Question about Car Audio & Video
Bass is going though it with rca offf the amp and it rumbles like its not clean when it is on have a amp for the door speckers but two are hooked up to the deck not to other amp dont know why it is doing this can you help its a kicker zx750.1
  • 635 Answers
Was it OK before with the same connection some time back ?.
You have not mentioned which sub woofer you are using. Any way check the following:
The head unit has 2 sets of RCA out labeled front out and rear out. Then it will have a single RCA out labeled sub woofer.
Your door speakers must be connected to the front and rear out if you have a 4 channel amplifier.
Now your Kicker zx750 is a very powerful amplifier ( 750 watts r.m.s ). Make sure your sub woofer has the same power rating or more.Set your crossover to about 80 Hz and turn on the subsonic filter for the time being.Turn down the Bass boost control to zero.On the head unit keep the sub woofer level to half.
Now with the boot and door closed play some music and see how it sound and if not satisfied turn up the bass level using the Kicker's wired remote control. It should work ok. Cheers !!
Posted on Mar 28, 2011
Hooking up two amps together
Yes. There could be big issues depending on how you want to "hook" them together. If you are wanting to simply run them at the same time (play through both at once) you can get a cheap signal splitter from GC or Radioshack and run your bass to the input, then output 1 and 2 to the respective amps. That is your best bet.
Setting up two amps parrallel does not nessesarily add power. That is to say that your 150 and your 350 "hooked" together does not give you 500 watts. In addition, there may be some issues with running a powered signal from the first amp into an input that is not designed for powered signals. Try the splitter or an old fashioned AB box. Safe and a cool trick. You can also use a stereo chorus pedal and let the signal chorus between amps. Makes the bass sound huge! Try it and good luck.
Jun 17, 2013 | Fender Music
HI CAN YOU PLEASE TELL ME WHY MY FENDER RUMBLE 100 BASS AMP DISTORTS AT LOW VOLUME? EVEN THOUGH THE SPEAKERS IS NOT BLOWN
A common reason for 'distortion' with all bass amps can be either that the screws holding the speaker unit to the cabinet have worked loose or that there has been a build up of dust particles in the corrugations around the edge of the speaker cone, which rattle especially on the lower notes.
The solution is simple - remove the front grille and check the screws are tight. Use a vacuum cleaner to remove dust from the rim of the speaker cone.
Feb 01, 2011 | Fender Rumble 100 Bass Guitar Amplifier
Hello ! Do You have shematic diagram for bass guitar combo Fender Bass Rumble 100 / 15 ? If You have it, please snd me on my e-mail ? Regards Zlatko
Try this link:http://www.fender.com/support/amplifier_schematics.php If your amp isn't listed contact them and they will send you one.
Oct 21, 2010 | Fender Rumble 100 Bass Guitar Amplifier
Speaker has become crackly, only when i play certain notes though. I tried a different cord and bass and its definitely the amp. I have never turned the volume over three quarters, Should I just switch out...
Before changing the speaker, check for debris or other things in the cabinet or grill that MIGHT be rattling..
Also, plug in an external speaker to the ext jack and see if it is clean.
Aug 18, 2010 | Fender Rumble 100 Bass Guitar Amplifier
Speakers pop or rumble when stereo is turned on
AMP HAS PROBLEM.. SOUNDS AS THOUGH THE LINE INPUT AMPS HAVE PROBLEMS IN AMP ALSO ONE THING TO CHECK WOULD BE TO DISCONNECT SPEAKERS AND HOOK UP RCA'S.. CHECK THE SPEAKER OUT PUTS WITH A DC VOLT METER TO SEE IF YOU HAVE DC VOLTAGE ON THEM IF SO YOU HAVE SOME SHORTED OUTPUTS
Apr 24, 2010 | Kicker ZR600 Car Audio Amplifier
How do i wire in a Zn-4088 Xlopd sub/amp?
I also bought one and it came with no instructions either.
Should be pretty simple but if you want to control the On/Off of it by the head unit you will need to use a relay,
Sep 24, 2009 | Car Audio & Video
Similar prob.did the 12 steps on how to install amp(jensen4100,blue).red protec light comes on when starting car then goes out and is not followed up by the green protec light .green one never comes on....
If you are running a set or a single subwoofer with the jensen amp than you will want to hook up the rca cord to the subwoofer rca connection on the back of the stereo unit-the other rca outputs are there in the event that you want to run a 2 or 4 channel amp to power the speakers that are generally located in the doors or back deck-with that set up properly you would still be able to adjust the balance and the fader just as though you were powering the speakers with the deck. Pug the free ends of the RCA cord into the input rca receptacles of the amp- the stereo now will feed a signal to the amplifier that only contains bass - good luck
May 16, 2009 | Jensen LXA300 Car Audio Amplifier
Fender Rumble 100 210 pop noise then hum after strong low e note
I just fixed my bass amp with a similar problem last week: the problem is related to a loose connection on the PCB board (likely).
A bass amp is a rough place for circuitry: the low rumble and power shake a bass amp more than a guitar amp.
In my case, the power transistors needed to be re-soldered and then the grounding bolts and screws needed to be removed and cleaned because the connection was bad. Remember that when two different metals needed for an electric connection are toughing, there is the likelyhood that corrosion WILL happen.
My bass amp did basically the same thing yours did: sounded good at low volumes, but at higher volumes it would act up.
In short, there is nothing you can do (unless you are a repair person): you need to take it to a local music shop and have a tech fix the intermittant contact problem: someone who knows what they are doing should only take an hour at most.
Hope that helps!
-mike
Feb 22, 2009 | Fender Rumble 100 Bass Guitar Amplifier
Cant figure out my car audio problems!!!!!
There are a couple of tests you can perform. I'd first recommend checking the shield ground. You'll need an ohm meter. The details can be found on the following page.
RCA shield ground test
You can also test the output with the multimeter. Set the multimeter to AC volts. If it's not an auto-ranging meter, set it to a voltage range of ~2v AC. Disconnect the RCA cables from the head unit. Touch one meter probe to the outer ring of the head unit's RCA jack. Touch the other probe to the metal contact in the center of the RCA jack. With the head unit near full volume and a clean signal source, you should read at least one volt on musical peaks. If you have a bass disc or a test tone disc (~60hz sine wave), use those.
May 04, 2008 | MTX Thunder 8302 Car Audio Amplifier
Amp cuts off
So you have an EQ and a Pioneer amp you're trying to hook up to each other? And only some Stinger RCA cable works? And when the lightning audio RCA cable is hooked up, it doesn't turn on? The amp isn't grounding itself through the RCA cables, is it? Check your ground wire and make sure it has a clean contact that's free of rust or any paint that might be in the way. Otherwise, the RCA cables should have nothing to do with an amp turning on or not.
May 07, 2006 | Pioneer GM-X324 Car Audio Amplifier
Car Audio & Video Logo
22 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
