Question about Panasonic Viera TH-42PX80U Plasma TV
Can remove stand from television - Panasonic Viera TH-42PX80U Plasma TV
  • 635 Answers
Yes you can remove the stand from the television for wall mounting purpose.Just unscrew the four screws marked by the yellow circles. Lift the TV up while somebody holds the base down or it will lift along with the TVand fall. Make sure you take help from one more person while doing this.can remove stand from television - bobhifi_22.jpg
Posted on Mar 28, 2011
How to remove stand from television?
Lay your tv on its back and then look under the stand part and you will see the bolts or screws holding the stand in place.
May 30, 2012 | Samsung Televison & Video
I have a olevia237 t12 lcd tv i cant seem to ge the stand off of? any tips?
Is it the stand you're trying to to take off? If so, follow the steps below.
1 Unplug the television and remove any connected audio or video cables from the rear.
2 Place the television face down on a soft bed spread to avoid screen damage.
3 Examine the rear of the television and locate the screws securing the stand to the monitor. Depending upon your particular model, the screws securing the stand to the television may be marked with an "Arrow" symbol.
4 Remove the screws securing the stand to the television with an appropriately-sized Philips screwdriver. Slide the plastic stand off the rear of the television.
5 Store the mounting screws and plastic stand for future use.
Thank you for visiting FixYa! We answer your concerns promptly for FREE. Please spare a few seconds to click on YES button and leave a short comment to let other people know how I help you. Have a good one!
Aug 20, 2011 | Olevia 237T 37 in. LCD TV
How do i remove the tv stand from a 42 inch flat sreen so i can hang it on the wall
Before detaching the stand, unplug the AC cord from the AC INPUT terminal. Before performing work spread cushioning over the base area to lay the TV on. This will prevent it from being damaged.
With the tool you will be using to remove the stand remove the screws from the bottom back of the television and remove the stand.
Jan 08, 2011 | Televison & Video
How can i get the stand off of the tv to hang on the wall?
With the hex key that came with the television stand remove the four screws from the bottom back of the television and remove the stand.
If you also wish to remove the post from the stand base unit you can remove the four screws that attach them.
Jan 03, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
HI how do I remove the tv stand part because i want to mount it?
After disconnect power/antenna/any AV wires, turn your TV. Look at back side of your TV (on TOP of Stand part). You should see some screws there. To remove your stand, you should unscrew them all. Then Hold your stand and pull UP your TV. Be careful with your TV once your stand taken apart .
Nov 28, 2010 | Proscan 19LA25Q 19 in. LCD Television
How can I remove the the stand so I can mount it on the wall
1)Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
2)Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3)Remove the five screws shown in the diagram below. This will
allow removal of the pedestal stand.
4)Once you have removed all five screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
5)Now you are ready to install the wall mount brackets
I hope this helps and good luck!
Feb 28, 2010 | Toshiba 32HL67 32 in. LCD Television
Question on toshiba tv - fixya post
Found this on the www.Toshiba.com website. Q. How do you remove the stand?
Models: 26HL37, 26HL47, 32HL17, 37HL17, 42HL17, 32HL37, 26HL67, 32HL67, 37HL67, 42HL167, 42HL67,
47HL167, 52HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00078
1. Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface. NOTE: Extreme care should always be used when removing the pedestal
stand to avoid damage to the LCD panel.
2. Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can
be removed without tools.
3. Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
4. Once you have removed the five screws holding the pedestal stand in place, remove the stand from the TV by
sliding the stand away from the TV. The Toshiba customer service number is 1-800-631-3811. Hope this helps you with your problem.
Dec 22, 2008 | Toshiba 42HL167 42 in. LCD Television
Removing tv stand
Remove the screw and pull the TV upwards.
Have someone step on the stand
Dec 07, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Remove swivel stand
There's likely a plastic cover on the back of the swivel stand. If so, remove it and you will find four to eight phillips screws. Take them out and the stand should come free. If there is no plastic cover, then there should be some screws in the back cover that go through the back cover and into the support. Remove the screws and gently remove the stand. Good luck. David
Sep 05, 2008 | Toshiba REGZA 46RV530U LCD TV
Panasonic Viera TH-42PX80U Plasma TV Logo
982 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
