Question about Philips DVP3140
How to unlock dvp3256
I would like to unlock philips dvp3256 for region code. currently it plays only region 5
  • 1 more comment
  • Anonymous Sep 21, 2008
    I own a Philips DVP3256/94 (this player also has a USB slot)... I not able to unlock the region. I went through the instructions that was given went to page preference and was not able to find PAGR and enter the passcode, all i could see was the ratings page where you have different ratings like PG, PGR,Adult,R. I clicked the "R" and "PGR" one after the other a passcode page appeared where i did enter the numbers that was suggested by you but nothing happened.
    Please Advise
    SAmir
  • Anonymous Nov 27, 2008
    I have similar problem. Please suggest how I could make my DVD Player DVP3256/94 Region free
  • Anonymous Mar 20, 2014
    no video any softwareto update
Following steps will sole the problem.
1. Power on
2. Open the tray
3. Press SETUP on remote and select PREFERENCE PAGR
4.Enter 138931
5. Press OK
6. Use up/down on remote to set the region code to 0
Posted on Aug 21, 2008
How to unlock regional code of philips HTB3510 3d blueray player?
Check current region code
Open the Philips HOME Screen
Type on your remote: 8520
This will display all of the current settings for your player.
Example: Region_Code: DVD(2) BD(B)Change region code
Turn on player with no disk inserted
Press "Open/Close" on the remote control until the tray is open
Press 8689310 - 0 means all region
Press 8689311 - 1 means region 1,
Press 8689312 - 2 means region 2,
Press 8689313 - 3 means region 3,
Press 8689314 - 4 means region 4,
Press 8689315 - 5 means region 5,
Press 8689316 - 6 means region 6.
Now the front Buttons might not work!
Go to SETUP and click on RESET FACTORY SETTINGS
Wait until the player restarts and now you can play all DVD regions
Oct 08, 2014 | Philips HTB3510 5.1 3D Home Theater System...
Philips DVD Player DVP5140
1. Turn on the unit
2. Open the loading tray
3. Press the "Setup" button on the remote
4. Navigate to the "Preferences" page using the right arrow key
5. Enter 138931
6. You will now see the current region code displayed
7. Use the Up/Down arrow keys to select the region required or "0" for all regions
8. Press the "Play" button on the remote
Aug 12, 2008 | Philips DVP5140 DVD Player
I want to play Dvd's from Europe so I want a region code free.
1. Power ON the main unit (some unlocks work with, some with no disc inside)
2. Press the SETUP button (on the top of the player) to open the setup menu
3. Navigate to the PREFER menu using the button below the screen
4. Press NEXT>, PREVIOUS, NEXT>, PREVIOUS, NEXT>, NEXT>, aPREVIOUS
(NEXT> and PREVIOUS are on the top of the player next to the SETUP button. Don't use the menu navigation buttons below the screen for this.)
5. The current Region of the player should be displayed on the screen
6. Use the menu navigation UP/DOWN buttons (below the screen) to change the region. Region 0 is region-free.
7. Press PLAY/OK (below the screen) to confirm the region selection
The player should now be unlocked and able to play discs from all regions - it worked on my PD9012/37 that was region 1
Please note: Unlocking a DVD player may invalidate the warranty and some DVD players have been damaged through failed attempts to unlock them. Unlocking the DVD player is attempted at your own risk.
Jun 21, 2011 | Philips PD7012/37 Player
Would like to unlock my DVD player (Region 2) to region free mode
HELLO!
I'm sure if you do this, you will be able to play your American DVD's!
1. Turn on the unit.
2. Open the loading tray.
3. Press the "Setup" button on the remote.
4. Navigate to the "Preferences" page using the right arrow key.
5. Enter 138931.
7. Use the Up/Down arrow keys to select the region required or "0" for all regions.
8. Press the "Play" button on the remote.
ALL THE BEST!!!!
Aug 08, 2009 | Philips DVP5140 DVD Player
Region Code Error for Philips DVP3256
hi
you can try this
>Go to Setup.
>Select Preference Page.
>Press 1, 3, 8, 9, 3, 1 on the Philips DVP3986 DVD Player remote.
>Press the up/down key to select "0" which makes it region free.
>Press ok and exit setup.
riz.
Feb 24, 2009 | Philips Televison & Video
Unlock region code for Philips DVP 3256
Region code hack for PHILIPS 3256 x/94
1. Go to Setup. [from remote]
2. Select the Preference Page.
3. Press 1, 3, 8, 9, 3, 1 on the Philips DVD Player remote.
--> It will show current region code [ for example 5 ]
4. Now Press the up/down key to select "0" which makes it region free.
5. Press ok and exit setup.
Probably the same would be applicable for 3258, 3268, 3986.
Good Luck!
Jan 02, 2009 | Philips DVD625 DVD Player
DVD PLayer Region Unlock
hello mushkil
you could try the following
1. Turn on the unit
5. Enter 138931
regions
this should unlock it to all regions .
riz.
Aug 16, 2008 | Televison & Video
1. Turn on the unit
5. Enter 138931
Tryed the code to unlock region
1. Turn on the unit
5. Enter 138931
DVP 5106k
1 - Make sure there is no disk in the player
2 - Press EJECT on the remote or on the player. The eject icon has to be visible on screen for the hack to work!!!
3 - Press MENU (System) on the remote
4 - Press the RIGHT button on the remote until you get to the PREFERENCES screen
5 - Now enter the sequence 135566 with the remote control
6 - Now "Region Code" should appear
7 - Select the 0 (multiregion)
8 - Press MENU (System) on the remote to exit the setup screen
9 - Press the power button on the remote to set the player on standby, this saves the new setting.
Apr 19, 2008 | Philips DVP5140 DVD Player
Philips DVP5960 DVD Player unlock code
1. Turn on the unit
5. Enter 138931
8. Press the "Setup" button on the remote
9. Press "OK" on the remote
Nov 17, 2007 | Computers & Internet
Philips DVP3140 Logo
614 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
