Question about PAC Electronics PAC TR7 Universal. Trigger Module
PAC-TR7 brake/video bypass for Alpine IVA-W200, help with wiring. I tried wiring them with the directions that came with the module atleast 3 times but each try had negative results.
Cant set the time
What you need to do is buy a PAC TR7 universal trigger module.Without this module you have to do some sequence of events with your brake and parking brake.and it wont let you program the unit. By default the TR7 is pre programmed for the video bypass. Even if you don't have any kind of video in your system you need this TR7 setup to program your IXA W407.
Nov 22, 2010 | Alpine iXA-W404
TV says locked out for your protection. how do I bypass that? Also how do i brighten the screen?
pac tr7 module will bypass the video lock. the lock comes on if you have the aux on while in drive. shuts off the screen so you cant watch movies and drive. go to amazon or google PAC-tr7 module. costs between 15-30 bucks depending on where you buy it. Very simple hook up, just follow the wire chart.
Nov 10, 2009 | Alpine CVA-1005 Car Video Player
How do i bypass the parking break saftey feature on my Alpine IVA-W205
put a switch on the brake wire make sure the switch is on the off position. the switch should have two wires ,one wire connects to the brake wire the next wire ground it to the car .then turn on the stereo put a dvd in and turn the swicth on and off several times .It should come on
Oct 02, 2009 | Alpine IVA-W205 Car DVD Player
Video is off for you safety ?
Mar 24, 2009 | Alpine NVE-P1 Navigation Add-in Unit for...
How do i bypass the parking brake switch on my eonon
all u gotta do it the light pink wire that has brake label on it, connect it to the casing of the dvd itself, thats what I did, works like a charm, u might gonna have to run it through an opening of the casing and twist it around itself to hold in place
Sep 24, 2008 | Alpine IVA-D310 Car DVD Player
Alpine IVA-W200
you need to put a toogle switch
Nov 13, 2007 | Alpine IVA-W200 2-DIN DVD/CD/MP3/WMA...
Can't view the movie
it isn't bypassed properly. recheck bypass wiring.
Sep 13, 2007 | Alpine IVA-W200 2-DIN DVD/CD/MP3/WMA...
Driving me Crazy
well i have a alpine cva1004r multimedia screen.and the way inwich i use my screen when the vehicle is in motion is, i connect the wire(normally brown and yellow on alpine screens)which goes to the hand brake(so when you let the hand brake of it cuts the screen out)direct to earth as this wire is only a earth. if you have allready done this then all i can suggest is to turn the heater vents off next to your head unit. hope this helps.
Mar 28, 2007 | Alpine IVA-W200 2-DIN DVD/CD/MP3/WMA...
PAC Electronics PAC TR7 Universal. Trigger Module Logo
124 people viewed this question
Top PAC Electronics Car Audio & Video Experts
xxxxxx xxx
Are you a PAC Electronics Car Audio and Video Expert? Answer questions, earn points and help others
