Question about Frigidaire Freezer Refrigeration White Upright Large Manual Defrost Freezer Model FFU2124DW
Kitchen Aid Refrigerator Mod: KTRS22MJWHOO Date:09-00
Condensate line must be clogged. Ice/water in bottom of interior. See a tube behind panel in back which apparently used to drain water into the pan beneath, but, cannot see a corresponding drain hole on the floor of the interior.
How do I attempt to unstop line?
  • minihaahaa Aug 04, 2008
    What a croc this "free" cite is
    Problem Solver:
  • 12 Answers
By blasting the hole with compressed air
Posted on Aug 05, 2008
Frigidaire FFHS2311LWD has water pooling up and freezing bottom drawer and lower vent. Drain tube doesn't seem to be clogged. Water leaks onto floor some days.
the drain tube is most likely clogged. if the lower vent is freezing up there is no way to confirm because it is covered with ice. the reason water leaks onto the floor is, the refrigerator goes into defrost, frost melts and runs down the ice to the door. use a hair dryer to remove all ice, then use hot water to check drain. drain tube may be up to a foot long and may have a trap. you may have to go in through the back to gain access to the drain
Oct 22, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Ice build up on floor of freezer. can't figure where it is coming from. There is not a drain on bottom panel. Any suggestiuons? Frigidaire model no AFU2067BWL2
I know that your freezer shows a drain in its floor but there is also a drain behind the rear wall and at the bottom of a tray that collects the water during defrost and is surposed to drain that water that comes during defrost and then drains to a pan below the refrigerator and next to compressor. The solution will be to clean out this drain that is hidden from site behind the rear wall. I am pretty sure you are having a defrost drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers.This is not always the same with every model as you may see frozen ice flowing down ther rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian He has been around a good bit and deserves credit for his contributions. Here is another way to make this look more si mple in clip below. TechnicianBrian.com And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! This is a common tip so I will be placing this post and add as we go new ideas listed in Sea Breeze Tips Section. If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
Feb 22, 2013 | Freezers
The refrigerator has two halves. One is the freezer side and the other refrigerator Water is leaking from the freezer side. Appears to be a problem with the defroster. I do not have the model #
One of two things is happening, there is a heater inside your condensate line that prevents the water from freezing, this may no be working. You can check this with an amp meter if you have one. Or your condensate line is clogged with sludge which would cause the water to not drain and freeze. You will need to take the drain apart to defrost the ice and blow out your line.
Sep 16, 2011 | Continental Freezer Wide...
I have a Kenmore Model # 253.62812202 refrigerator. It collects water at the bottom of the vegee and fruit trays at the bottom of the refrigerator which eventually leaks out onto the kitchen floor. Does...
It has a clogged drain tube and bottom trays is already full.
De-clogged it using a solid wire, match enough to penetrate the drain tube.
Insert solid wire slowly to the drain tube, back and forth.
Put water to clean and rinse drain tube.
Regularly check drain tube for clogged and tray for full water.
Good luck.
Jun 27, 2011 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Ice keeps forming on the bottom of the freezer - like a leak on the back side flows into the bottom toward the door.
When a refrigerator leaks water like yours, it is common for the problem to be nothing more than a clogged defrost drain. When the unit defrosts itself, the frost melt water drips into a pan underneath the evaporator in the freezer, and goes through a tube from there to the bottom outside of the unit. Since the water cant go down this drain, it backs up on the freezer floor, then eventually the kitchen floor.
Oct 06, 2010 | Amana 15.0 cu. ft. / 425 liter Upright...
No drain plug in freezer to drain water out when defrosting?
The drain hole is behind the back wall underneath the evaporator coil. Im guessing you have ice on the freezer floor. This is because the drain tubing from the freezer to the drain pan underneath is clogged. There will likely be ice that will need to be defrosted in the drain tubing in order to get to the clog. Once the ice is removed, I use compressed air when I perform this refrigerator repair service.
Sep 27, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Sears Freezer, Model 253 9284013-unable to locate manual, nor online. Freezer did not maintain freezing level, fish thawed slightly, dripping liquid onto bottom interior. It froze over. On bottom, at the...
Your problem could be caused by a clogged drainage tube. even though you may have removed the ice it may still have a clog. my suggestion would be to take all of the contents out of your fridge and let it sit unplugged for atleast 24-48 hours with the doors open this will eliminate any left over ice that may be clogging your drain tube. if this dosent help then you may have a defrost heater problem, or possibly a defrost termination switch problem. as for the smell i know that vinegar works well for getting rid of odor. ther eis also a product you can purchase called fridge aid, it is a charcoal based air purifier and should work well.
Oct 11, 2009 | Kenmore Freezers
Our upright freezer drips water on the floor. We believe the seal is bad since ice also forms inside at the top of the door. Is the seal replaceable or should we buy a new unit?
Self-defrosting refrigerators/freezers dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator/freezer compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Aug 16, 2009 | Freezers
Ice at the bottom of freezer ice at the bottom of freezer, defrost water not draining
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
May 30, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Defroster leaks
you have a cloged evap. drain. the rf is defrosting properly but with the drain be clogged the water has to go somewhere which is generally in the crisper draws on top and bottom models. two way to clear up this issue. turn rf OFF for at least 48 to 72 hrs. to allow the drain to de-ice or take matters into your own hands and take the back panel off of the freezer and using boiling hot water pour it down the evap. drain tube until it flows like you just flushed a tiolet
Jun 01, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
150 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
