper jam".
I even moved the roller forward and backward (after having uplugged the device.  I did this repeatedly and the "paper jam" alert continued (along with the awful noise).
As a last resort I thought I would just take it apart and hope to get it back together but figured it was a sensor or something along that line if I could not find any paper anywhere
with the machine unplugged (it would not shut down), I opened the lid I used a flashligt to look around trying to figure out how to take it apart.
It then dawned on me that I had not moved the print head over and using a screwdriver I gently pushed it to the center of the bar.  When I looked inside with a flashlight, there was the paper jam way inside under the cover.
I used some needlenose to reach in and took the paper out and it is now working fine.
I hope this helps, but you may have to search really deep into the device.
Posted on Dec 10, 2008
Mix-it-up
  • 832 Answers
SOURCE: Brother mfc845cw
See picture how to do that :-)
Posted on Oct 02, 2007
  • 4 Answers
SOURCE: Epson Stylus CX8400 Paper Jam Error
I have the same exact problem of paper half torn removed but I can not see the other half anywhere. The printer has hardly worked for at the most six pages and now showing paper jam error. How do I fix it?
Posted on Aug 12, 2008
  • 3 Answers
SOURCE: canon ip1880 continous paper jam error on screen
first you turn off your p.
Posted on Mar 26, 2009
SOURCE: how do you reset brother dcp-117c printer to
press # 6 button and disconnect the power cable..press them both and reconnect that..reset is done
Posted on Mar 24, 2010
How to clear "unable to init.73" in brother dcp-j125 printer?
Hi
This is a mechanical problem of some description. Open the scanner cover and remove any foreign objects and paper scraps from inside the machine. Then, disconnect the machine from the power for several minutes and reconnect it. This should clear the error, but if it does not repeat the procedure making absolutely certain there is nothing in the printer obstructing the paper path.
You can get a manual for this machine here:
http://data.manualslib.com/pdf2/36/3557/355673-brother/dcpj125.pdf?5f68814c3d046699f5763ce9725a25e1
and there is a manual resetting procedure that you might try here:
Reset Methods for All Brother Printer Models
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 29, 2014 | Brother Dcp-J125 Compact A4 Colour Inkjet...
DCP-J125 what is "machine error 31"
Paper jam, do a thorough inspection looking for any stuck bits of paper.
Jul 12, 2014 | Brother DCPJ125 All-In-One Inkjet Printer
Troubleshooting oh printer
Look in the user manual under errors or go to the Brothers support website and look up the model and error codes.Brother Printer Support
Feb 05, 2014 | Brother DCPJ125 All-In-One Inkjet Printer
UN ABLE TO CLEAN 50
paper jam, or some sensor error, clean the sensor under the pump, to clear the error.
Jan 24, 2014 | Brother DCPJ125 All-In-One Inkjet Printer
Brother 540cn Printer won't print and displays unable to print 50. The photo capture button also flashes
The error code 50 indicates a paper jam condition. Whether there's actually still paper jammed or not, it's sensors are still indicating a jam. Check again for a bit of paper, or there may be a faulty sensor.
Check out this link: Brother for further information.
Feb 10, 2013 | Office Equipment & Supplies
UNABLE TO INIT 4F BROTHER DCP-J125
my brother printer when on the screen show unable to print 4f
model printer brother dcp-j125 how to solve the problem ?
Dec 16, 2011 | Brother DCPJ125 All-In-One Inkjet Printer
I have brother dcp-j125..when i start the print more than 2 to 3 page try to go to the print.. what can i do ?
TRY USING LESS PAPER ...AND FAN YOUR PAPER, SO THEY DON'T STICK TOGETHER.
YOU ALSO MIGHT CHECK YOUR PRINTER SPEED...YOU CAN DO THIS BY...CLICK ON YOUR START BUTTON, TYPE IN PRINTER...CLICK ON THE PRINTER MENTIONED, GO TO PROPERTIES, SELECT THE SPEED...YOU MAY HAVE IT SET ON QUICK PRINT? TRY CHECKING THE NORMAL SPEED!
HOPE THIS HELPS!
Aug 31, 2011 | Brother DCPJ125 All-In-One Inkjet Printer
Brother DCP-350C InkJet Printer Logo
525 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
