Question about Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
I have a dual fuel Dacor ERD30 range that will not stay hot. Lately, it will heat up to the desired temperature and beep to indicate it is ready, but then will not hold the temperature. And strangely, if I turn the oven off, the fan will turn off right away. Usually, it runs long after the oven has been turned off. Any ideas? Gratia
Sounds similar to what mine is doing.
Since Dacor uses the gas broiler to preheat the oven, the problem is that the lower heating element isn't getting power.
I took out the element and verified that the element is still good, but no AC voltage coming from the relay board to the element.
Try setting on the Pure Convection mode - it will probably heat up and hold the temp fairly well - that still doesn't do any good if you need to bake something covered (convection modes are useless for covered container..
Posted on Aug 16, 2011
Oven turns off without warning
I had to replace the thermo coupler in mine. Would heat up then go out.
Aug 17, 2014 | Dacor Epicure ERD30 Dual Fuel (Electric...
F3 error. Beeping wont stop.
Hi miketack,
If your Dacor is getting an F3 error code and wont stop beeping this is because of shorted oven temperature sensor or RTD. You can fix this by checking sensor harness and harness connection between oven sensor and oven control. In case that wiring is ok you need to replace oven temperature sensor (RTD). You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model number ready when you call.
Hope this helps.
Thank you for using FixYa.
May 21, 2011 | Dacor Epicure ERD30 Dual Fuel (Electric...
Why dont my burners stay lit on my Dacor Dual Fuel ERSD30 range? They work fine for about 30 seconds, then stop.
hello,it's duely because the gas supply is not being supplied as it is suppose too,kindly check if you are not short of gas or probably if the hose that supplies the gas is not having thorough flow of the gas.
wish you good luck,
take care.
Jun 09, 2010 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor rsd305
Once you replace the oven control again....never use self clean on any oven....unless you want to replace parts.
Before you replace the control...look inside the control panel for a resettable thermal fuse.
Mar 10, 2009 | Dacor Epicure ERD30 Dual Fuel (Electric...
ERD36 Oven over heats
If the oven stays off when turned off then it is definitely a controller board problem. - that would mean the element is coming on and there is no control - changed the controller
Regards
Sep 11, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
F1 Error Dacor oven
I'm Neil and glad to be at your service!
This time you need to call service!
For a good service you might try,
A&E Factory service
1-800-905-9505 7days / 24hours Nation Wide
Please give me a solution rating here at fixya.com
Thank You
Neil
Jul 07, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range Logo
521 people viewed this question
Top Dacor Kitchen Ranges Experts
Oloyede Monsuru
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
