Question about Acer Computers & Internet
How to repair broken power jack AS5251-1513-US
  • Eleazar Cruz Mar 28, 2011
    Thanks I figured it would be that answer but wasn't sure...
    Guru:
  • 1,833 Answers
According to your problem there is no way to repair a broken power jack. For solution you have to purchase a compatible 12 volt power jack. Solder the new power jack properly to the motherboard.
But the solution is to replace the motherboard. You can contact with nearest Acer service center /dealer to get the motherboard.
Posted on Mar 28, 2011
Dropped toshiba PSC2EU-00U02H and brock power jack and charger
MOST power jacks are repairable, though they require an experienced person to disassemble the computer and replace the jack. Older laptops have the jack soldered to the motherboard and require a complete disassembly, while newer laptops have the power jack on a wired connector that plugs into the motherboard (MUCH easier to fix).
Here's a link to YouTube video for a Toshiba Satellite C655 (I think that's your model) that shows the entire procedure:
http://www.youtube.com/watch?v=Q76HHXJVvAg
You can check with local computer repair services in your area, though I generally find better prices online.
If the Charger plug is broken, you can order a replacement charger online as well.
Dec 29, 2012 | Computers & Internet
SAMSUNG NP R430 POWER JACK
There is something seriously wrong with the power jack for it to get very hot. I doubt replacing the power jack will fix this problem. The laptop needs to be repaired by a specialist.
Jul 28, 2012 | Samsung R430 Notebook
Hi when plug in my ac adapter into lenovo x61 the tablet will not turn on i try it on other computer and it will on what happen?
LOL, sounds like your tablet has seen it's better days. See why HP got out of the Tablet business? They are nothing but trouble.
Apr 08, 2012 | Lenovo Tablets & eReaders
My power jack is broken. Need directions on how
You need to take the unit apart down to the system board. Sorry, I do not have the sefrvice manual.
The link below shows how to resolder the connector on the system board.
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Nov 30, 2009 | Lenovo IdeaPad S10-1208U Netbook
REPLACING A BROKEN POWER JACK ON A SONY VAIO
Hi:
The power jacks can be bought on line for less than $10, but the fun part is the repair. The laptop must be dis assembled to get at the power jack, and when you do get to it, it takes a deft hand and soldering skills to swap one out successfully.
I have done a few and am personally only about 50% successful. There are electronics shops that swap out the power jacks for about $150, and guarrantee their work.
Nov 22, 2009 | Computers & Internet
Power jack loose on mother board advent 5303
If the jack is just broken loose then you should be able to disassemble the laptop and resolder the jack back onto the motherboard. If the jack is broken then you will need to get a replacement jack and change it out. You can get power jacks from several places on the internet including Ebay.com If you don't want to try the repair yourself we have a repair service and can do it for you. We charge $55 + return shipping. Let me know if you have any additional questions.
Buddy
Corporate Computer
www.ccl-la.com
Sep 13, 2009 | Televison & Video
MY GATEWAY LAPTOP NO LONGER RECEIVES POWER.
Motherboard or harddrive? I'm betting it's more towards the motherboard. The DC Power Jack to be more specific. This is the port where the AC adapter, (Charger), plug is plugged into.
The DC Power Jack is not much bigger, than the plug for the AC adapter that plugs into it. There are small pin leads that are on the bottom of this jack, and they go through the motherboard, and are soldered to the motherboard.
Accidental bumping of the AC adapter plug, while plugged into the DC Power Jack, can damage the jack. It can break the connections for the adapter plug, and/or can crack the solder joints for those small pin leads.
[Laptops use DC electricity. A flashlight battery, and a laptop battery, are examples of stored DC electricity. DC electricity has two poles. Positive and Negative. The DC Power Jack has two connections. Positive and Negative. {Even if the DC Power Jack has multiple holes in it]
There is also another known problem associated with DC Power Jacks. It may stem from a bad motherboard design.
More to the point, the area where the DC Power Jack mounts on the motherboard. In this design, the DC Power Jack motherboard area, is almost a separate part of the motherboard. It's shaped like a Peninsula. (Think of an island, with one side connected to the mainland)
This peninsula shape, has the tendency to crack away from the main body of the motherboard. Circuit traces are broken.
When the AC adapter plug is setting in a certain position, it presses the two broken halves of the circuit traces together, for a momentary contact. As the AC adapter plug is moved from this position, the circuit trace halves are moved apart, and there is no contact.
(No distribution of electricity from one circuit trace half, to the other circuit trace half. Think of a circuit trace as a very, thin, flat copper wire. When a circuit trace is broken, there is essentially a wire that is broken into two parts)
Solution?
See if the DC Power Jack can be repaired, (Solder joint connections re-soldered), or replaced.
If the DC Power Jack motherboard area is the aforementioned peninsula shape, it may require replacement of the motherboard.
There are very FEW, computer repair shops that have the technical expertise to replace a DC Power Jack. Easy fix is to simply replace the motherboard. (More $$$$$ too)
However, some laptops DO require replacement of the motherboard for this repair.
Bad motherboard design, for the DC Power Jack area on the motherboard.
Re-solder DC Power Jack solder joints? (IF, this is the problem) Average is $50 to $75 (US)
Replace DC Power Jack? Average is $125 to $150. (US)
Replace motherboard? Depends on the Gateway model. Could be $225 to $400 (US)
[Yes, most of the time the cost warrants just replacing the laptop itself, as the cost of replacing, is close to the repair cost)
Just to SHOW you ab average DC Power Jack, and the repair involved of replacing. (Doesn't show you, that the entire laptop needs to be disassembled, down to the bare motherboard in hand)
This is NOT a recommendation to replace the DC Power Jack yourself! It is just for knowledge of what is partially involved. (You can accidentally burn the motherboard when desoldering, or soldering, rendering the motherboard useless)
Sep 09, 2009 | Computers & Internet
Power jack connection broken on HP Omnibook xe3
The jack in itself is quite robust, it is the soldering to the board that sometimes lack substance, also rough usage in the way of forcing the plug in and pulling it out roughly contributes to the demise of the soldering. If the jack is still intact take it to a repair shop and if the pads haven't broken away from the printed cirsuit board have them reflow and maybe add a bit of extra solder to the joints.
Apr 15, 2009 | Computers & Internet
DC input jack broken
Yes it's not usually something that can be repaired at home. Your chances are better if the jack just seems loose and not actually broken, however replacing it is better. I work for a Laptop Repair Shop in NYC and we deal with this issue frequently.
Dec 25, 2008 | Acer Aspire 5500 5570-2609 Laptop
Power connect within a panasonic cf 28 toughbook has broken. any help would be a appreciated. mark
this is a pretty straight forward repair. using a small tip soldering iron 15 watt solder the + lead and the - lead back 2 the board. if the pwr jack its self is broken a electronics store OTHER than radio shack will probably have what U need in stock. I myself Use ORVACS in anaheim. Only hard part is getting to the power jack for repair. download a manual to see
dissasembly instructions ..
Mar 08, 2008 | Computers & Internet
Computers & Internet Logo
88 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
