Question about Motorola Mobility RAZR V3i Cellular Phone
Can,t read a memory card - Motorola Mobility RAZR V3i Cellular Phone
  • 17,130 Answers
Possible that the phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Posted on Mar 28, 2011
My memory card is not working
Memory cards, also called memory sticks or MS cards, can create problems with a computer. Sometimes, a computer will not read the card or errors cause problems when removing files from the card to put them onto the computer.
Problems range from a virus on the memory card to inappropriate software on the computer. Fixing the problem partly depends on the cause of the problem, but making the card work is simple and takes only a few minutes.
Scan for viruses. Some viruses or worms infect MS cards.
A computer that suspects a virus might interfere with the memory card as a result.
Look for viruses or problems with the anti-virus software that won't allow the memory card to open. If a virus if found, remove the virus through the anti-virus software before opening the memory card.
Check that the computer has the appropriate software installed to read the card.
Some MS cards or memory sticks might require more updated software or specific software that is not on the computer.
If the software is installed, look for current updates and download any updates to determine if the problem is old software.
Open the control panel.
Click on "Add New Hardware" and see if it is available.
If the hardware for the memory card is not installed on the computer, this will allow installation.
Once installed, the card should read.
If the memory card is not showing up, the problem is often damage to the card, which prevents reading the card. If the card is damaged, it must be replaced.
Use an adapter.
Some memory cards are not designed for reading in a computer directly and require the appropriate adapter.
The adapter changes the data to the appropriate system for the computer to read it.
Hope this helps
Nov 16, 2012 | Electronics - Others
Cannot read 4gb memory card
Check that your camera can read the format of your memory card.
There are SD memory cards and also SDHC memory cards.
The SDHC memory cards are a new format that cannot be read or written to by many cameras.
Mar 13, 2011 | Cameras
My cellphone dose not read memory card and i can't format it
maybe your memory card is damaged or corrupted... check it by inserting other memory card... if your phone CAN read other memory card it means that your memory card is damaged or corrupted... and if the other memory card you inserted and still the same problem persist that your phone thus not read memory card... maybe there is something wrong with your phone... it can't detect a memory card...
options:
- replace new memory card (if damaged)
- go to the cellphone technician and have that phone fix..
goodluck...
Feb 02, 2011 | Nokia 5130 Cellular Phone
Cant read my m2 memory card after installing some games on my phone
hi....
This is because your memory card may be affected by virus.please delete the games which you installed and try weather it is reading your memory card.
if it is not reading please scan your memory card with proper anti virus,stil the problem presists then format your memory card it wil be ok.
if you can please take a back up of your memory card as when you format the details will be lost.
thanx
Jul 16, 2010 | SanDisk 2GB Memory Stick Micro M2 Memory...
My camera will not read my memory card anymore. It is only using the memory from the camera. How can I get it to read the memory card
Confirm first whether the memory card is still good or bad by using a card reader, put the camera memory card into the card reader then connect it to your system, see whether the system will read your card, if the system doesn't read it, it simply implies that memory card is bad and you need to replace it with a genuine memory card, but if it works it implies that the card slot on the camera is bad. so, your either need to service your camera or you replace the memory card. Thanks
Sep 24, 2009 | HP Photosmart M417 Digital Camera
Memory card full but computer cant read it
Maybe the pins in the memory card are broken or there may be dust lodged in the memory card :D
Dec 08, 2008 | SanDisk 2GB microSD Memory Card
Not reading memory card; keeps saying reinsert memory card, diplays error C 13
not reading memory card; keeps saying reinsert memory card, diplays error C 1
Aug 04, 2008 | Cameras
Memory Card Reader
when you install the software and connect the phonevia USB cable the memory card should be read as DCIM
Jun 22, 2008 | Cell Phones
Psp not reading memory card
Have you try other memory card ? If other card works then means your old memory card is broken. You need a new card !! In fact I sell cheap 4Gb memory card ...
Jul 28, 2007 | Sony PlayStation Portable (PSP) Console
Motorola Mobility RAZR V3i Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
