Question about Nikon F80 35mm SLR Camera
Shutter release assembly problem- need replacement
Hello , i'm sakthi murugan from south india, having a f80 nikon 35mm film SLR camera. for the past 3 to 4 months i haven't used it and now the shutter release assembly is struck and the guys in the nikon service center are asking me to write a mail to the company to get a replacement. is there anyother possibilities
please help
sakthi
[email protected]
    Guru:
  • Nikon Expert
  • 362 Answers
Have you tried replacing the batteries?
Posted on Nov 20, 2008
SOURCE:
Nikon FM10 will only release shutter with cable
Hello Blair,
I too like old school camera, mine are the N2000, N6006, N80, and F100. First without film in the camera I would attempt to release the shutter. If it does then there is something going on with the film transfer causing a bind.
However, If it continues not to release the shutter I would put the FM10 on the shelf then go to KEH.com for another. Just now checked KEH.com, 2014-05-26, a FM10 in EX condition is $89, EX+ condition $99. That would be a much better move than repairing yours and less expensive.
Cordially
May 25, 2014 | Nikon FM10 35mm SLR Camera
Will a nikon n2000 turn on without a lens and film?
The camera should operate perfectly fine without a lens. It should also operate perfectly fine without film (other than for not taking any pictures, of course).
I know this is stupid, but make sure the batteries are inserted in the proper direction. Then make sure the film advance mode selector around the shutter release button is not in the "L" position. L is for Lock, S is for single-frame, and C is for continuous.
If you need a manual you may download a copy here.
Apr 27, 2012 | Nikon N2000 35mm SLR Camera
Loss oft focus area selector button cover on nikon f80.
You can order the part from
http://uscamera.com/1k208-250.htm
Jan 09, 2011 | Nikon F80 (n80) Qd 35mm Slr Film Camera +2...
Can't load the camera, it is a nikonF80
The F80 was called the N80 in North America. You can download the N80 manual from
http://butkus.org/chinon/nikon/nikon_n80/nikon_n80.htm
You'll find illustrated instruction for loading film beginning on page 20.
Dec 16, 2010 | Nikon F80 35mm SLR Camera
What types of film can i use with my nikon f80?
You can use almost any 35mm (size 135) film available. Black&white, color negative (print), color transparency (slide). The only restriction is that you can't use infrared film since the camera uses infrared light internally. Any brand will work, as the film size and cartridge are standardized.
Sep 28, 2010 | Nikon F80 35mm SLR Camera
Weird error message
Whenever you have a problem like this, start with the simple fix. Reset the electronics by removing the batteries, waiting a few seconds and replacing them.
May 08, 2008 | Nikon F80 35mm SLR Camera
Nikon N80 Shutter? Issue
dear ben505,
This could be due to the shutter leaking light from the top or bottom, and it could also be caused by light leaking in through the camera back. The most common cause of edge fogging is light leaking in through the film canister, which happens over time if the unused film is not stored properly. If this is a high ISO film(400 and up) and you load your film into the camera in a very bright enviroment that can also cause film fogging. Try a brand new roll of film and if that doesn't resolve the problem I would have it looked at by a camera service technician.
Sincerely,
Agent Allan
Go Ahead. Use Us.
Apr 15, 2008 | Nikon F80 35mm SLR Camera
Re: Shutter Wont click
Hi , check everything set c amera speed to 60/seconds auto or manual / check also the the camera shutter blade , open the lense and close to activate the shutter blade .
Feb 17, 2008 | Nikon F80 35mm SLR Camera
Nikon F80 35mm SLR Camera Logo
100 people viewed this question
Top Nikon Photography Experts
Ric Donato
pictureman4u
Jeff
Jeff
Are you a Nikon Photography Expert? Answer questions, earn points and help others
