Question about Cameras
My finepix j150w wont turn on. tried a brand new battery and still no luck
  • Cameras Master
  • 17,130 Answers
Can be due to errors in the camera main processor board if the battery is good , the voltages were checked to be correct.
You will need to open the camera to get access to the board from where the power can be read on the processor. If the processor is not responding even with +B then the board must be changed. take estimate and decide.
Posted on Mar 28, 2011
I lost my fujifilm finepix jx 400 battary charger and i want to use my usb cable to charge it is it possible i plug it but it seems doesn't charge
The JX-400 is a camera, not a battery charger. Connecting it to a computer's USB port simply drains the battery faster since the camera has to expend juice communicating with the computer (even if only to say it has nothing to say).
One source for a battery charger is http://www.overstock.com/Electronics/BasAcc-Battery-Charger-Set-for-NP-45-Fuji-FinePix-S610-J110-J150W/7124327/product.html?searchidx=3
Feb 15, 2014 | Cameras
User manual for fujifilm finepix j150w
You may download a copy of the manual here.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Mar 19, 2012 | FUJIFILM FinePix J150w Compact Camera...
I tried ALL the suggestionas for my fuji fine pix J150W camara. still have the message of "frame no full". Thanks for all the efforts. I will be buying a new camara.
Don't buy a new camera yet. This solution will help you correct your camera problem. If this helps consider voting me.
1). Insert a new memory card.
2). Format the memory card using the FORMAT function in SET-UP menu in the camera.
3). Set RENEW as the FRAME NO. setting in the SET-UP menu.
4). Start taking pictures.
5). Set CONTINUOUS as the FRAME NO. setting in the SET-UP menu.
Good luck! And thanks for using FixYa!
Sep 05, 2011 | FUJIFILM FinePix J150w Compact Camera...
My fujifilm finepix camera gets stuck when i look through my pictures, so when i go to my library, my whole camera gets stuck and i have to take the battery out to turn it off. it still takes pictures, and...
The card is probably defective.
But before buying a new card, try to format the card in the camera. Make sure you have saved all images first. Formatting will "reset" the card and delete all images.
To format the card: Menu/ok, Setup, Format, OK
Feb 18, 2010 | Fuji J150w Digital Camera
Tool to open fuji finepix j150w
where did you buy the replacement screen? I just broke mine :(
Sep 22, 2009 | Cameras
I have a fujifilm j150w and it keeps on sayin card not initialize
i dont think there is a solution to this problem. i have the same problem with fujifilm j150w and this stupid error usually happens when you are at the height of excitement in taking pictures. it is sooooo annoying.
a temporary solution to it though is just format the stupid memory card using the stupid digicam. you can still you it though. but you can't depend on the digicam for special occasions and important events. i really dont think its worth it
Jun 25, 2009 | Fuji FinePix A400 Digital Camera
Fujifilm finepix j150w has slow shutter speed
Most digital compact cameras suffer from this shutter lag, though some cameras have managed to reduce it considerably. This is normal.
Feb 14, 2009 | Fuji J150w Digital Camera
Finepix z10
Check to make sure your battery pins are touching the connections on the battery. You might have to bend them slightly towards the battery to make a better connection. Else, I would get in touch with Fuji's support team. Good luck. -JHOBBS
Mar 22, 2008 | Fuji FinePix A345 Digital Camera
Cameras Logo
85 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
