Question about Dell Computers & Internet
Dell latitude cpx. Charging Light flashes yellow then green when plugged in. When I push the power button that light and the one next to it turn green and the 2nd & 3rd light under thoseturn green also. But it doesn't power on. Any help?
  • 62 Answers
From what you have said it sounds like your battery might be the problem. Have you connected the computer to the wall and tried to turn it on. Is the same happening then?
Posted on Mar 28, 2011
Dell latitude 100L power light flashes green as if
It sounds like you have a bad AC adapter . When you plug it in to the outlet in the wall and into your computer , do you see a charge indicator light on the computer? I'm asking you this because even with a bad battery your computer should operate without any problems with the AC adapter plugged in.
May 13, 2010 | Dell Latitude 100L Notebook
Dell Lattitude CPx
first be sure the battery is actually charging ..than second thing to take in mind is the Ram memory ..cause it is the first thing that computer sees for to boot..
i fthe lights came on ..and you still got no activity after you verify the ram memory in another computer .. the only thing that remain is the the cpu..but ..I thing in this case it is the ram memory ..or a power issue..
May 01, 2010 | Dell Latitude CPX Notebook
I have a dell Latitude cpx that wont turn on.
may be you battary is corrupted....is it old battary?
Oct 27, 2009 | Dell Latitude CPX Notebook
When trying to start up my dell latitude CPX nothing happens, and when I plugg up the wall charger, there is a blinking light but still no power
A blinking light normally indicates a dead battery; however, since it does not power up when power is plugged in, I would suspect that the power jack on the motherboard needs to be repaired. This would explain the lack of power and the inability to charge the battery. I replace powerjacks a lot. Good luck. -Carlos:
Jun 13, 2009 | Dell Latitude CPX Notebook
PL-CS55 headset lifts receiver but only get buzzing sound in
Try a system reset:
1. Lift the headset off of the charging cradle (the base).  Make sure the headset is turned off.  The green light on the base won't be on if the headset is turned off. 2. Hold down the call answer button on the headset at the same time as mute button.  The mute button is found on the little black wheel on the top of the headset.  Use the tip of your finger to push it straight in. 3. Hold both buttons until you see a green light on the headset flash.  It will be right below your thumb.  Hold both buttons until the green light flashes for a series of 2 flashes.  Then let go of both buttons. 4. Put the headset back on the charging cradle and wait 30 seconds.  Lift it back off and try again. 5. If this doesn't work repeat the process once more or try a resubscription.
Resubscription procedure:
1. Put the headset back onto the charging cradle.  Make sure the red light on the base is on and the yellow light is flashing. 2. On the back of the base there are two buttons for the microphone adjustment that can be pressed down.  Press both of those down until the red light and yellow light on the front of the base start flashing. 3. While the headset is still on the charging cradle press and hold the mute button until the red light on the base goes solid, and the yellow light stays flashing. 4. Unplug the power to the base and then plug it back in. 5. Wait 20 seconds and try.
Apr 22, 2009 | Plantronics PL-CS55 Wireless Headset
Won't turn on
Have you tried a hard reset hold the Ctrl+R key at the same time as switching on the computer will sometimes clear the problem did on mine
Jan 19, 2009 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Dell Latitude cpx
Well, when the power supply is plugged to the computer, there should be a light indicating that the battery is charging. One other thing, does it turn off completely (I should have asked this first) or is it just blocking? No messages on screen?
Oct 15, 2008 | Dell Latitude C610/C600 Notebook
Dell latitude cpx will not power on
bad motherbord litte power tansformers on it getting to hot failed have to replace them or new bord
Jan 26, 2008 | Dell Latitude CpX Laptop PIII 500 Mhz...
My c600 is not puttin power in battery
if its the battery with a press button that lights up 5 green lights.. if u hold it for about 6 seconds it should light up all or some in a row like 000.. ( depends on charge it has) after 6 seconds none should flash , they should turn off . if any do flash or led green are missing in between its likely a bad battery.
Sep 29, 2007 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Computers & Internet Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
