Question about Fujitsu LifeBookS6120 Notebook
When system boots an error occurs"system bios shadowed" "Mouse initialized error" just before the OS is loaded into RAM
    New Friend:
I had the same problem today:
fujitsu ef7 laptop Bios boot freezing
Stuck at "mouse initialized"
Applying walesarumi's solution, i finnaly noticed that was simply the battery. Once i removed the batery, the boot wasn't stuck anymore!
Thank you all! :)
Posted on Dec 28, 2012
    Brigadier General:
  • 8,909 Answers
Firstly I would enter the BIOS and set it to default. That should remove the BIOS Shadow. When you finally get it to boot, run CHKDSK/F to remove any hard disc virtual errors.
Hope that helps.
Posted on Mar 28, 2011
2 Suggested Answers
walesarumi
  • 6993 Answers
SOURCE: Hi: My Sony VGN FZ180E was dropped, OS won't boot
the problem should be from the Hard disk of your system. While it fell, the hard disk might have disconnected or has shifted and not properly fitted to its rightful position when the system dropped.
Turn of your system, remove the battery, then pull out the hard disk and fix it back into the system properly. Make sure its firm, couple it back, fix in the battery and try again.
Once your OS refuses to boot, the hard disk is the first thing to be checked. I believe the problem is from the hard disk part of your system.
Good luck.
Posted on Oct 09, 2010
Beep codes
AMI BIOS beep codes Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code Descriptions 1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed Award BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary. Beep Code Description 1 long, 2 short Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information Any other beep(s) RAM problem. If any other correctable hardware issues is found the BIOS displays a message. No Power, Loose Card, or Short.1 Short BeepNormal POST, computer is ok.2 Short BeepPOST error, review screen for error code.Continuous BeepNo Power, Loose Card, or Short.Repeating Short BeepNo Power, Loose Card, or Short.One Long and one Short BeepMotherboard issue.One Long and Two Short BeepsVideo (Mono/CGA Display Circuitry) issue.One Long and Three Short Beeps.Video (EGA) Display Circuitry.Three Long BeepsKeyboard or Keyboard card error.One Beep, Blank or Incorrect DisplayVideo Display Circuitry. Phoenix BIOS Q3.07 OR 4.X Beep Code Description and what to check 1-1-1-3 Verify Real Mode. 1-1-2-1 Get CPU Type. 1-1-2-3 Initialize system hardware. 1-1-3-1 Initialize chipset registers with initial POST values. 1-1-3-2 Set in POST flag. 1-1-3-3 Initialize CPU registers. 1-1-4-1 Initialize cache to initial POST values. 1-1-4-3 Initialize I/O. 1-2-1-1 Initialize Power Management. 1-2-1-2 Load alternate registers with initial POST values. 1-2-1-3 Jump to UserPatch0. 1-2-2-1 Initialize keyboard controller. 1-2-2-3 BIOS ROM checksum. 1-2-3-1 8254 timer initialization. 1-2-3-3 8237 DMA controller initialization. 1-2-4-1 Reset Programmable Interrupt Controller. 1-3-1-1 Test DRAM refresh. 1-3-1-3 Test 8742 Keyboard Controller. 1-3-2-1 Set ES segment to register to 4 GB. 1-3-3-1 28 Autosize DRAM. 1-3-3-3 Clear 512K base RAM. 1-3-4-1 Test 512 base address lines. 1-3-4-3 Test 512K base memory. 1-4-1-3 Test CPU bus-clock frequency. 1-4-2-4 Reinitialize the chipset. 1-4-3-1 Shadow system BIOS ROM. 1-4-3-2 Reinitialize the cache. 1-4-3-3 Autosize cache. 1-4-4-1 Configure advanced chipset registers. 1-4-4-2 Load alternate registers with CMOS values. 2-1-1-1 Set Initial CPU speed. 2-1-1-3 Initialize interrupt vectors. 2-1-2-1 Initialize BIOS interrupts. 2-1-2-3 Check ROM copyright notice. 2-1-2-4 Initialize manager for PCI Options ROMs. 2-1-3-1 Check video configuration against CMOS. 2-1-3-2 Initialize PCI bus and devices. 2-1-3-3 Initialize all video adapters in system. 2-1-4-1 Shadow video BIOS ROM. 2-1-4-3 Display copyright notice. 2-2-1-1 Display CPU Type and speed. 2-2-1-3 Test keyboard. 2-2-2-1 Set key click if enabled. 2-2-2-3 56 Enable keyboard. 2-2-3-1 Test for unexpected interrupts. 2-2-3-3 Display prompt Press F2 to enter SETUP. 2-2-4-1 Test RAM between 512 and 640k. 2-3-1-1 Test expanded memory. 2-3-1-3 Test extended memory address lines. 2-3-2-1 Jump to UserPatch1. 2-3-2-3 Configure advanced cache registers. 2-3-3-1 Enable external and CPU caches. 2-3-3-3 Display external cache size. 2-3-4-1 Display shadow message. 2-3-4-3 Display non-disposable segments. 2-4-1-1 Display error messages. 2-4-1-3 Check for configuration errors. 2-4-2-1 Test real-time clock. 2-4-2-3 Check for keyboard errors 2-4-4-1 Set up hardware interrupts vectors. 2-4-4-3 Test coprocessor if present. 3-1-1-1 Disable onboard I/O ports. 3-1-1-3 Detect and install external RS232 ports. 3-1-2-1 Detect and install external parallel ports. 3-1-2-3 Re-initialize onboard I/O ports. 3-1-3-1 Initialize BIOS Data Area. 3-1-3-3 Initialize Extended BIOS Data Area. 3-1-4-1 Initialize floppy controller. 3-2-1-1 Initialize hard disk controller. 3-2-1-2 Initialize local bus hard disk controller. 3-2-1-3 Jump to UserPatch2. 3-2-2-1 Disable A20 address line. 3-2-2-3 Clear huge ES segment register. 3-2-3-1 Search for option ROMs. 3-2-3-3 Shadow option ROMs. 3-2-4-1 Set up Power Management. 3-2-4-3 Enable hardware interrupts. 3-3-1-1 Set time of day. 3-3-1-3 Check key lock. 3-3-3-1 Erase F2 prompt. 3-3-3-3 Scan for F2 key stroke. 3-3-4-1 Enter SETUP. 3-3-4-3 Clear in POST flag. 3-4-1-1 Check for errors 3-4-1-3 POST done - prepare to boot operating system. 3-4-2-1 One beep. 3-4-2-3 Check password (optional). 3-4-3-1 Clear global descriptor table. 3-4-4-1 Clear parity checkers. 3-4-4-3 Clear screen (optional). 3-4-4-4 Check virus and backup reminders. 4-1-1-1 Try to boot with INT 19. 4-2-1-1 Interrupt handler error. 4-2-1-3 Unknown interrupt error. 4-2-2-1 Pending interrupt error. 4-2-2-3 Initialize option ROM error. 4-2-3-1 Shutdown error. 4-2-3-3 Extended Block Move. 4-2-4-1 Shutdown 10 error. 4-3-1-3 Initialize the chipset. 4-3-1-4 Initialize refresh counter. 4-3-2-1 Check for Forced Flash. 4-3-2-2 Check HW status of ROM. 4-3-2-3 BIOS ROM is OK. 4-3-2-4 Do a complete RAM test. 4-3-3-1 Do OEM initialization. 4-3-3-2 Initialize interrupt controller. 4-3-3-3 Read in bootstrap code. 4-3-3-4 Initialize all vectors. 4-3-4-1 Boot the Flash program. 4-3-4-2 Initialize the boot device. 4-3-4-3 Boot code was read OK.
http://www.computerhope.com/beep.htm
Jul 09, 2014 | EliteGroup GeForce6100PM-M2 Motherboard
CPU=1 Processors Detected, Cores per Processor =2 Intel (R) Corel (TM) 2 Duo CPU T5450 @1.66GHz 1015M System RAM Passed 2048 KB L2 Cache System BIOS Shadowed Video BIOS Shadowed ATAPI CD-ROM:...
if that is all you are getting a the system start, there is a good chance the hard disk drive may have failed. Try reseating the drive then F2 to BIOS, reset defaults and see if the system will boot. If HDD isn't detected in the bios, it has likely failed.
Jul 01, 2011 | Computers & Internet
My HP e9120f gave me the following error message the other day. "reboot and select proper boot device..." My first thought was my hard drive was bad. I could turn off the computer and after a...
You might have another part that has gone bad. Check the RAM and see if it gives you any problems.
There is a program call mem test that you can burn to a CD and test your memory. But if your no longer able to get to the bios:
you def had a hardware problem.
May 04, 2011 | HP DT PAVILION ELITE E9120f DESKTOP PC
I turn on my compaq and the first thing come on screen is CPU=AMD-K6(tm)/300 00000640K SYSTEM RAM PASSED 00064512K EXTENDED RAM PASSED 0512K CACHE SRAM MOUSE INITIALIZED FIXED DISK 0:FUJITSU...
above 06 lines are related with system information, Go to the BIOS check the startup sequence, if everything is ok save and exit from BIOS.
Apr 01, 2010 | Computers & Internet
Stuck on BIOS Screen?
I would try to power off the machine completely and hold a key down on the keyboard and power on the computer while still holding down one key. Keep holding it (it might make an irritating beep sound, that is expected) . This is one trick that will almost always force a computer to go into the BIOS. I might also check that the power to the Hard drive was not accidentaly unplugged as I see the CD-ROM drive was recognized, but I do not see a hard drive which means a couple of things, either the hard drive died or it has no connection to either the power or data cable. Check these and see if your computer will boot.
Jun 08, 2009 | E-Machines eMachines Desktop PC
I have aproblem with my Acer Aspire 3100 Laptop
locate the cmos/bios jumper below your memory ddr2 modules (J2) you need to be sure to make contact trought this jumper pe.-with a screwdriver, put back your memory modules and turn on your laptop, this process will clear your cmos/bios memory, you will need to setup your dates.
If this will not work you will need to replace your Mobo because of a faulty, we can replace your Mobo if you are interested:
10001 buckwood ave 79925 El paso tx
contact me if you are interested
support@vcrtech.com
vcrtech@hotmail.com
www.vcrtech.com
Apr 28, 2009 | Acer Aspire 3100 Notebook
Tecra M2 doesn't boot is it a processor problem?
given the symptoms, it points to motherboard.. if it was processor, video or ram. it wouldnt boot at all and you'd just get error beeps from your laptop. i'd first try resetting the bios, by removing the bios battery for 30 min, then putting it back in. if that doesnt work try changing it out, usually costs under 8 bucks. if that doesnt work then I would change out the motherboard, if its cost effective.
Mar 03, 2009 | Toshiba Tecra M2-S730 Notebook
Cant get to home page
Your laptop doesn't recognised hdd.
You should go to bios to see if your hdd is there.
if you don't see your hdd in the bios, most of the time is harddrive problem (dead).
In this case, you can replace your hdd.
but if you see your hdd and you get PXE-E61 error message, your OS might be corrupted.
Oct 16, 2008 | Acer Aspire 5630 Notebook
Fujitsu LifeBookS6120 Notebook Logo
236 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
