Question about Xerox Phaser 6180N Laser Printer
Printer is populating the error code 093-423 replace yellow catridge. Please suggest us what need to do.
Service error 6500 ix4000
The Canon website indicates that is a hardware problem, there's nothing i can do. You call a technician or the canon help support. This is the description of the code:
Other hardware error [6500] - Logic board ***'y (QM2-3393 / QM3-1654)
Mar 02, 2011 | Canon PIXMA iX4000 InkJet Photo Printer
The answer to my error 5100 question was replace pinhead and clean. where is the "pinhead"??
You need to open the top cover, access the ink catridge case(Where catridges hung), then look for other objects that look like ink catridges but smaller, that's where the catridges feed ink (into the print heads) usually separate by colors cyan, magenta and yellow Usually Black is a lone. Replace the print Heads and clean where the dirty ink drops.
Dec 03, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Help w/ h/p deskjet 3520
hi/....
this is because of the low ink in the catridge. normally the colour catridge contains three colour in it. yellow ,blue and i think one more is pink. so in your case the other colours might have finished. so because of that you are getting only yellow. so please replace the catridge with new one and the problem wil be solved
Jul 15, 2010 | HP DeskJet 3520 InkJet Printer
My lexmark 7170 printer has error message : right cartridge incorrect. I pulled the brick. Waited a few minutes, replaced but error still appears. Turned off and on etc. Lexmark quide was not helpful. any...
You are trying to put the wrong catridge into right hand side,. the catridge you have put is incorrect. try removing the catridge and put the right catridge back
Jan 09, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Ink system failure, won't reset, won't respond to cleaning
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com , click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 31, 2009 | HP Photosmart C6180 All-In-One InkJet...
Error code 1203
it is catridge error kindly replace the catridges.
Nov 24, 2009 | Lexmark P450 InkJet Photo Printer
Canon mp460 printer. refilled cartridge not recognised
Dear Sir,
This is deffinately due to catridge circuit problem.Canon suggest that we have to replace emptied catridges with new genuine canon catridge they dont suggest refilling and also not give any support for refilling catridges. So you can replace catridge with new one.
This Happens due to weakining of catridge circuit portion or may long period printer not in use.
If you not want to replace catridges i will give you the possible hints it may fix refilled catridges.
1.Clean the catridge circuit portion with soft cloth,care must be taken that there is no smudge or ink traces on catridge circuit.
2.Clean the ciruit of printer catridge placing box present inside the printer .wipe out the any sumdge or ink traces.
Then re install the catridges. give the print if it shows error press resume button continuosly. I think it will fix your problem.
If it is not solution is replace the catridge with new one.
good luck
Aug 26, 2009 | Office Equipment & Supplies
HP LaserJet 2420dn Catridge Data Error
CHANGE THE TONER!
TROUBLE BOILS DOWN TO SAME THING BUT!
IF IT IS AN HP OR A REBUILT NON-HP CARTRIDGE THE E-PROM ON THE CARTRIDGE IS BAD OR DROPPED OFF AND THE PRINTER CAN NOT READ IT.
WHAT YOU COULD DO IS TRY TO TAKE THE E-PROM FROM YOU OLD TONER (IF YOU STILL HAVE IT AROUND AND GLUE IT IN PLACE OF YOUR NEW CARTRIDGES E-PROM
Jul 31, 2008 | HP LaserJet 2420dn Printer
Xerox Phaser 6180N Laser Printer Logo
547 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
